Old 08-29-2012, 02:01 PM   #1
APS86
Drives: GTS86 Manual
TRD bumper garnish fitting instructions in English
Hi all,
does anyone know where you can find TRD part instructions on the net in English and in particular for the bumper garnish fitment. I have found the instructions on the Japanese TRD part site in japanese but cannot find instructions anywhere in English. have even tried to download the document and use google translate which gives some pretty funny results but not much help.
thanks in advance
APS86 is offline   Reply With Quote
Old 08-29-2012, 04:00 PM   #2
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
Post em, and I'll translate em.
ZC6BRZ is offline   Reply With Quote
The Following User Says Thank You to ZC6BRZ For This Useful Post:
Trust86 (11-15-2018)
Old 08-29-2012, 09:00 PM   #3
APS86
That would be cool..... thanks for that.....
the link for the Bumper garnish instructions is:
http://www.trdparts.jp/manual_pdf/86/MS343-18003.pdf
all their instructions are at:
http://www.trdparts.jp/manual_download.html
it is a pity that they don't provide english instructions!!!! and I cannot find a link in English on their website to be able to email them and ask if they can provide
here is the PDF of the garnish manual attached:
Old 08-30-2012, 03:33 PM   #4
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Pg 3/6
1. Remove Rear Bumper
2. Cut out pattern #7, mark from the inside where you'll cut for the bumper and drill the hole for the bandclamp. Do not discard pattern #7 as you'll use it for the other side too. Refer to picture 1.
3. Drill a 3mm hole in the spot marked in step 2. Refer to picture 2.
4. Enlarge the hole to 7mm, clean the shavings off the hole. Refer to picture 2.
5. Cut the rear bumper using a tool like an airsaw. Refer to picture 3.
6. Install bandclamp in the hole you just drilled. Refer to picture 3.
7. Flip the harness clip and route the harness over where the muffler will be. Refer to picture 4.
8. Make sure there is no slack in the harness.
9. Reattach bumper.
10. Mark the bottom of the rear bumper. Refer to picture 5.
11. Drill a 4mm hole, using masking tape as a stopper (so you don't drill too far) and clean the hole. Refer to picture 6.
12. put the muffler garnish 2 on the bumper, and mount using push rivet 3 and clip 4 on both sides. Use tape to adjust the mounting temporarily. Refer to picture 7.
Do this on both sides.
1. Use masking tape to mark where the muffler garnish will attach. Remove garnish. Refer to picture 8.
2. Clean the garnish with either IPA or white gasoline (Rubbing Alcohol?) Paint PAC Primer K-500 (6) on the insides of the area you masked off previously. Refer to picture 8.
3. Mount double sided tape on the back of the muffler garnish. Tape masking tape onto the front of the double sided tape. Refer to picture 9.
4. Reattach the muffler garnish (2) onto the rear bumper, and mount using push rivet and clip. Refer to picture 10.
5. Peel the double sided tape off using the masking tape tabs you made on 3. follow the order. use at least 49n(5kgf) of pressure. Refer to picture 11.
Make sure everything is clipped and not damaged. Don't wash the car for 24 hours. If it's colder than 15C, use a heatgun to heat the double sided tape to about 40C.
The Following 12 Users Say Thank You to ZC6BRZ For This Useful Post:
asdf (02-27-2016), Brink (11-16-2018), DCdesign2000 (06-19-2015), DHitHim (04-23-2015), dphan (04-28-2013), DrunkMonkey45 (10-18-2014), GaN-MaN (02-14-2013), KiK (10-03-2023), mokinbird87 (08-19-2014), peachch (12-09-2013), Trust86 (11-15-2018), Vic4uf (11-17-2018)
Old 08-30-2012, 10:27 PM   #5
APS86
Huge thanks .... would press the thanks button but I dont seem to have one!!!!!
Old 08-30-2012, 11:43 PM   #6
gmookher
not a pretty install , huh
Old 11-14-2018, 03:11 PM   #7
VR4Jr
Drives: 2015 BRZ Limited
I hate to revive a dead post, but would you mind translating the instructions for the full bumper installation? I purchased one through japanparts.com and it's in great shape, but the instructions are all in Japanese as it's the TRD Japan bumper.
The instructions are located here: http://www.trdparts.jp/manual_pdf/86...8001_18002.pdf
VR4Jr is offline   Reply With Quote
Old 11-15-2018, 10:02 PM   #8
Trust86
Drives: 2016 Halo FRS
Fucking legend
Trust86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Trust86 For This Useful Post:
DaBoBo21 (11-16-2018), Leonardo (11-15-2018)
Old 11-16-2018, 08:57 AM   #9
Vin
Vin's Avatar
Drives: 2012 GT86 EU-spec
Here you go, manual in English :
https://www.google.nl/url?sa=t&sourc...W2Yme0u5mgWftC
Vin is offline   Reply With Quote
Old 11-16-2018, 11:29 AM   #10
VR4Jr
Originally Posted by Vin View Post
You are the man. Thank you!
The Following User Says Thank You to VR4Jr For This Useful Post:
Vin (11-16-2018)
Trading BRZ bumper for FRS bumper WHITE just86 Exterior Parts (Aero, Lighting, Etc.) 7 12-09-2012 02:08 PM
Chrome Fuel Door Garnish switchlanez Cosmetic Modification (Interior/Exterior/Lighting) 6 07-28-2012 09:06 AM
Instructions for dash disassembly whataboutbob Cosmetic Modification (Interior/Exterior/Lighting) 3 07-01-2012 07:03 PM
fitting 17x9's with 255s, and fitting brake pads Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-29-2012 11:08 AM
