| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Wheels for Brains
[Resolved] Wheel shop overbored lug nut holes. Potential issues?
Hey all,
Recently, I took my wheels to a repair shop to get my lug nut hole faces/tapers resurfaced to smooth (60 deg taper). However, when I got my wheels back, I noticed they also bored out the holes from M12 to M15 (in addition to the requested countersink). I didn't ask for a bore-out, so I'm going to ask the shop for refund/repair/replace. In the event they hose me over or my options are limited, do you see any causes for concern with using as-is?
------ **EDIT** Thanks all, I've looked around and notice wheels from other makes sometimes have M15 holes on wheels for the 86. I talked to the shop and they agreed to refund me. Based on some calculations and fit checks, it looks like I'll be able to use my lug nuts just fine so I won't pursue much further Last edited by EndlessAzure; 07-30-2018 at 06:31 AM. Reason: Conclusion |
#2 |
[insert cool phrase here]
Drives: BRZ Premium
Well, that's new. Haven't heard that one.
Guess the quick way to make them work properly is to get bigger/wider lug nuts. You can do a quick check to see how much contact your current nuts hold the wheel. Get a marker and give it a good paint over on the nuts tapper. While it's still fresh quickly drop it into the wheel and give it a wiggle. If it made contact with over 50% of the tapper it ok. Less, well it's your call.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#3 |
Drives: Crapcan
Make them fix or replace them. That's pretty inexcusable on their part.
#4 |
Are you sure they were actually bored bigger? Even my factory wheels fit loose on the studs until the lugs are tightened down.
#5 | |
Were the wheels bored out using a CNC lathe or Mill? Either way it's completely wrong, and they should replace them
#6 | |
Wheels for Brains
Yes they're bigger. My stock wheels and my other set of aftermarket wheels have a bore sized at 13mm. My friend also has the same wheels, and the bore is the same. CNC |
#7 |
TRACKBREAD
It may not be a problem. The aftermarket wheels on my BMW fit both the M12 and M14 lug bolts BMW uses.
As suggested above, check the % engagement with the lug seats, go from there. |
#8 |
Shit that's a really dumb mistake then, easy g code edit and what not. Honestly they'd have to add material back by welding and that sounds sketchy or weld in a cylinder of some type in and remill that. They should pay the value of the wheels because of their mistake...
#9 |
Drives: 2017 BRZ
I'd expect the shop to replace the wheels with a new set and refund whatever you paid them for the work that was done (assuming they made you pay already).
#10 |
Wheels for Brains
Thanks all,
I've looked around and notice wheels from other makes sometimes have M15 holes on wheels for the 86. I talked to the shop and they agreed to refund me. Based on some calculations and fit checks, it looks like I'll be able to use my lug nuts just fine so I won't pursue much further |
| The Following User Says Thank You to EndlessAzure For This Useful Post: | wparsons (07-30-2018) |
#11 | |
I've never measured my stock wheels, but there's way more than 1mm of space around the lugs.
#12 |
Drives: FR-S Turbo
Lug-centric wheels? Is that even a thing?
#13 | |
Wheels for Brains
Yeah. From what I recall when I put a caliper to the stock wheels, they're pretty close to 13mm. I can post a picture later today. Yes. Among the top search hits on Google: https://www.americastire.com/learn/h...vs-lug-centric And among a myriad of discussion on whether or not you need a hubcentric ring: http://www.ft86club.com/forums/showthread.php?t=128460 http://www.ft86club.com/forums/showthread.php?t=23877 http://www.ft86club.com/forums/showthread.php?t=29670 http://www.ft86club.com/forums/showthread.php?t=74143 |
#14 |
Wheels for Brains
| Tags |
| bore, drill, lug nuts, lugs, wheels |
| Wheel stud/lug nuts issues: need recommendations | TMF | Tracking / Autocross / HPDE / Drifting | 65 | 06-26-2019 09:39 PM |
| Hit a bump - any potential issues? (Pic incl.) | 1Cor10:23 | Scion FR-S / Toyota 86 GT86 General Forum | 68 | 05-20-2016 12:54 AM |
| Recommended OC/LA shop to paint trunk spoiler and fill in trunk holes? | tracerit | Southern California | 13 | 04-20-2016 12:39 PM |
| Body Shop issues, need advice. | Inextirpable | CANADA | 14 | 08-15-2013 12:00 PM |
