Old 05-14-2018, 11:36 AM   #1
BRZ.DEX
Drives: 15 BRZ limited
Stock brz ride height
I installed coilovers over the weekend and I forgot to measure the wheel center to fender
I've searched and only found fender to ground measurement. Can someone help me out. Thanks
BRZ.DEX is offline   Reply With Quote
The Following User Says Thank You to BRZ.DEX For This Useful Post:
bobel (09-05-2020)
Old 05-14-2018, 11:52 AM   #2
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I believe it's 14.5" from hub center to fender in the front. Not sure about the rear, but it's probably about the same.
smg1138 is offline   Reply With Quote
Old 05-14-2018, 12:21 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
LOL, I did this with my Honda accord daily a month ago. Good luck to me finding the measurements, at least here we have enthusiasts!
Old 05-14-2018, 12:28 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
OE Tire size is 24.6" diameter
Take the fender measurements you found and -12.3" for the measurement you want.
ineedyourdiddly
wparsons (05-14-2018)
Old 05-14-2018, 03:49 PM   #5
BRZ.DEX
Thanks fellas
Old 05-14-2018, 04:19 PM   #6
gpvecchi
gpvecchi's Avatar
Took from https://www.ft86club.com/forums/showthread.php?t=8739
Need to determine how much your car has lowered?
Distance between hub center and top of fender opening
Front is 14 7/16" and rear is 14 5/8"
Old 05-14-2018, 11:39 PM   #7
n0thing
Drives: Subaru BRZ
As per the shop manual:
Front wheel arch to wheel center: 375mm (14.76")
Rear wheel arch to wheel center: 372mm (14.65")
n0thing is offline   Reply With Quote
The Following User Says Thank You to n0thing For This Useful Post:
gpvecchi (05-15-2018)
Old 05-15-2018, 02:55 PM   #8
smg1138
smg1138's Avatar
That's about 1/4" higher in the front that I thought. I may have to revisit my ride height after learning this. Do you by any chance have a link to that info?
The Following User Says Thank You to smg1138 For This Useful Post:
strat61caster (05-15-2018)
Old 05-15-2018, 10:15 PM   #9
n0thing
Drives: Subaru BRZ
here you go
The Following 3 Users Say Thank You to n0thing For This Useful Post:
smg1138 (05-16-2018), strat61caster (05-15-2018), wparsons (05-16-2018)
Old 01-10-2021, 08:37 AM   #10
Hamza
Hamza's Avatar
Drives: Widebody 86/F56 Mini Cooper S
here you go
How do you compare to the ride height with aftermarket wheels?
Hamza is offline   Reply With Quote
Old 01-10-2021, 04:08 PM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
it depends entirely on the change in specifications of your aftermarket wheels AND tires. if you did it correctly, the final circumference of the new tires/aftermarket wheels will be the same size, and therefore, all the axle centerline dimensions will still apply.
Hamza (01-12-2021)
Stock ride height numbers? xwd Tracking / Autocross / HPDE / Drifting 16 07-11-2018 12:42 PM
rocket bunny with stock ride height xcuz31 Off-Topic Lounge [WARNING: NO POLITICS] 20 10-25-2016 04:29 PM
Stock Ride Height? JimmyMac Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-10-2015 11:46 AM
BRZ vs 86 stock ride height Moe AFRICA 2 11-21-2013 08:35 AM
Stock ride height or lower? StevenDavisPhoto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 01-31-2012 10:58 AM
