Old 08-14-2018, 11:45 PM   #1
stig_iv
stig_iv's Avatar
Drives: N/A
OFT Pops and Crackle Tune just stops working after a while?
Not really sure what's going on here, but I have the V1 OFT with the Stage 1 tune on it and have retarded the valve timings at the lowest settings as well as changing the fuel cut threshold to 6000 and get pops and crackles with my car (used the mod linked here: http://www.ft86club.com/forums/showthread.php?t=61069). It works great for about the first few days, but then all of a sudden it just sort of...stops? Usually around 3,800 to 4,200 RPM is where I can get those nice pops, in rapid succession too. For some reason, after a few days, I'll be in the exact same place (there's this one hill close to where I live with like a 10 degree decline that is PERFECT for a super long ride down the RPM range, crackling and popping the whole way) giving it the exact same amount of throttle, and it just barely makes any noise? After running with this tune for almost 2k miles now I know how to trigger it almost on command, so I'm assuming it's not user error with the throttle. The only way I've found to fix it is to reflash the tune, then it goes back to popping every time I tip the throttle. It's almost as if the tune is learning over time. Any ideas?
stig_iv is offline   Reply With Quote
Old 08-14-2018, 11:59 PM   #2
steve99
Drives: FT86
sounds strange, all you need to alter is ignition timing base B table.
been doing those tunes for years no problems
see if your ltft goes way positive at idle if so you might have exhaust leak or intake leak
Old 08-15-2018, 12:18 AM   #3
stig_iv
stig_iv's Avatar
Drives: N/A
I’ll give it a try. Will update you tomorrow (it’s nighttime here and don’t want to wake the whole neighborhood lol)
And what numbers should stick out when I’m looking?
Old 08-15-2018, 04:59 AM   #4
steve99
Drives: FT86
ltft should be below 10%
Old 08-16-2018, 12:46 PM   #5
stig_iv
stig_iv's Avatar
Drives: N/A
Yup, LTFT is below -7%. Seems to be intermittent enough that I can't put my finger on what I even think it could be. Any other ideas?
Old 08-16-2018, 01:51 PM   #6
steve99
Drives: FT86
have you only got ignition retard in lowers load column ?
if so try putting some retard in second column as well
start retard in first load column at say 2400 rpm and second column 3000 rpm
Old 08-16-2018, 01:58 PM   #7
stig_iv
stig_iv's Avatar
Drives: N/A
Yup, have the timings retarded to -9.6 (or whatever the rounded 10 value was) from ~2000 to ~5000. Should I be going for a triangular pattern to the right of the map for this? Like a ">" shape almost? Or stop at the second column?
P.S. I understand the basics of retarding the ignition timing, but my novice mind would think that retarding the second column as well would cause almost like an overflow scenario? Where like there's simply too much fuel? Not really sure, I'm learning as I go here haha. Thanks for oyur help so far btw man!
Old 08-16-2018, 03:47 PM   #8
steve99
Drives: FT86
stop at second column
put -6 in second column from 3000-5000
Old 08-19-2018, 08:59 AM   #9
gt7877
Drives: turbo frs
DEAR steve99
thnx alot for your help
but can u show me a screen shot what row i have to change
thnx
gt7877 is offline   Reply With Quote
Old 08-19-2018, 05:03 PM   #10
steve99
Drives: FT86
Originally Posted by gt7877 View Post
DEAR steve99
thnx
just one table Base timing B
similar to below
don't go all the way down to 800 rpm stop at 2400
you can make it simple and put -9 in 0.15 load column 2400 and above
then -6 in the 0.2 load column from say 3200 and above
Old 08-20-2018, 05:20 PM   #11
gt7877
Drives: turbo frs
thnx steve
but this would work with stock exhaust??
this is cal id ZA1JA01J
i try to use oft stage 1 map but car not runing good at all
i re flash stock romdownload it from your http://www.ft86club.com/forums/showthread.php?t=62332
thnx
Old 08-21-2018, 12:59 PM   #12
stig_iv
stig_iv's Avatar
Drives: N/A
Reflashed the tune and those sweet sweet pops and burbles are back to normal. Maybe it was just something wrong with the flash? Not sure, will come back and try what you said if it happens again. Thanks for the help and advice man!
Old 08-21-2018, 05:30 PM   #13
steve99
Drives: FT86
thnx steve
thnx
Pop wont work on stock exhaust, you need catless header and a catback for them to eork.
Car should drive fine, just stock exhaust too quiet for pops
If you flash stock map or oft tunes you need to have stock injectors and map sensors and preferably stock intakes
bangs, oft, popcorn, pops
E85 Overrun Pops & Fire on NA erebuswarrior Software Tuning 33 02-25-2023 07:32 PM
OFT Backfire/Pops help DaveyBonesJones Southern California 8 08-27-2018 11:53 AM
Question about crackle and pop.. Qc86 Engine, Exhaust, Transmission 10 12-03-2017 01:49 PM
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 04:39 AM
Exhaust crackle and pop? Kiwi Engine, Exhaust, Transmission 19 03-22-2013 03:14 PM
