Drives: 2016 FR-S
Vibrating gas pedal?
Hey everyone,
I've been experiencing a really weird thing recently - my accelerator vibrates when I hold it at cruising speeds and it makes my foot tingle/feel like it's going to fall asleep. Has anyone else experienced this? Any suggestions? Car has 28k miles, so I could bring it to the dealer, but it seems like one of those issues where they would say "oh we can't feel it" and waste my time. Thank you!
Daily: 2016 FR-S
Weekend: 2002 Boxster S Retired: 2007 Mazdaspeed3, 2000 M5 |
#2 | |
Are you sure it's the accelerator pedal assembly itself or what it's attached to, that is vibrating ...?? You might check to see that it's bolted down tight. If you use the cruise control, does your foot still tingle (careful, that's a trick question .... ).Next ...... ![]() I call on @Ultramaroon to see if that old fool is still up. I'm sure he will have some sort of cocka mame theory ...... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | speedyspaghetti (01-29-2018) |
#3 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
| The Following User Says Thank You to finch1750 For This Useful Post: | speedyspaghetti (01-29-2018) |
#4 | |
The Fail Boat
Drives: CWP S.B.
| The Following 2 Users Say Thank You to chaoskaze For This Useful Post: | humfrz (01-29-2018), speedyspaghetti (01-29-2018) |
#5 |
Drives: 2016 FR-S
The shifter vibrates as well.
Daily: 2016 FR-S
#6 | |
Drives: 2016 FR-S
Daily: 2016 FR-S
| The Following User Says Thank You to speedyspaghetti For This Useful Post: | humfrz (01-29-2018) |
#7 |
Did you change tires recently? When I run my snow tires everything vibrates. I get used to it.
Anything change that could impact alignment? Pothole hit, etc? It may be something along that line where the vibration is just enough to be felt though the smaller fittings such as the pedal mount and shift lever. Could be so many things you may need to slowly work through process of elimination.
#8 |
"You got mud in your tires" Get your tires rotated and balanced.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| The Following User Says Thank You to stevesnj For This Useful Post: | humfrz (01-29-2018) |
#9 |
The Gunshine State
Drives: '14 BRZ Limited
I wish I sprung for the "foot massager" option.
![]() Current DD: M235i |
| The Following 2 Users Say Thank You to 8RZ For This Useful Post: | gravitylover (01-29-2018), speedyspaghetti (01-29-2018) |
#10 |
We DO NOT want to know what you would do with the vibrating shifter option.
#11 |
Your car didn't come with one of these ........??
![]() humfrz |
#12 |
The Gunshine State
| The Following User Says Thank You to 8RZ For This Useful Post: | stevesnj (01-29-2018) |
#13 | |
![]() (and I'm not sure I want to ...... )humfrz |
#14 |
| The Following User Says Thank You to humfrz For This Useful Post: | stevesnj (01-29-2018) |
| Buzzing/vibrating gear stick | paulca | Issues | Warranty | Recalls / TSB | 49 | 10-12-2017 11:47 AM |
| Vibrating shifter fix! | Superhatch | Issues | Warranty | Recalls / TSB | 51 | 06-05-2016 10:56 PM |
| Rear License plate vibrating | primalT | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 05-03-2014 01:20 AM |
| Exhaust is vibrating a bit.. | pgeist | Engine, Exhaust, Transmission | 3 | 07-09-2013 02:00 AM |
| Buzzing/vibrating speaker fix | CBR600RR | DIY (Do-It-Yourself) Guides | 3 | 05-21-2013 12:11 PM |
