Drives: 2013 Firestorm FR-S
Condensation in tailights.
I have none. 35k miles, 2013 frs. The thread is too long to search through in the recall section. Should i do anything to prevent it? Or just leave it alone?
#2 |
If you don't have it now you probably won't. Just leave well enough alone and don't do a thing.
#3 |
Drives: 2014 Scion FR-S
#4 |
Drives: 4wd zooks
The tail light condensation problem was with the initial 2012 production.
#5 |
Drives: 2013 Scion FRS
I live in south Florida with a '13. Slight condensation, but nothing bad. You can try to add sealant around the border to prevent it, but you've already made it this far. And it gives a good reason to upgrade to Valenti if it does go bad.
Sent from my HTC6535LVW using Tapatalk |
#6 |
Drives: Grrrr
I don't have any punctures at the moment.
What should I do about it? |
#7 |
*Some really cool title*
Normally I'd ignore what Scrappy says, but this time he has a point. Not worth it worrying about a problem that isn't there, and even if it does appear is very easy to fix.
If it's bothering you that much, then the two easiest solutions are drilling a hole in the bottom corner of the housing to allow the water to vent out, or sealing the border between the tail light and trunk vent with silicone (which is what I did). |
#8 |
| The Following User Says Thank You to humfrz For This Useful Post: | Scrappydoo (06-30-2017) |
#9 |
Thanks guys. I figured I shouldn't do anything, but the thread was so long that I wasn't entirely sure what the issue was. Thanks for the reassurance guys.
Next up: My car seems to be running perfectly, does that mean the exhaust bearings need to be replaced? Stay tuned. |
#10 | |
You're a good sport there, nickjpass ...... we'll let you hang out here ..... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | nickjpass (07-04-2017) |
| FS: OEM tailights | VirginiaBRZ | Exterior Parts (Aero, Lighting, Etc.) | 5 | 03-23-2016 11:21 AM |
| Tom's tailights | halo13 | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 01-29-2016 03:49 PM |
| FS: OEM Tailights BRZ/FRS | TONYpepperon1 | Exterior Parts (Aero, Lighting, Etc.) | 12 | 05-22-2015 05:34 PM |
| Some tailights we might have to get used to seeing! | NOHOME | Other Vehicles & General Automotive Discussions | 48 | 12-25-2014 01:02 AM |
| Where can i buy these tailights!! | Amir_joon | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 07-01-2014 11:19 AM |
