Old 04-10-2019, 02:29 PM   #1
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Eek! Oil leak
I found a small puddle of oil on the garage floor today. This is what I found when I dropped the pan. Driver side.) I guess I didn't get a pic after I cleaned it up, but everything looked pretty normal. I'll watch it for a week or so, but I don't expect it to fix itself. Anyone have an idea how much trouble I'm in? Warranty expired three weeks ago!
Qwimby1 is offline   Reply With Quote
The Following User Says Thank You to Qwimby1 For This Useful Post:
humfrz (04-10-2019)
Old 04-10-2019, 02:32 PM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Probably just the front timing cover leaking. Fairly common issue. But I'm not sure how much the fix is.
Sent from my SM-G930V using Tapatalk
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
Qwimby1 (04-10-2019)
Old 04-10-2019, 02:50 PM   #3
Qwimby1
You may have just made my day!
Old 04-10-2019, 02:57 PM   #4
BigTuna
BigTuna's Avatar
Mine had the same leak before I took it on for the recall. Upon reassembly, they reseal it and I haven't had it leak since. It had been happening for maybe 6 months, however, I never saw any measurable oil loss. Maybe just keep an eye on it, check the oil level every once in a while and monitor if it changes.
Old 04-10-2019, 03:03 PM   #5
Not that common an issue on a post 13 but depends on when your 14 was built I guess.
Here are the common leaks and how to fix them.
http://www.ft86club.com/forums/attac...1&d=1413834741
BigTuna (04-10-2019), Qwimby1 (04-10-2019)
Old 04-10-2019, 03:50 PM   #6
Qwimby1
Very helpful. Thank you. Build date 1-14..
Old 04-10-2019, 04:04 PM   #7
Well you don't get much earlier a 14 than that.
Old 04-10-2019, 04:46 PM   #8
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I noticed recently mine has a little on the driver side.
MS, CSCS, TSAC-F, CPT
Old 04-10-2019, 09:27 PM   #9
Oh, just put a pan under the car on the garage floor and add oil to the crankcase every now and then.
Well, it's what some of us used to do -
Old 04-11-2019, 11:03 AM   #10
Qwimby1
My wrench tells me it could take 8-9 hours to fix! Seems like an awful lot. It's a job I couldn't take on.
The Following 2 Users Say Thank You to Qwimby1 For This Useful Post:
humfrz (04-11-2019), Sleepless (04-11-2019)
Old 04-11-2019, 11:10 AM   #11
weederr33
weederr33's Avatar
What about cleaning the site, and applying some high temp RTV sealant over it?
The Following User Says Thank You to weederr33 For This Useful Post:
humfrz (04-11-2019)
Old 04-11-2019, 12:46 PM   #12
BigTuna
BigTuna's Avatar
https://www.ft86club.com/forums/show...5&postcount=24
weederr33 (04-11-2019)
Old 04-11-2019, 03:40 PM   #13
Qwimby1
Looks like a good way to go. I'll try it.
Gas Leak? Fuco Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 10-07-2022 09:40 AM
Oil leak help please TorontoNat Engine, Exhaust, Transmission 1 12-26-2018 01:36 PM
Oil Leak? Tofu-86 Forced Induction 3 09-23-2016 03:47 AM
Yet another oil leak.... Astroboy Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 09-24-2015 01:02 AM
Oil leak. ohnoitsthefuzz Issues | Warranty | Recalls / TSB 2 03-23-2015 01:31 AM
