Old 05-10-2017, 09:53 PM   #1
GoobyFRS
GoobyFRS's Avatar
Drives: Ultramarine Blue FRS
Disable Rear O2
Keep getting P0140 CEL. Rear O2 No Voltage. I double checked the connector, everything looks fine. So I figure it's just shot.
I installed catless headers 5 months ago and have been running the OFT OTS Stage 2 UEL 91 oct tune since. About 15k miles.
Gonna buy a new O2 sensor at some point, but can't right away, so I want to disable it.
So from reading other threads I understand I need to 0 all inputs in the Closed Loop Fueling Target Compensation B (Load) in RomRaider.
https://gyazo.com/0b54a6c17dda6a4e338f42fe068d25d7
So, I'm thinking I should 0 those, and then in the Primary Open Loop Fueling leaning out a bit around Idle to help compensate from running at 13.4 AFR like it has been.
GoobyFRS is offline   Reply With Quote
Old 05-11-2017, 12:29 AM   #2
steve99
Drives: FT86
Set af#3 corrections to zero
Old 05-11-2017, 01:26 AM   #3
GoobyFRS
GoobyFRS's Avatar
Would that normally be in the Fueling - AF Corrections / Learning folder? Because I don't seem to have anything anywhere in my rom with AF#3.
https://gyazo.com/93ff4b63d8cdefbbbe55e3f109c72059
Old 05-11-2017, 04:45 AM   #4
steve99
Drives: FT86
AF3 correction in my defs under Fueling AF correctiom /Learning
try attached definition but check tables and make sure its matched to your rom
Old 05-12-2017, 09:11 PM   #5
RedFRS4me
RedFRS4me's Avatar
Drives: Firestorm '13
Zero af3 tables then disable cel code for o2 voltage. I've been running with zeroed af3 tables for a year with no noticeable issues. Another thing if you intend to buy a new o2 sensor. Going catless might be why the o2 deteriorated prematurely. I bought a new o2 but left my bad o2 in for my catless header.
'13 Firestorm
RedFRS4me is offline   Reply With Quote
catless, header, oft, oxygen sensor, tune
TPMS Disable? Newtothegrounds Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 03-30-2017 01:54 PM
How to disable DRL in FRS whitefrs Cosmetic Modification (Interior/Exterior/Lighting) 12 12-13-2016 02:11 PM
how to disable drl ? Ardenyo2k13 Scion FR-S / Toyota 86 GT86 General Forum 55 05-03-2016 09:38 PM
Automatic VSC ABS TRC disable box KenTK808 Electronics | Audio | NAV | Infotainment 0 04-04-2015 06:25 AM
Is there a way to disable the immobilizer? schtebie Issues | Warranty | Recalls / TSB 5 09-22-2012 06:09 PM
