Old 05-23-2019, 02:16 PM   #1
ETM_Shaman
ETM_Shaman's Avatar
Drives: 2013 Toyota GT86
FA20 oiling problems, study and solution
Hi all, this is my first post but I'm a long time user of the wealth of information shared in this forum.
I'm co-owner of a performance shop in Lima - Peru and have a 2013 Toyota GT86 as a personal car. I wanted big power so I installed a Sprintex 335 supercharger together with many other upgrades and a full engine build.
Since then I struggled with oil starvation issues very similiar to the well documented problems in this good threads:
http://www.ft86club.com/forums/showthread.php?t=63723
https://www.ft86club.com/forums/showthread.php?t=131419
To sum it up, I had three engine failures with damaged bearings indicating oil starvation. Oil pressure was always good (I have a gauge with sensor tapped to the main oil gallery), engine build was clean and checked (we've built many performance engines). I chose to use 0.04 mm main and 0.06 mm rod clearance, and although a little looser than spec, by no means reason for failure. I'm also using Motul 300V 10W40 oil. For some reason there was not enough oil flow to the bearings (rod bearings suffer first of course), particularly at high RPMs: I could do a couple hundred km of break in below 5,000 RPMs full power without problems, but as soon as I started hitting my 7,600 RPM redline, boom. A stock engine can take 7,600 RPM all day long so
This felt a lot like oil flow restriction of some sort, having ruled out most of other variables. I had a much more detailed look at the oil galleries in this engine.
The first thing I noticed is the very long and restrictive oil galleries from the pump to the crank (including the main gallery which tapers from 12mm to 8mm) so I did this:
1. main oil gallery enlarged and straightened to 12.7mm
2. block entrance enlarged (shoulder modified for bigger oring)
3. pump to block gallery enlarged to 12.7mm
4. all restrictive parts on the timing cover galleries ported / enlarged to 12.7 mm (including galleries to / from the oil filter)
5. blocked small return hole in oil pump with epoxy and shimmed the PRV 2.0 mm
After this work I had another oil starvation engine failure, at first I was at a loss and very frustrated.
Then I looked at the only part I hadn't improved: the inlet side of the pump. After all I know now, I think this is THE most important part to improve, even in stock engines:
After reading a lot about oil pump cavitation I had a much more detailed look at my oil pump's inlet parts. After three engine failures, cavitation HAD to leave a mark if it was part of the problem:
a smoking gun right in front of me!
I wanted some confirmation with the engine running (maybe the oil pump came cast like that? how can I be sure?). Cavitation is very hard to evidence in real life, luckily after a lot of searching I found this amazing research paper by E. FROSINA, A. SENATORE , D. BUONO, F. P. BOVE of the University of Naples, Italy:
https://www.gtisoft.com/wp-content/u...r_IUC-2017.pdf
Although the pump is not exactly like ours, it's very similar and the information I'm looking for applies: how inlet pressure (something I can measure with a little work) relates to cavitation and pump output.
This is the summary for that (taken straight from their paper):
So if you want good mass flow you need to keep your oil pump inlet pressure above -0.2 bar at all times.
I rebuilt my engine, tapped the oil pump's inlet and connected it to my vac / boost gauge and started doing tests:
To my surprise, inlet pressure would drop to -0.23 bar at high RPMs. This was with the stock oil pickup but with the other oil inlet galleries already enlarged! With a completely stock oil pump inlet, pressures would surely drop below that causing heavy cavitation. I didn't test like that because I'd have to tear the engine apart to enlarge the internal inlet galleries after the tests while the oil pickup is easily changed.
I ordered a Killer B Motorsport Ultimate FA20 WRX Oil Pickup and modified it (the WRX FA20 pickup has a different length and orientation, besides, their pickup tube has aprox 19.4 mm inner diameter and I wanted at least 22.0 mm):
We used a TIG welded 1" pipe that had 22.4 mm inner diameter:
After the install I repeated the tests and these are the results:
Big difference in inlet pressure but small difference in outlet pressure (which ilustrates how oil pressure in the outlet doesn't tell you 100% of the story).
After about 1,000 km of very heavy (almost track-like) use with clean oil and oil filter inspections I'm confident we've solved the problem. I'd love to take a look at the rod bearings but it would be hell in this engine.
I think stock engines survive because they have very tight clearances that keep oil flow low and the inlet and outlet galleries are *just enough*. Low viscosity oil also helps in the cavitation department. Even so I think that stock engines that are regularly taken above 7,000 RPM are cavitating, just not enough to destroy the engine (and sometimes yes, look at all the "spun rod bearing" stories). All FA20 engines will benefit from a much less restrictive oil pump inlet. Taking into account that the stock oil pickup elbow is THE most restrictive part of the whole inlet, a good enough solution might be to just install a Killer B improved pickup. They even have one correctly fabricated for the GT86 FA20 now (I will still ask them to make a 1" tube version for my engines).
The car has a lot of power and there's room for more . I had a lot of upgrade paths paused while solving this issue.
My happy car:
ETM_Shaman is offline   Reply With Quote
The Following 46 Users Say Thank You to ETM_Shaman For This Useful Post:
7 skulls (05-23-2019), AT-JeffT (03-13-2021), ATL BRZ (05-25-2019), BatStig (05-23-2019), BigHugeFatGuy (01-23-2020), BigTuna (05-23-2019), Boris_Petrov (05-23-2019), Calum (05-24-2019), Capt Spaulding (05-24-2019), churchx (05-23-2019), clayrush (05-24-2019), EndlessAzure (05-23-2019), FeRS (03-08-2022), flippy (04-02-2022), HKz (05-23-2019), HlfpriceWngs (05-23-2019), Horrid_Funk (05-23-2019), humfrz (05-23-2019), i8ur911 (11-05-2019), imprezive (05-24-2019), Irace86.2.0 (05-23-2019), jcw99 (05-27-2019), JIM THEO (05-23-2019), Joesurf79 (05-23-2019), JohnH (11-23-2021), kevaughan (10-27-2022), lamawithonel (06-18-2019), Lantanafrs2 (05-23-2019), mkodama (06-04-2023), NoHaveMSG (05-23-2019), PulsarBeeerz (05-23-2019), rixter145 (05-24-2019), SCFD (06-21-2021), shiumai (05-23-2019), soundman98 (05-23-2019), Spuds (05-23-2019), theadmiral976 (05-23-2019), timurrrr (08-27-2019), Tokay444 (05-24-2019), Tristor (05-23-2019), Trueweltall (05-25-2019), Ultramaroon (05-23-2019), Wally86 (11-12-2020), Wasabi (07-23-2019), whataboutbob (11-09-2021), ZDan (05-23-2019)
Old 05-23-2019, 02:22 PM   #2
ETM_Shaman
ETM_Shaman's Avatar
Timing cover pressure test
After reading the threads that mentioned the possibility of having oil leaks through the oil gallery covers in the timing cover, we did an air pressure test (after assembling the covers with anaerobic sealant and an impact screwdriver used *carefully*):
There were absolutely no leaks in any of the oil gallery covers or in the pump itself. This for me settled the issue (this test was done before beginning with the modifications mentioned in the first post).
The Following User Says Thank You to ETM_Shaman For This Useful Post:
Old 05-23-2019, 02:33 PM   #3
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
@ETM_Shaman Have you considered doing this evaluation of flow/pressure with a bone stock block with just the oil pick-up upgrade?
EndlessAzure is offline   Reply With Quote
The Following 6 Users Say Thank You to EndlessAzure For This Useful Post:
Boris_Petrov (05-24-2019), Calum (05-24-2019), Capt Spaulding (05-24-2019), Horrid_Funk (05-23-2019), Irace86.2.0 (05-23-2019), soundman98 (05-23-2019)
Old 05-23-2019, 02:57 PM   #4
Your work is brilliant. Thank you VERY much for sharing. I wish you and your shop all the best. Upstream vacuum gauge is the big winner here.
...despite using a Sprintex.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
Boris_Petrov (08-28-2019), Capt Spaulding (05-24-2019), soundman98 (05-23-2019), Tristor (05-23-2019)
Old 05-23-2019, 03:13 PM   #5
solidsnake11
Drives: brz
Great work. I have also been wondering if the oil pump plate is flexing around the oil pump and opening up the pump clearances causing lower pressure . Most oil pumps have a steel backing plate or they bolt to the block or both. Another thing I have been thinking about is the expansion of aluminum compared to the steel oil pump gear.
What is your oil tempature? I have 83lbs at 7500, tempature 200f. That is with vr1 20w 50 conventional oil. Have not tried redline yet. Was also thinking of using BMWs fix for spun bearings 10w 60 tws. Great work and thanks so much for sharing.
solidsnake11 is offline   Reply With Quote
Old 05-23-2019, 04:35 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
IIRC oiling problems at high rpms are one of main limiters to upping redline on FA20. I wonder, how fast otherwise stock FA20 might be spun if oiling is enhanced. Highly doubt that to S2000 Mk1 levels .. but i can dream, no?
Calum (05-24-2019), soundman98 (05-23-2019)
Old 05-23-2019, 05:40 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Interesting you installed spacer shims on the oil temp sensor. I have suspected that running my oil pressure sending unit there is giving me false cavitation readings from poking too far into the galley.
Old 05-23-2019, 07:06 PM   #8
Horrid_Funk
Horrid_Funk's Avatar
Drives: 2017 DGM BRZ PP
This is awesome work, thanks for sharing. I'm wondering how much of an improvement one can get from doing the two least invasive things here even on a stock engine? Relocate or shim the temp sensor and replace the oil pickup. With how big of a difference the oil pickup made on your inlet pressures, I imagine that it should still make a significant difference without removing the other restrictive areas.
Seems like a no-brainer to me for how easy those mods are.
Horrid_Funk is offline   Reply With Quote
The Following User Says Thank You to Horrid_Funk For This Useful Post:
racingfool (11-13-2020)
Old 05-23-2019, 07:52 PM   #9
ETM_Shaman
ETM_Shaman's Avatar
It would be very interesting but it's fairly involved because you have to remove the timing cover to tap it properly. Then do the test with stock oil pickup and then remove the pan, change the pickup and do the tests again. I'd love to see these results but wouldn't be willing to do all that work on my account to tell you the truth.
The Following 3 Users Say Thank You to ETM_Shaman For This Useful Post:
Calum (05-24-2019), EndlessAzure (05-24-2019), Ultramaroon (05-23-2019)
Old 05-23-2019, 08:06 PM   #10
ETM_Shaman
ETM_Shaman's Avatar
Thanks! Your thread was what made me really look into cavitation.
I have a JDL oil cooler and use Motul 300V 10W40. For the first 100km or so I used 15W50 mineral oil for break in and got higher pressures overall.
When driving slowly my oil temp is around 90 deg C (I get 0.6 bar at idle) When I drive it hard it can get to 110 deg C (aprox 0.4 bar idle pressure, 4.0 bar at redline). At first I was a little scared because of the low pressures but after having oil starvation engine failures with higher pressures than that I'm learning to live with it. Just look at the guys with stock engines and less than 3.0 bar oil pressures at redline while tracking with perfect UOAs after every oil change (there's a couple of good threads).
I still have a last test which is taking the car to the track (I used to track my car monthly before doing the rebuild). I'm curious of how hot my oil and how low my oil pressure will get
Old 05-23-2019, 08:16 PM   #11
ETM_Shaman
ETM_Shaman's Avatar
Yes and I think this also applies to the FA20DIT. A bigger 14mm pump with the same restrictive oil galleries, oil pickup and more power looks very bad for me.
The thing with just spinning it faster is that you're not producing good torque high in the RPMs. This COMPLETELY changes with head work (already done) and a good set of camshafts (one of my planned improvements). We'll have to wait for enough people to build their engines with this mods and explore to start seeing if our engine ends up being a nice high RPM screamer (n/a or boosted) like we all want to see
Old 05-23-2019, 08:27 PM   #12
ETM_Shaman
ETM_Shaman's Avatar
The problem is the stock oil temp sensor has a thick part that ends up blocking the gallery a lot without shims.
solidsnake11's post illustrates this very well:
Old 05-23-2019, 08:33 PM   #13
ETM_Shaman
ETM_Shaman's Avatar
Absolutely! Probably almost all of the improvement coming from the oil pickup but still worth it to do both.
Someone that has a stock engine with an oil pressure gauge installed, that tracks the car and is already familiar with how his oil pressure behaves should try this and report his findings!
Old 05-23-2019, 08:52 PM   #14
Great piece of applied research! -
FA20 Engine Oiling, Bearings, and Starvation Element Tuning Engine, Exhaust, Transmission 784 04-20-2024 04:25 AM
VVT Problems: 100$ reward for a solution!! Exhaust targets all 0, intakes no response bren5279 Forced Induction 12 03-14-2017 07:34 AM
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-04-2016 11:18 PM
An alternate solution to Drone problems 86-tundra Engine, Exhaust, Transmission 1 09-26-2013 02:50 AM
Question about oiling filters showbe Engine, Exhaust, Transmission 7 10-25-2012 09:50 PM
