Old 08-28-2017, 10:17 AM   #1
BRZHarley
Drives: 69 Firebird, 2015 BRZ
Whiteline Greaseless swaybar bushings..
Hello Everyone!
Just a little year long end-user feedback on the Whiteline Greaseless swaybar bushings...
They hold up very well in the very rough driving conditions of North Central WV... Also the coating on the 20mm 2 position bar that I'm using is still flawless after over 10K miles of use...
The only caveat.... The bushings are not greaseless long term... After checking other items first, I was finally force to remove the bar and grease them with proper bearing lube... Smooth and quiet sailing since... :-)
Just my 2cents so take it for what it's worth!
Ed
BRZHarley is offline   Reply With Quote
Old 08-28-2017, 10:44 AM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
So basically false advertising?
Old 08-28-2017, 11:29 AM   #3
Racecomp Engineering
I'd recommend also wrapping the bar at the bushings with teflon tape.
Old 08-28-2017, 11:35 AM   #4
e1_griego
e1_griego's Avatar
Drives: Many
One of my whiteline d-link bushings tore in half within a month of install, and I had used a bit of grease on it. After some back and forth white whiteline they sent me a pair of replacements.
I ended up buying a pair of HardRace bushings (16mm) but sold the bar before I got around to install (for sale if anyone wants them).
e1_griego is offline   Reply With Quote
Old 08-28-2017, 11:43 AM   #5
BRZHarley
Not so much... More like Murphy's law... ;-)
Ed
Old 08-28-2017, 11:44 AM   #6
BRZHarley
I always wanted to try this but I never seem to think of it once I have everything apart... LOL
Whiteline spring and swaybar kit Purist Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-11-2017 07:54 PM
FS: Whiteline 20mm Front Swaybar smg1138 Brakes, Suspension, Chassis 0 04-30-2017 06:28 PM
FS: Whiteline Rear sway bar endlinks, New Whiteline rear swaybar mount braces e1_griego Brakes, Suspension, Chassis 1 02-15-2017 12:00 PM
Aftermarket swaybar bushings venturaII Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-27-2015 07:59 PM
replace stock swaybar bushings - any material handing differnce? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-16-2013 07:15 AM
