Old 07-10-2017, 09:10 PM   #1
Veejayy
Drives: VW GTI
Check engine and traction control symbol in rental
Hello- I have rented an FRS, 2015 automatic and both times after driving for awhile the check engine and traction control symbol appear.
I pull off and turn engine off and restart and traction control symbol gone but check engine light still appears. The car drove fine and I was near dealer so I returned and told them about it and they said they would check it out.
Both times it was dry with low humidity but ambient temp in the mid-80s.
I did not push the car either time. Both times it happened when I was in heavy stop and go traffic with occasional breaks were you could go faster.
The reason I am renting is I wanted an extended "test drive" before I purchased car. I really enjoyed both rentals and I am close to purchasing.
Any thoughts?
Thanks!
Veejayy is offline   Reply With Quote
Old 07-10-2017, 09:17 PM   #2
There are about 1,000 things it could be from a loose gas cap up to the engine is going to die any second. The only way to have any clue at all what is up is to read the code that is throwing the CEL.
DarkPhoenix (07-10-2017)
Old 07-10-2017, 11:27 PM   #3
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
Any thoughts?
Thanks!
i doubt it has anything to do with the air temp, my 86 does ok in the dry 120 degree AZ heat..if it is a full time loaner/rental who knows what sort of abuse it went through.
HKz is offline   Reply With Quote
Old 07-11-2017, 01:25 AM   #4
Any thoughts?
Thanks!
Nope, that's not normal behavior for the car.
I'd suggest you call your test drive good and take the car back to where you rented it from and turn it in.
22R (07-11-2017)
Old 07-11-2017, 09:39 AM   #5
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
rental- take it back. You don't want to diagnose or give a fuck. You definately don't want to be driving it when whatever is broken on that car decides to go.
Don't even drive it back, call the rental co., tear them a new asshole complain it goes into limp mode and have them TOW IT BACK AT THEIR EXPENSE.
guybo is offline   Reply With Quote
Old 07-11-2017, 11:44 AM   #6
extrashaky
Drives: 2014 BRZ Limited
By any chance are you or the rental company using any kind of OBDII device in the car?
The Following User Says Thank You to extrashaky For This Useful Post:
wireman957 (07-11-2017)
Old 07-11-2017, 01:27 PM   #7
wireman957
wireman957's Avatar
Drives: 2015 FR-S MT Steel
I actually had that combination in my car the other day. I had my bluetooth OBDII device on and Torque running on an Android tablet. I have the OBDII on a switched extension cable and stopped to grab something at the store. Didn't turn the device off and when I re-started the car I had a CEL and the Trac Control indicator was lit, even though the car seemed to be running fine. Torque told me it was a bus communication error of some sort. I used Torque to clear the code and it's been fine ever since. If you don't have Torque or access to a code reader, find an auto parts store that can clear the code for you. Many, if not most, will do it for free. If the code stays cleared, you're good to go. If it comes back, like others have said, call the dealer and have him pick it up. You don't want to take a chance on being dinged for something you didn't do.
"No matter where you go, there you are" - Buckaroo Banzai
Last edited by wireman957; 07-11-2017 at 04:50 PM. Reason: Sometimes my grammar sucks...
wireman957 is offline   Reply With Quote
Old 07-11-2017, 07:15 PM   #8
Veejayy
Drives: VW GTI
Thanks everyone. Yeah I turned the rental in both times because I was on my way back to the rental agency and was done with my drive anyway.
Old 07-11-2017, 07:58 PM   #9
So, what color are you going to get ...... ??
Old 07-11-2017, 08:29 PM   #10
Dake
Dake's Avatar
Almost five years in and never had that happen. I would consider it representative. Rentals get abused; sports car rentals get murdered.
Dake is offline   Reply With Quote
Old 07-11-2017, 10:00 PM   #11
stevesnj
stevesnj's Avatar
Sports car rental = EVERYONE before you beat the crap out of that car! From the salesman to the 70 year old grandpa looking for a fun weekend. As long as you told them don't worry. That car has 50 different peoples farts in the driver seat. That's gotta be the cause of something.
My 2016 Build thread
Check Engine light and Traction Control Light JeRM Issues | Warranty | Recalls / TSB 25 06-02-2023 09:00 PM
Help needed! Check engine light after weird traction lights. dillanp86 Engine, Exhaust, Transmission 3 12-08-2016 09:17 AM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
First Check Engine Light and Traction control QFry Issues | Warranty | Recalls / TSB 26 10-04-2014 11:27 PM
