Old 04-02-2019, 01:58 AM   #1
Turbo
Drives: FR-S Turbo
Has anyone tracked on 'plasti-dip' coated wheels?
I'm curious how this coating stands up to the heat and rigors of the track?
Anyone have experience running this stuff on track? I have a set of rims to freshen up and this would be easier than de-mounting the tires and powder coating them.
Might also be nice to have a protective coating on there to deal with the brake dust......
Turbo is offline   Reply With Quote
Old 04-02-2019, 02:54 AM   #2
FirstWinter
Drives: Car
Holds up fine.
FirstWinter is offline   Reply With Quote
The Following User Says Thank You to FirstWinter For This Useful Post:
Turbo (04-02-2019)
Old 04-02-2019, 07:10 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
If you are worried about brake dust.....
Maybe you shouldn't be on a race track.
Maybe you should park hard bro!
You know like those car circle jerk parties all over instagram.
Old 04-02-2019, 08:47 AM   #4
15limited
15limited's Avatar
You cant even compare professional sandblasting/powder coating compared to driveway plastidip, no matter how much easier it is. Gotta pay to play or look just like the others.
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
The Following User Says Thank You to 15limited For This Useful Post:
Pat (04-02-2019)
Old 04-02-2019, 09:19 AM   #5
ka-t_240
My personal car, no.
I have tracked a friends Evo-X with purple plastidipped wheels. They were sprayed out of a paint gun vs spray cans if that makes any difference. They have held up ok, but after 2 years they have lost their "look" as the brake dust is pretty embedded. Didn't seem to be much of an issue with heat, but I never took the car out for a full session ever.
ka-t_240 is offline   Reply With Quote
Old 04-02-2019, 10:03 AM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Rocks will tear this coating off pretty quickly. If rocks aren't an issue, I don't see why it wouldn't stay on. plastidip does not clean well in my experience,so be aware that while you may delay damage from corrosive dust, they're always going to look a bit... bleh. Honestly, for the cost to benefit, powdercoating is amazing. And it washes nicely.
Old 04-02-2019, 10:09 AM   #7
ka-t_240
I have a hard time when Powder Coat and wheels. Almost every wheel I've seen fail(that is not from something like hitting an object) both on and off the track has been powder coated. Maybe its a coincidence.
The Following User Says Thank You to ka-t_240 For This Useful Post:
Turbo (04-02-2019)
Old 04-02-2019, 10:37 AM   #8
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
There is a spray on product you can use to help protect the coating from being stained by brake dust. It holds up under heat just fine. There is a similar product called flexidip. It sprays on thinner but also lays down flatter with less of a textured finish.
It won't have the up close finish of powder coating, but it's a nice way to change the look and protect the original finish. One can per wheel should give you a thick coating.
I have always coated my winter steelies black. A four year old pair of wheels looked brand new when I sold my SX4 after peeling off the dip.
The Following User Says Thank You to RToyo86 For This Useful Post:
Turbo (04-02-2019)
Old 04-02-2019, 11:24 AM   #9
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
no heat issues. Spraying it on thick and on a clean wheel surface are key.
Turbo (04-02-2019)
Old 04-02-2019, 12:09 PM   #10
15limited
15limited's Avatar
How many wheels have you seen fail? What brand of wheels? I'll believe it, if you told me you had proof lower quality flow formed wheels and the electromagnetic process of powdercoating weakened them, but all you just said powdercoated wheels are weaker...
Old 04-02-2019, 12:36 PM   #11
CSG Mike
CSG Mike's Avatar
I will clarify his post with aftermarket powdercoats.
ka-t_240 (04-02-2019), Turbo (04-02-2019)
Old 04-02-2019, 01:04 PM   #12
steverife
Drives: 2016 Scion FRS
Back in the day, Steeda made a wheel for NASA's American Iron series. Might have been a spec wheel. They came in silver or powdercoated. There were lots failures and they were almost exclusively the powdercoated ones. Given how you have to heat a wheel and what heat can do to compromise strength, it doesn't seem like an unreasonable concern.
Regarding plastidip? If they mess up or look bad after some time, just re-do them. Isn't that the point?
steverife is offline   Reply With Quote
The Following 3 Users Say Thank You to steverife For This Useful Post:
CSG Mike (04-02-2019), dowroa (04-03-2019), Turbo (04-02-2019)
Old 04-02-2019, 01:15 PM   #13
Pat
Pat's Avatar
Drives: 2023 BRZ
There is a range of temperatures used to powdercoat things. Some super hot; some not so hot. The lower temperatures aren't far off what a wheel might see at a race track. I wouldn't use your example to say ALL wheel powdercoating will increase the likeliness of failures.
The Following User Says Thank You to Pat For This Useful Post:
15limited (04-02-2019)
Old 04-02-2019, 01:21 PM   #14
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Agree with this, half the point of plastidip is you peel it off and redo it if it looks like shit, probably once a year if you really care about what it looks like.
Lots of good brake pads have dust that just wipes right off, if you haven't been to the track yet just go and don't defer to 'protect your wheels' they'll be fine.
ineedyourdiddly
Turbo (04-02-2019)
Plasti-Dipped Wheels hobojoker Cosmetic Modification (Interior/Exterior/Lighting) 274 07-24-2015 10:02 AM
Plasti Dipped Gold Wheels Khalis FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 72 07-10-2014 12:37 PM
How to Plasti Dip Wheels! (Video) Teeeg28 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 07-07-2014 05:51 PM
Plasti-dip wheels (Anthracite) jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 6 08-30-2013 05:44 PM
plasti dip wheels and the track? subaruferrucci Tracking / Autocross / HPDE / Drifting 17 05-17-2013 01:36 AM
