Old 10-12-2017, 07:54 AM   #1
btan219
Drives: DGM 15' BRZ Limited
What's the suggest RPM threshold yo shouldn't exceed after first starting your car?
I turn my car on, wait a few seconds and then drive off. I try not to exceed 3k rpm in the first few minutes. Wondering if what I'm doing is ok or if I should change anything up.
btan219 is offline   Reply With Quote
Old 10-12-2017, 08:21 AM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
From a cold start, I let the RPMs drop off to the normal idle before I move (usually only takes 30 seconds). From there, I keep it under 4k RPMs until it reaches normal operating temp.
What you're doing is fine.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
humfrz (10-12-2017)
Old 10-12-2017, 11:08 AM   #3
The owner manual simply says "Do not race the engine on start up". No definition as to what "race" entails but since the break in max is 4,000 I would guess that exceeding 4,000 is what they mean.
Old 10-12-2017, 11:54 AM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
There was a brilliant detailed post a few years back from some dude in Norway I think who studied this kind of stuff at his job or something, someone dig that up that isn't me this morning, I haven't finished my coffee yet.
ineedyourdiddly
chaoskaze (10-13-2017)
Old 10-12-2017, 01:03 PM   #5
Sounds good to me ....
Old 10-12-2017, 01:13 PM   #6
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Same here. I let the cold start idle rpms drop before I leave, keep it under 3k for the first 5 or so minutes and under 4k until its warmed up... usually about the time I get to the freeway on ramp for a nice pull to get me up to speed
wolffbite is offline   Reply With Quote
The Following User Says Thank You to wolffbite For This Useful Post:
Somerandom18 (10-13-2017)
Old 10-12-2017, 01:19 PM   #7
TorontoNat
Drives: 2013 Scion FR-S Asphalt [Gray]
Onramps = Happy
TorontoNat is offline   Reply With Quote
Old 10-12-2017, 02:38 PM   #8
Originally Posted by TorontoNat View Post
Onramps = Happy
That reminds me of a back-in-the-day story ....... yep, it's a slow day here in Puyallup.
I had just moved from California to Westport, CT.
I was on the Merritt Parkway for the first time, screaming down the parkway in my MGB when the exit came up.
Now, I was accustomed to the wide sweeping off/on ramps of California.
So, when I exited onto the off ramp, I discovered that the surface was bricks and a much tighter turn than I was anticipating.
Having a sports car ...... I thought ....... no problem ....... right ......??
While sliding around the tight turn, taking most of the "off ramp" ....... I discovered (as another car was coming at me) that the off ramps were also the on ramps .......
THE END
The Following 7 Users Say Thank You to humfrz For This Useful Post:
chaoskaze (10-13-2017), Spuds (10-12-2017), StraightOuttaCanadaEh (10-12-2017), strat61caster (10-13-2017), Tcoat (10-12-2017), TorontoNat (10-12-2017), wrh3 (10-12-2017)
Old 10-12-2017, 02:44 PM   #9
THE END
Never though I would ever hear that sentence!
humfrz (10-12-2017), Spuds (10-12-2017)
Old 10-12-2017, 02:48 PM   #10
Me either ....... apparently they were made that way to conserve space .......
Old 10-12-2017, 02:54 PM   #11
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I watch my oil temperature which lags a bit behind the water temp. Usually oil temps are at 170-180 when coolant is up to temperature. That's about when I get to an on-ramp 5-10 minutes in. Until then, I try to keep it under 3.5krpm. Still a bit early at the on-ramp, but I can't resist either.
Spuds is online now   Reply With Quote
Old 10-12-2017, 02:56 PM   #12
TorontoNat
Oh man.. ON+OFF ramp is a scary thought indeed! I cant even picture how that would work at all.
Old 10-12-2017, 03:08 PM   #13
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
There's a small period, upon first starting a "cold" car, where the RPMs will stay slightly raised and then drop to normal idle. This is to warm the catalytic converter and is not necessary to wait for in order to drive the vehicle. Some people wait as peace of mind.
Jyn is offline   Reply With Quote
Old 10-12-2017, 03:16 PM   #14
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Onramps = Happy
Curvy onramps = very happy
Curvy offramps very, very happy
TommyW is offline   Reply With Quote
The Following User Says Thank You to TommyW For This Useful Post:
Why You Shouldn't Run Your Car Low On Gas Extreme Dimensions Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 38 06-23-2017 07:47 PM
Steering wheel resistance while threshold braking Pat Tracking / Autocross / HPDE / Drifting 28 01-25-2017 08:50 PM
Maybe I just shouldn't own this car execoll BRZ First-Gen (2012+) — General Topics 26 12-06-2013 06:08 PM
Turbo Kits: Rational boost threshold yet? Ryephile Forced Induction 88 01-22-2013 12:05 AM
Protecting plastic door threshold BMWDavid Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 06-19-2012 09:04 PM
