Old 12-07-2018, 04:47 AM   #1
gt7877
Drives: turbo frs
how to tune 2step ecuTek
Dear
I have turbo frs tuned buy ecuTek
How can I tune 2step ??
Thank
Also can I tune NA frs OFT maps to work with 2step ??
I use for NA cars tactrix cable and romrider and ecuflash
Thnx alot
gt7877 is offline   Reply With Quote
Old 12-07-2018, 06:24 AM   #2
steve99
Drives: FT86
Originally Posted by gt7877 View Post
Dear
Thank
Thnx alot
With ecutek 2 step is called launch control
You need to go to racerom features and enable it , it will then work with the default parameters
If necessary you can finectune a few parameters if needed
See ecutek manual below page 9
https://ecutek.zendesk.com/hc/en-gb/...eatures-Manual
With oft maps the launch control is a very simple setup it jist ajist an extra rev limiter active whan vehicle stationery..
You jist set one parameter launch rpm delts which is redline rpm - delta = lainch rpm
Old 12-07-2018, 03:49 PM   #3
gt7877
Drives: turbo frs
Thnx Steve
Can u show me how I can do that with oft ROMs??
Snapshot ..
Old 12-07-2018, 03:50 PM   #4
gt7877
Drives: turbo frs
Also can at 2step be some flams or backfire ??
Old 12-07-2018, 06:01 PM   #5
steve99
Drives: FT86
Very difficult to get any flames and pops with brz\86 as this ecu uses fuel cut to limit rpm not ignition cut,
With oft you jist need oft roms and oft romraider defs amd you alter the launch control parameter only one parameter in oft roms
gt7877 (12-07-2018)
Old 12-07-2018, 10:01 PM   #6
gt7877
Drives: turbo frs
Could you please show me please at romraider how to do this?
Old 12-08-2018, 04:49 AM   #7
steve99
Drives: FT86
http://www.ft86club.com/forums/showthread.php?t=79152
gt7877 (12-10-2018)
Ecutek Tune? Jadrien86 Software Tuning 7 10-29-2016 04:41 PM
Ecutek Tune tyler_win_photo Software Tuning 2 10-26-2016 05:37 AM
ECUTek E85 TUNE !! c1m8y11 Engine, Exhaust, Transmission 2 07-10-2014 03:06 PM
EcuTek Tune SalM Software Tuning 20 01-30-2014 10:09 PM
