Old 04-21-2019, 09:48 PM   #1
YgRoshi
YgRoshi's Avatar
Drives: 2017 86 MT BASE
Rattling noise coming from car?
Just changed out entire exhaust system yesterday (Header, Overpipe, Frontpipe, Muffler) and there is some sort of rattling? noise coming from the front of the car whenever I am around 2.3 - 3k RPM. No lights are on, no funny smells, or exhaust leaks after I went back under the car today, even took off the pans and retightened every screw that I tampered with, anyone have any idea what is going on? or do I just desperately need a tune?
YgRoshi is offline   Reply With Quote
Old 04-21-2019, 09:57 PM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
The header will make the engine sound noisier, and these motors tend to clatter a bit around 3k. If it's actually rattling it's most likely where the overpipe gets close to the subframe, I'd check there first.
Old 04-21-2019, 10:00 PM   #3
Impureclient
Drives: 2015 FR-S
Probably posting a video would help out a lot.
Old 04-21-2019, 10:03 PM   #4
Yep. I'd also guess some piece of your exhaust system is hitting something else. I'd suggest that you figure which way the engine twists (torques) over under acceleration and see which exhaust piece is coming close to something else.
Bubba says, once you find the piece, just pry it over with a crowbar and use baling wire to wire it away from that piece.
humfrz & Bubba
Old 04-21-2019, 11:21 PM   #5
YgRoshi
YgRoshi's Avatar
I see, thanks a lot fellas!
Old 04-22-2019, 08:23 AM   #6
gravitylover
Mine has an awesome heat shield rattle right at 4k, not 3850 and not 4200. My solution has been to accelerate past that point as quickly as possible so it doesn't bother me for more than a second at a time.
Old 04-22-2019, 08:54 AM   #7
I had that as well but just hit and pried on random shields until it stopped.
gravitylover (04-23-2019)
Old 04-22-2019, 10:50 AM   #8
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Check the clearance on the Over Pipe.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 04-22-2019, 06:32 PM   #9
Fast13FRS
Fast13FRS's Avatar
Drives: 2013 Scion FRS
Yup mine has a complete HKS header, pipe and exhaust and has a rattle at idle through about 2500 RPMs. the car is so low to the ground with the splitter and wide body kit I cannot see under it. cannot wait till my 4 post lift gets installed next week.
Fast13FRS is offline   Reply With Quote
Rattling sound coming from Brake booster and Master Cylinder darkslide18 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-10-2019 01:22 AM
Ticking/Rattling coming from steering column/gauge cluster Imprezzave Issues | Warranty | Recalls / TSB 24 09-17-2016 09:38 AM
Rattling noise Eighty 6 Scion FR-S / Toyota 86 GT86 General Forum 4 06-07-2016 11:54 AM
Rattling noise coming from both doors, not speakers kev60625 Issues | Warranty | Recalls / TSB 21 05-16-2016 08:52 PM
Weird rattling noise in cabin coming from front left Webster10 Scion FR-S / Toyota 86 GT86 General Forum 36 03-01-2016 04:44 PM
