Old 05-09-2019, 07:45 PM   #1
StaggeredHorizons
Drives: 2015 FRS
How To: Change your Transmission & Differential Fluid
New Video is up, thought this would be helpful as this is a must, preventative maintenance for our cars!
Hope you enjoy, subscribe for more content, Thank You!
[ame]https://www.youtube.com/watch?v=eZjbr4EbWAE[/ame]
StaggeredHorizons is offline   Reply With Quote
The Following 5 Users Say Thank You to StaggeredHorizons For This Useful Post:
alphasaur (05-28-2019), humfrz (05-09-2019), Impureclient (05-11-2019), MJones_RB (05-21-2019), rixter145 (05-09-2019)
Old 05-09-2019, 10:29 PM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
It's not a necessary maintenance task.
Old 05-11-2019, 06:36 PM   #3
gravitylover
^^ Of course it is. That's a silly thing to say.
When I did my rear diff I spun the wheels by hand while the plug was out and more fluid drained out, not much but enough that it was worth that small effort.
Old 05-28-2019, 11:59 PM   #4
alphasaur
friendly
Drives: 17' 86
Appreciate this video.
Where in ny? A lot of rust/salt considering only 30k miles
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 05-29-2019, 08:47 AM   #5
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Looks like a normal amount of undercarriage corrosion for a vehicle that gets driven all seasons in the snow belt, especially if in an area that (over)uses salt on the roads...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 05-29-2019, 12:11 PM   #6
alphasaur
friendly
Drives: 17' 86
I drive in all seasons in new york, and I haven't had that much rust on my undercarriage and am at similar mileage.
That's why I was asking, I'm assuming his area throws down an obscene amount of salt.
Old 05-29-2019, 12:59 PM   #7
Grady
Grady's Avatar
When doing the engine oil change you should start your engine too while drain plug and filter are off. More oil will come out.
The Following User Says Thank You to Grady For This Useful Post:
Mr.ac (05-30-2019)
Old 05-29-2019, 10:15 PM   #8
StaggeredHorizons
Drives: 2015 FRS
thanks everyone! I am between NYC and Albany and yes, the roads get covered with as much salt and sand like a beach
let me know if you have any questions and be sure to subscribe for more content, thanks!
Old 05-29-2019, 10:23 PM   #9
gravitylover
Oh come on. A 3-5 second spin by hand generates next to no heat and can't create any damage but a bit of fluid will run off. Sorry your popcorn is stale and some of the kernels didn't pop, don't hurt your teeth.
Hey neighbor
Old 05-30-2019, 01:02 AM   #10
Phuviano
Drives: FRS RS 2.0 #757
Wow that diff drain plug looks filthy. Also I have those same shitty disposable gloves, they always end up ripping.
Phuviano is offline   Reply With Quote
Old 05-30-2019, 01:46 AM   #11
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
You forgot to mention to add a bottle of simple green or any brand of degreeser to the engine. Then start the engine.
I'll post up my YouTube vid on how to do this later. But only after I get you chumps....er I mean followers to subscribe for more content.
The Following User Says Thank You to Mr.ac For This Useful Post:
Grady (05-30-2019)
Old 05-30-2019, 08:27 AM   #12
StaggeredHorizons
Drives: 2015 FRS
Gravitylover where in NY are you?
Old 05-30-2019, 08:28 AM   #13
StaggeredHorizons
Drives: 2015 FRS
Phuviano, I know those gloves are terrible and rip in seconds haha
Old 06-01-2019, 06:46 PM   #14
Aluma007
Drives: 2017 Brz
I'm guessing the AT isnt that easy...:/
Aluma007 is offline   Reply With Quote
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
Differential Fluid Change Drain Plug - 10k & 40k BRZ_F Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 01-04-2018 10:25 AM
Changing Differential and Transmission fluid Seabass47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-20-2017 12:21 AM
Differential and Transmission Fluid Swap with Red Line Oil - 2013 Subaru BRZ JPxM0Dz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 05-05-2013 05:12 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
