Old 09-22-2019, 12:12 PM   #1
solidsnake11
Drives: brz
Unplugged ECU with battery hooked up seems Bricked
I was being lazy and did not unhook battery. Then unplugged ecu and reconnected it. It will not start or respond to tactrix or elm. I have the 2017 limited cluster and it says engine coolant high tempature. This is a 2013 brz smart entry. Anybody have any advice? I have already ordered two used ecus.
solidsnake11 is offline   Reply With Quote
Old 09-22-2019, 04:08 PM   #2
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
It may be bricked...
Not exactly the same but I had a problem with laptop dying during a write and mine seemed bricked. What I had to do was disconnect the battery and press the break to fully discharge everything and then reconnect the battery and I was able to connect to and rewrite it.
I would try disconnecting the battery with the ECU plugged in and pressing the brake for 30-60 seconds and then reconnect the battery and try to connect with tactrix then and see if that works for you.
Jaden
Jaden is offline   Reply With Quote
Old 09-22-2019, 06:04 PM   #3
steve99
Drives: FT86
As above with everything plugged in remove battery , press brake, try tactrix again after reconnecting.
Stil no go diconnect battery for 30 minutes try again.
Id be quite supprised if ecu is damaged unless you shorted something. Ix say either ghe ecu or other modules in car are in a strange state when they lost contact with ecu
Old 09-22-2019, 06:14 PM   #4
solidsnake11
Drives: brz
Thanks guys, I wish we had an open source recovery. I would give a donation for that. One more question do I wait in till the bell gets through dinging before I hit program.
Old 09-22-2019, 06:16 PM   #5
steve99
Drives: FT86
Thanks guys, I wish we had an open source recovery. I would give some moneys for that. One more question do I wait in till the bell gets through dinging.
Tactrix you always need to turn ignition on full, not accessory, engine stopped. Then wait 15 seconds, before trying read or write
Old 09-22-2019, 06:17 PM   #6
steve99
Drives: FT86
Did you write to ecu just prior to unplugging ecu ??
Old 09-22-2019, 06:19 PM   #7
steve99
Drives: FT86
Make sure all 4 ecu plugs are pushed in all the way till the clip clicks
Old 09-22-2019, 06:21 PM   #8
solidsnake11
Drives: brz
No just unplugged it.
Old 09-22-2019, 06:22 PM   #9
solidsnake11
Drives: brz
Will do.
Old 09-22-2019, 06:27 PM   #10
solidsnake11
Drives: brz
Going to try again. Will post results later. Thanks again!
Old 09-22-2019, 06:49 PM   #11
solidsnake11
Drives: brz
Obd2 communication failed trying oem bootloader....
Oem bootloader communication failed.
This is what I get.
Old 09-22-2019, 07:01 PM   #12
steve99
Drives: FT86
This is what I get.
Does it read vin number and calid ??
Have you ever flashed this ecu before with tactrix ?
Os battery volts near 12v
Old 09-22-2019, 07:09 PM   #13
solidsnake11
Drives: brz
No vin or calid.
12.3 volts
I have flashed it about 30 times or more.
Techstream doesn't communicate nor my elm.
Old 09-22-2019, 07:30 PM   #14
solidsnake11
Drives: brz
Before it was bricked the cluster would say the same thing "engine coolant high tempature" when I was loading a rom. Now it's permanent anytime the key is on.
Car only starts when primary 02 is unplugged j0hnnybk01 Issues | Warranty | Recalls / TSB 22 08-28-2017 11:13 AM
My first drift event and now I'm hooked. mhightower FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 05-23-2017 12:58 PM
Accidentally unplugged a pressurized air hose on radiator? G-awesome Issues | Warranty | Recalls / TSB 4 08-28-2015 12:43 PM
DAMN I'M HOOKED Touge Monster Tracking / Autocross / HPDE / Drifting 0 12-26-2012 03:46 PM
Why am I hooked on this car? Rob_g CANADA 9 06-21-2012 01:50 AM
