Old 02-10-2019, 06:28 PM   #1
Aphaux
Aphaux's Avatar
Drives: Silver 2013 BRZ
Engine Block Damage (Minor) Repairable?
It's all in the title.
The oil passage entrance is a bit marred to say the least. I am betting I can rebuild the entrance with some good ole JB weld. But it must be precise.
This is my plan, haven't done it yet but I am going to give it a shot. But as always I want to reach out to other folks to get a different perspective and possibly uncover some information I didn't know before.
Mine is broke, the other is not.
https://drive.google.com/file/d/12Vx...ew?usp=sharing
https://drive.google.com/file/d/1LHB...ew?usp=sharing
I hope these images show up, been having trouble with that.
Thank you.
Aphaux is offline   Reply With Quote
Old 02-10-2019, 06:50 PM   #2
I'm not getting the context of those pictures. there's no coolant routed through the timing cover.
Aphaux (02-10-2019), Tcoat (02-10-2019)
Old 02-11-2019, 12:35 AM   #3
I'm not seeing the direct comparison in the two pictures. -
However, your JB Weld idea might be worth a try.
Old 02-11-2019, 12:45 AM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The picture looks odd because the case half is split. The center passage with the oring is what OP is talking about.
If you have the case half split apart already it may be worth taking it in to have it welded, then trying to grind it back out to the original shape. I don't like the idea of JB welding anything aluminum that sees a lot of differential heating/cooling.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Aphaux (02-13-2019), Ultramaroon (02-11-2019)
Old 02-11-2019, 01:34 AM   #5
Oh, that's the input to the main oil gallery. I agree with NoHaveMSG. Definitely not a place to fool around. If you want to save the block, get it built back up and rebored/resurfaced.
Was there other damage to the block? Better make sure. Look especially where the impact against the thrust bearings would be dissipated.
Aphaux (02-13-2019)
Old 02-13-2019, 01:17 AM   #6
Aphaux
Aphaux's Avatar
Yes indeed sir.
This being my first encounter with engine block repair I wasn't sure how to approach it. Whether to trust ole JB or if there was hope for a weld-n-grind fix. I do have a replacement engine so no sweat there.
Old 02-13-2019, 01:20 AM   #7
Aphaux
Aphaux's Avatar
I have been going over the block inch by inch since stripping it. Thankfully I have not located any further damage on this or the other half..yet.
Greatly appreciate the assistance from ya'll ^.^
Old 02-13-2019, 12:59 PM   #8
Good luck with it. Keep us posted.
BTW, if you're in the Portland metro area, I'm right across the river. I know a guy who knows a guy...
Old 02-13-2019, 01:23 PM   #9
ermax
ermax's Avatar
[IMG]
[/IMG]
Thank you.
Your embedded images do not work because you wrapped both links in one block. To fix it wrap them individually with [img][/img].
The Following User Says Thank You to ermax For This Useful Post:
Aphaux (03-15-2019)
Can you tell year if an engine by the engine block number? guybo Engine, Exhaust, Transmission 18 07-22-2018 10:53 AM
Minor damage from flying debris SisterBlue22 Scion FR-S / Toyota 86 GT86 General Forum 29 09-11-2015 01:44 AM
Need advice on minor damage to FR-S trim babydriver Scion FR-S / Toyota 86 GT86 General Forum 14 10-30-2014 05:17 PM
Preventing rust on minor body damage GMU-BRZ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 04-12-2014 01:41 AM
Minor paint damage Double4Free Great Lakes 8 07-23-2012 07:35 PM
