Old 07-17-2012, 08:02 PM   #1
Style
LXXXVI
Style's Avatar
Drives: Dahlia (Raven FR-S)
Shift light.
Noob question:
I was wondering if the shift light indicator is only available for MT or is it available with the AT as well...if so how do you access it?
Style is offline   Reply With Quote
Old 07-17-2012, 08:19 PM   #2
nquillen
Drives: SWP BRZ
No idea if it works on automatic, but manual doesn't say it won't.
While stopped hit the "DISP" button until the screen says "rev. --00"
Press and hold "DISP" to go into a mode to change it
Tapping "DISP" toggles through the the 1000s digit the 100s digit and weather or not you want it to beap("b on" or "b off").
Press and hold "DISP" to change the current thing selected.
Page 196 of the BRZ manual(which you can download), section "Setting the REV indicator".
nquillen is offline   Reply With Quote
Old 07-17-2012, 09:13 PM   #3
Ziggyzag420
Drives: 2013 Fr-s
It does work on the automatic as well
Ziggyzag420 is offline   Reply With Quote
Old 07-18-2012, 09:17 AM   #4
Ocho-Seis
Ocho-Seis's Avatar
Drives: Raven FR-S 6MT
What point would it serve on an Auto?
Ocho-Seis is offline   Reply With Quote
Old 07-18-2012, 09:32 AM   #5
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
There is still a manual mode in the AT which allows you to shift via paddle shifters or the shifter itself.
Old 07-18-2012, 09:33 AM   #6
Nepenthe
Drives: 2013 Argento Silver Automatic FR-S
You do know the auto has a user-shift mode, don't you?
Anyway, I use mine at 2300 RPMs to facilitate economy driving in D+Snow mode on my morning and afternoon commutes.
Nepenthe is offline   Reply With Quote
Old 07-18-2012, 09:49 AM   #7
Ocho-Seis
Ocho-Seis's Avatar
I know that, but even in an Auto once it hits Redline its going to shift for you any way....Idk call me a negative nanny I still don't see the point.
Old 07-18-2012, 09:53 AM   #8
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
In manual mode? Not on the FR-S, it won't. It'll sit there and ping off the rev limiter all day until you shift it yourself. The only time the car will shift for you in manual mode is downshifting to avoid a stall. IIRC, I think it'll also upshift if the engine starts to overheat, but I haven't run into that situation yet.
MVJ1975 is offline   Reply With Quote
The Following 6 Users Say Thank You to MVJ1975 For This Useful Post:
blackfireball5 (07-18-2012), Dadhawk (07-18-2012), denkigrve (07-18-2012), ExWhyZer0 (10-19-2012), hav0c (07-19-2012), Ocho-Seis (07-18-2012)
Old 07-18-2012, 10:40 AM   #9
Originally Posted by Nepenthe View Post
...Anyway, I use mine at 2300 RPMs to facilitate economy driving in D+Snow mode on my morning and afternoon commutes.
Interesting, are you seeing any appreciable gains from this? I pretty much drive in standard mode with the occasional bursts of madman, and I'm averaging almost 32MPG in mine.
Old 07-18-2012, 10:51 AM   #10
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
As a counterpoint to that, I drive mostly in sport, and I indulge my inner hoon at every possible opportunity. Corner coming up? Ooh, let's see if we can get the VSC to kick in! I am a symphony of squealing Michelins.
To make matters worse, most of my drive is low-speed stop and go. 55 max, with stoplights a-plenty.
I'm still managing around 25mpg, and for me and this area, I'm pleased. My tC was worse.
Old 07-18-2012, 11:40 AM   #11
Nepenthe
Snow mode does seem to have a couple of effects beyond just starting in 2nd (which provides ample torque by the way): The shift programming is more conservative than standard mode, shifting seems a little softer and throttle seems a little softer. I believe it makes a bit of a difference.
Is that 32 MPG calculated using your fillup gallons and mileage or based on the AVG MPG on the dash? Best I've seen on my commute (30 mph roads mostly, a dozen stop signs) is 37.2 MPG on the dash computer by resetting it right after start. I'm still waiting for my next fillup to get a more accurate actual MPG for the tankfull.
It's more of a game to me than anything. Just an interesting contest I have with myself rather than an attempt to conserve earth's resources for future generations or save enough money to retire on.
Old 07-18-2012, 11:56 AM   #12
Lefty
Drives: Scion FR-S
I do approximately 70% HWY/30% City. Getting 32 MPG using dash calculator and 30.5 MPG doing to actual calculation.
Cruise control in 6th is annoying if you have it pegged at around 75 MPH. It will shift down on even a remote incline. I find myself putting it in manual mode and setting cruise control so it sticks in 6th.
Lefty is offline   Reply With Quote
Old 07-18-2012, 12:37 PM   #13
Manually calculated over 3000+ miles, mostly commuting (although not quite city miles obviously). Details are here at the bottom of my Journal's OP.
Interesting results I may have to play with it on my next fill-up just to see what happens.
Old 07-18-2012, 12:47 PM   #14
Skyhound
Drives: Jaguar X-Type
The User Shift mode acts exactly like a Manual except the clutch is automated. It won't shift down or up if you don't make it. On the FR-S it's a nice middle-of-the-road option between practicality and performance since it blips the throttle after down shifting. Though race cars, most high end sports cars, and I BELIEVE the Volkswagon GTI have a double clutch automatic w/ paddle shifters which actually shift better and faster than any human ever could.
Skyhound is offline   Reply With Quote
How to set the Shift Light & Gear Indicator Display Settings EsoBOFH DIY (Do-It-Yourself) Guides 76 04-21-2020 08:42 PM
ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD! ZILLA DIY (Do-It-Yourself) Guides 117 09-19-2017 10:17 AM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 11:21 AM
Shift Knobs For your FR-S TWMPerformance Interior Parts (Incl. Lighting) 19 06-03-2012 09:29 AM
Shift Apparel Lexicon101 Other Vehicles & General Automotive Discussions 2 05-02-2010 12:44 AM
