Old 07-17-2018, 07:38 PM   #1
Laz84
Drives: 2014 BRZ, 1991 Prelude Si 4WS
Dealer fuel filter replacement costs?
Does anyone know the ballpark pricing to have this service performed? Im at the Replace interval in the book.
Laz84 is offline   Reply With Quote
Old 07-17-2018, 08:26 PM   #2
norcalpb
norcalpb's Avatar
IIRC the fuel filter is inside the fuel pump and does not need to be changed.
The Following User Says Thank You to norcalpb For This Useful Post:
Opie (05-26-2020)
Old 07-17-2018, 09:03 PM   #3
Laz84
My owners manual says replace at 75k.
But it also says “clutch operation” at 75k as well?
What do?
Old 07-26-2018, 03:04 AM   #4
Brz_racer
Drives: Subaru BRZ
Neither need to be replaced until they start showing signs of problems, regardless of mileage. The owners manual is based on tests the manufacturer has done on the car and doesnt accurately represent real world driving.
Brz_racer is offline   Reply With Quote
The Following User Says Thank You to Brz_racer For This Useful Post:
Busybee (05-28-2020)
Old 07-26-2018, 03:31 AM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Although this may be the case for the fuel filter, some of the items it should be done way sooner like transmission fluid etc. Its a decent estimate as to when to change things if not sooner. The service intervals are mostly based on life expectancy and degradation of fluids or wear at an "average" use scenario
A dealership or mechanic will definitely charge $500-$600 for that and that depends on where you go and where you live. You have to remove the rear seats access the fuel sender :
https://www.ft86club.com/forums/showthread.php?t=99041
For our cars unless you begin to have performance symptoms common to a clogged filter, it's not necessary. Modern fuels and pumps have much less issues with blockages than they used to, probably something to do with tank design quality and how the fuel is stored.
Old 07-26-2018, 05:24 AM   #6
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
You can do it yourself and save money. YouTube it.
The fuel pump looks complicated but it's like legos, a couple of smaller parts that make up the unit.
But like others said you don't need to replace it, be ok if you did but it's your wallet.
Old 05-26-2020, 06:33 PM   #7
LoXodonte
Drives: Scion FR-S 2013 White
I've seen a lot of people ask about pricing on the fuel filter topic. I too noticed the suggestion for fuel filter replacement at 75K in my manual. My 2013 FRS is at the dealer currently because I can' t get a drop of gas in it so I asked them to scope the filler neck and check the Fuel filter. They claim the neck looks good and that the fuel filter should last the life of the vehicle but would cost $213 to replace. They believe the issue is the charcoal canister, and I'm looking at 1100 for the canister, $300 for the neck (if I want that added on) and $213 for the fuel filter. I just want some consistency in this information
LoXodonte is offline   Reply With Quote
Old 05-26-2020, 08:14 PM   #8
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Charcoal canister is the likely culprit. Fuel filter should only be changed if you are serving the pump for another reason or having issue.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 06-04-2020, 03:20 AM   #9
BRZ_88
Imperator
Drives: Supercharged 2013 BRZ Limited
I got one of these DW fuel pumps as a replacement. They're pretty cheap and come with installation instructions.
ft86speedfactory.com/deatschwerks-dw300-series-fuel-pump-w-install-kit-2015-wrx-2013-ft86.html#.XtigKTpKguU
BRZ_88 is offline   Reply With Quote
Old 06-04-2020, 02:16 PM   #10
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
Check out your 8-year Federally required emission system warranty. Most of these parts should be covered. Specified major emission control components are covered for the first 8 years or 80,000 miles
tarzan_nojane is offline   Reply With Quote
DIY: Drop-in Air Filter Replacement Rabble DIY (Do-It-Yourself) Guides 68 09-01-2022 07:12 PM
non-dealer key replacement options Shanahan Scion FR-S / Toyota 86 GT86 General Forum 24 02-23-2017 03:33 PM
Air Filter Replacement Shaisters Northwest 6 05-13-2014 06:39 PM
Simple drop-in filter replacement? CaptainSlow Engine, Exhaust, Transmission 3 04-22-2013 11:41 PM
