Old 10-05-2017, 11:40 PM   #1
Evil Rocky
Drives: FRS
Turn signal stuck on
So i have a 2015 FRS and changed bumper to a BRZ bumper and that's kind of when my issues started (before bumper changed i placed my side markers and all that would happen is my turn signal would be fast) I am having issues with my turn signal, my left turn indicator inside my dash stays on/lit and also my actual outside tail light stays on.
I do have Side markers and after market taillights. What could be the problem?
So before on FRS bumper I had turn indicators and now with brz I don't since I placed cleib canards on. A shop did the install and was working fine and the about a week later this happen.
Any help would be great.
Evil Rocky is offline   Reply With Quote
Old 10-06-2017, 12:30 AM   #2
LED86
LED86's Avatar
Drives: Black 86 GTS
Originally Posted by Evil Rocky View Post
So i have a 2015 FRS and changed bunkers to a BRZ and everything fits with nonorbelms. But now I am having issues with my turn signal, I do have side
Are the blinkers on and stay on as soon as you start the car? Cause it sounds like it's wired incorrectly and the have used the headlights park/drl wire to power the indicators
LED86 is offline   Reply With Quote
Old 10-06-2017, 08:58 AM   #3
Evil Rocky
Drives: FRS
Only when turn lights on or hit my brakes. If don’t hit brakes or tune lights on it functions fine
Old 10-06-2017, 10:11 AM   #4
I would check the after market tails.
Old 10-06-2017, 10:42 AM   #5
LED86
LED86's Avatar
Oh you mean you tail lights indicator? It sounds like you need to repin the tail lights as you brake/indicator wires are switched around. I think, bit hard to understand.
The Following User Says Thank You to LED86 For This Useful Post:
Tcoat (10-06-2017)
Old 10-06-2017, 07:52 PM   #6
Beachin86
Beachin86's Avatar
Drives: FR-S 10 Series
I agree with Tcoat and LED86, check the aftermarket tail lights. Search Youtube for DIY/Installation videos of whichever you have as some installs require splicing certain wires or moving them to different pins.
Beachin86 is offline   Reply With Quote
Old 10-07-2017, 09:28 AM   #7
Cole
Not a troll
Cole's Avatar
I dunno how any of you guys have even begun to be able to interpret what this guy's saying.
Some friendly advice, take the time to make sure your post is at least 90% understandable before asking for help.
Cole is offline   Reply With Quote
The Following User Says Thank You to Cole For This Useful Post:
Impureclient (10-07-2017)
Old 10-07-2017, 02:30 PM   #8
Hey, Cole, let's cut the guy some slack ........ he's from Chicago ........ it's a wonder he can type at all ........
Old 10-07-2017, 02:38 PM   #9
Beachin86
Beachin86's Avatar
I'm fluent in gibberish.
Sent from my Pixel using Tapatalk
Old 10-07-2017, 03:22 PM   #10
I haven't heard that term in quite a while .......
OK, you may translate for ol Cole .......
Beachin86 (10-07-2017)
Old 10-07-2017, 03:40 PM   #11
Impureclient
Drives: 2015 FR-S
The Following 2 Users Say Thank You to Impureclient For This Useful Post:
Beachin86 (10-07-2017), Cole (10-07-2017)
Old 10-07-2017, 08:00 PM   #12
Nsot
Nsot's Avatar
Drives: Whiteout FR-S
Shortly after installing my TOM's tail lights one of them would randomly get stuck on, even after turning off the car. I would have to pull the fuse to get them to turn off.
Like this
To fix it I bought a Tapturn relay and haven't had an issue in the last few years.
Nsot is offline   Reply With Quote
The Following User Says Thank You to Nsot For This Useful Post:
Evil Rocky (10-08-2017)
Old 10-07-2017, 09:42 PM   #13
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Did you check the blinker fluid? If the blinker fluid is low, it causes all kinds of issues.
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
Old 10-08-2017, 12:06 AM   #14
......... the blinker fluid system is sealed ....... it can't be low .......
guybo (10-08-2017)
Diode Dynamics Tail-as-Turn™: Make your LED tail a turn signal & add backup LEDs! Diode Dynamics Exterior Parts - Lighting 192 10-04-2017 11:51 AM
FS:GCS V.1 Turn signal Vesalera Exterior Parts (Aero, Lighting, Etc.) 1 01-07-2017 07:14 AM
Right Turn signal DOES NOTHING ??? JR Whiter Issues | Warranty | Recalls / TSB 5 10-29-2016 02:40 AM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
