Old 03-26-2018, 11:07 PM   #1
mulekr1
mulekr1's Avatar
Drives: 15' Limited BRZ
P0087 code, bad e85?
Hi around 3-4 days ago I was driving to pick someone up and earlier that day I chilled up with some really cheap e85 (1.75) and I drove the car all the way from way over full to 3/4 tank. I beat on the car all the way on the highway and then downshifted when I got off the exit and the car started bucking and limiting the rpm to 3,000. Car threw a code of p0087, and some air fuel and lean codes. The lean codes i think was from the bad gas as now I pumped all the remaining e85 lit and put two gallons of 93 and a seafoam and Techron in the tank. It’s idling much better but still limiting itself. I have very limited technical skill so any help you guys can give would be helpful.
Car has 12,000 miles and is a 2015 just for accuracy purposes
mulekr1 is offline   Reply With Quote
Old 03-27-2018, 03:32 AM   #2
classybum
classybum's Avatar
Drives: 2013 Asphalt FR-S
Are you running an e85 tune? Which one?
Sent from my SM-G920V using Tapatalk
classybum is offline   Reply With Quote
Old 03-27-2018, 05:52 AM   #3
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Need LTFT, AFR etc- do a logging run with OFT, make sure fueling info is included. I am assuming you're on an E85 tune, not FFK. If you run E85, you really need to use Torque Pro for when this happens.
This sounds to me like you may have a hardware issue, but no way of telling
P0087 is a general OBD2 diagnostic trouble code that indicates a fault within the fuel delivery system. This code is set once the ECM has detected low fuel pressure at the fuel pressure sensor.
guybo is offline   Reply With Quote
Old 03-27-2018, 06:06 AM   #4
BrQ
Drives: 13 BRZ
This is why you get a ffk instead of trying to save money.
BrQ is offline   Reply With Quote
Old 03-27-2018, 07:04 AM   #5
steve99
Drives: FT86
Rubbish
P0087 is a fuel presdure issue
https://www.obd-codes.com/p0087
The Following 2 Users Say Thank You to steve99 For This Useful Post:
guybo (03-27-2018), Teseo (03-27-2018)
Old 03-27-2018, 07:18 AM   #6
steve99
Drives: FT86
P0087
Is fuel pressure issue
On these cars only high pressure Direct injection fuel presdure is monitored
So code indicates problem with high pressure fuel pump
Its possible your low pressure fuel pump in tank is bad oryou have clogged filter and this in turn is causing fuel starvation and hence low pressure readings to high pressure pump.
Run the e85 out and flash back to petrol tune, confirm you still gave same issue on stock tune with petrol, take it back if its is still under warranty, new high presdure fuel pumps are not cheap
Only other thung would be if you have messec wuth the DI computer under Bonnett check its mounting bolts are tight
Old 03-27-2018, 10:20 AM   #7
mulekr1
mulekr1's Avatar
Don’t exactly know what a flex fuel kit would’ve done with bad e85. I’ve spent quite a bit on my car in more important places as my car is NA with pretty basic mods.
Old 03-27-2018, 10:22 AM   #8
mulekr1
mulekr1's Avatar
P0087
Car doesn’t have warranty so that’s the bad news. I truly hope it isn’t the high pressure fuel pump.
I flashed back to the 93 tune and the e85 tune both of them are idling much better but same results. I might let the car run till it dies maybe there’s some bad e85 left inside
Should I start with changing my low pressure fuel pump as it’s cheaper and I might go forced induction?
The high pressure fuel pump is expensive I have another brz that my dad owns he’s willing to give me his pump as he’s doing a 2jz swap with his car. Where exactly is it located and how hard is it to change?
Old 03-27-2018, 06:23 PM   #9
steve99
Drives: FT86
I would not start randomly changing stuff.
You need to get a proper diagnosis done and someone to measure the pressure of low pressure fuel pump.
Maybe remove low pressure fuel pump from tank and check filter is not clogged.
Old 03-27-2018, 07:11 PM   #10
mulekr1
mulekr1's Avatar
That’s the one in the back seat? I don’t exactly know how to check if it’s clogged I’ll try to figure it out though.
Old 03-27-2018, 08:41 PM   #11
guybo
Huge E85 fan!
guybo's Avatar
Thumbs down
If you play parts darts and start replacing things having no clue what the actual problem is, not only will you find the most expensive possible way to fix the issue, but you will spawn even more issues off the orig problem.
Going FI? Are you shitting me? You have a known problem in the fuel system so without knowing what it is, you're going to put even more stress on it? Most likely you have a weak fuel pump, or a restriction in the system and the extra duty caused by running E85 stressed the weakened part and you got the CEL as a warning.
1) find out what the problem is 2) fix it 3) then think about going FI
Old 03-27-2018, 10:01 PM   #12
mulekr1
mulekr1's Avatar
When I said I was thinking of going FI I should’ve been more clear. I have a kit that I already bought and I 100% intend to fix it that’s why I made this thread and so far steve99 is the only guy to help. I know I have to fix the problem, I’m asking what to target first. I’m going to switch my whole fuel pump hangar assembly with my fathers car and that would eliminate low flow fuel pump and a clogged fuel filter from bad e85
Old 03-28-2018, 01:24 AM   #13
Cal3000
Drives: Panda FR-S
Are you running stock fuel pump?
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 03-28-2018, 06:10 AM   #14
mulekr1
mulekr1's Avatar
Yea stock fuel system. I didn’t start this thread right my mods are
Ofh
Oft
Mishimoto intake
Q300
That’s literally it
P0087 Low Fuel rail pressure GT86meMR2 Issues | Warranty | Recalls / TSB 17 05-15-2021 01:23 PM
Another CEL code whitefrs Forced Induction 20 11-27-2019 11:27 AM
p0462 fuel level sensor code. anyone else ran into this code georgiafrsguy Engine, Exhaust, Transmission 1 02-28-2017 08:28 PM
Lean Code and 02 Code diagnostics. Kiske Engine, Exhaust, Transmission 12 04-28-2016 10:19 PM
CEL code ChandlerSwyng Issues | Warranty | Recalls / TSB 2 04-08-2014 01:27 AM
