Old 07-03-2017, 11:50 AM   #1
pym19109
WRBLUE BRZ
pym19109's Avatar
Drives: 2016 Subaru BRZ
Brake pads advice
Hi guys. Please be nice to me, I'm a noob
I'm looking for new brake pads but I am not sure which one is suit to my style.
My brz is DD , some spirited running and occasional track days 3-4times a year.
My wheels wrap by Michelin Pilot Sport 4 225/40/17. in the futher might be AD08R or R1R.
I am looking HPS,HP+ and HC+800 or anyone suggests other ?
pym19109 is offline   Reply With Quote
Old 07-03-2017, 05:28 PM   #2
Silver Supra
Hombre
Silver Supra's Avatar
Drives: 1994 Supra Turbo
I would start here:
A lot of good info.
Silver Supra is offline   Reply With Quote
The Following User Says Thank You to Silver Supra For This Useful Post:
pym19109 (07-05-2017)
Old 07-03-2017, 05:38 PM   #3
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Never listen to brake pads advice.
Scrappydoo is offline   Reply With Quote
The Following 4 Users Say Thank You to Scrappydoo For This Useful Post:
kch (07-05-2017), pym19109 (07-05-2017), strat61caster (07-04-2017), wparsons (07-04-2017)
Old 07-04-2017, 06:12 PM   #4
stevesnj
stevesnj's Avatar
Winmax W2 love them for DD and Tracking 5-6 times a year.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Old 07-04-2017, 06:19 PM   #5
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I was shopping for a DD Set of brake pads and rotors. I decided on StopTech street 308 with centric plain rotors. I wanted a non-squeeky brake with good bite. Didn't care about life or dust.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
Old 07-04-2017, 06:21 PM   #6
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Why not the stock ones? Most performance brake pads will make noise in DD.
The Following User Says Thank You to nikitopo For This Useful Post:
Old 07-04-2017, 06:46 PM   #7
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
If he has any skill on track he'll toast the stock pads by lunchtime if they run track days over there like they do here and be stuck with a car that has no brakes on the drive home.
I killed mine in my second ever track day, first time at Laguna Seca. The pads never recovered, felt like chalkboard erasers until I finally gave up on them.
Op have you been to the track before? If not then stock will likely be ok for your first time or two or three. Be careful and don't try and set any records until you're confident in your brakes, whatever you choose.
http://www.ft86club.com/forums/showthread.php?t=25485
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
pym19109 (07-05-2017), stevesnj (07-05-2017), wparsons (07-04-2017)
Old 07-04-2017, 07:54 PM   #8
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Once you start leaning on the brakes you might like to consider 2 sets of pads: one for street and one for track. Swapping them out is a painless choir that can be done the day before you go to the track.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
Old 07-05-2017, 05:36 AM   #9
pym19109
WRBLUE BRZ
pym19109's Avatar
I can accept the noise if it isn't too much loud.
The Following User Says Thank You to pym19109 For This Useful Post:
nikitopo (07-05-2017)
Old 07-05-2017, 05:45 AM   #10
pym19109
WRBLUE BRZ
pym19109's Avatar
Yes , 2 days with stock pads. I'm just a noob but i can realize that i need more stop power and it was fade after 3 laps.
strat61caster (07-05-2017)
Old 07-05-2017, 12:25 PM   #11
strat61caster
Sounds like you're headed in the right direction, any of the ones you've mentioned will be a nice step up but eventually you will fade those pads as well. The next step up is likely going to be too loud for the street and you'll have to swap pads between track and street driving.
The two alternatives mentioned a lot but may not be easily available in your country are Ferodo DS2500 and Carbotech XP8 which I believe are comparable to HC800+, I don't really know how well the Hawk's would compare.
ineedyourdiddly
Old 07-05-2017, 02:23 PM   #12
pym19109
WRBLUE BRZ
pym19109's Avatar
Thank you very much . I will search those review in this forum.
I may try one of those and consider about 2 sets of DD and track.
If it is not avaliable in my country , I will order it from ebay.
Old 07-05-2017, 02:29 PM   #13
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
The new Hawk Race/Street pads were really nice, they were like a higher bite Project Mu HC 800.
I've run the Hawk Street/Race, Project Mu HC 800, and the Ferodo ds2500 and the Hawks were my favorite (they were more expensive than the others, and could get loud on the street but worked amazingly at the track and for autox).
14stu is offline   Reply With Quote
The Following User Says Thank You to 14stu For This Useful Post:
pym19109 (07-06-2017)
Old 07-05-2017, 02:49 PM   #14
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Lots of good suggestions on this thread, I can't add too much to it. My experience with EBC Yellowstuff was decent for a dual duty track and street pad. They make a tiny bit of noise on the street and hold up to track abuse fade free. They actually bite quite a bit harder when hot than when cold. I chose to try running a more aggressive pad because they don't hold together very well and wear pretty quickly, I killed a set in a single season with moderate street and track driving.
I will note one thing that no one else here mentioned yet: Upgrade from the standard brake fluid right away. The OEM DOT3 stuff is not up to track abuse at all. A lot of people complain about fade on the OEM system and most of it can be attributed to the OEM brake fluid. If you don't want to spend an arm and a leg, Motul RBF600 is a good place to start but you may have to perform partial bleeds after any track days with this fluid so make sure you've got an extra bottle for that. If you don't want to do partial bleeds periodically then Torque RT700 or Castrol React SRF are great but expensive.
Lynxis is offline   Reply With Quote
The Following 2 Users Say Thank You to Lynxis For This Useful Post:
pym19109 (07-06-2017), strat61caster (07-05-2017)
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 03:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
