Old 05-09-2017, 01:26 PM   #1
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Need alignment spec recommendations
So I just installed Megan coilovers and will be doing the first alignment on it. The suspension does not have front adj. camber plates but I did buy front camber bolts (rear is all stock).
I mainly do spirited city driving with occasional autox (only 3 times last year and none this year yet).
I have heard some negative camber would be beneficial but how much in the front and rear exactly should I tell the shop? I plan on 0 toe, is castor adjustable on our cars?
Thanks.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 05-09-2017, 02:30 PM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
what is your goal? just street? track? it really depends on what you want.
go from -1.5 all around and see how you like it
Old 05-09-2017, 07:22 PM   #3
8RZ
The Gunshine State
8RZ's Avatar
Like I stated, mostly daily driving on the street with occasional autox.
-1.5-2 all around sounds like a good start.
Current DD: M235i
Old 05-09-2017, 08:24 PM   #4
Gforce
Drives: 2013 Subaru BRZ
You can get nearly 2.0 degrees rear camber with Subaru crash bolts. Subaru sells these to correct rear alignment problems.
Gforce is offline   Reply With Quote
Old 05-09-2017, 10:51 PM   #5
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
It has been suggested rear camber should be initially setup with 0.5 less negative camber than front given the different wheel geometries (Mac strut vs upper/lower control arm). E.g. Front camber -3.2, rear camber -2.7.
Old 05-10-2017, 03:39 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
"You can get nearly 2.0 degrees rear camber with Subaru crash bolts. Subaru sells these to correct rear alignment problems"
Rear camber with crash bolts? Not eccentric bushings? And it's Subaru, not Whiteline? rear alignment problems?
My conviction that he is trolling just grows stronger by each post.
sugoi (05-10-2017)
Old 05-10-2017, 08:13 AM   #7
8RZ
The Gunshine State
8RZ's Avatar
I have a staggered setup, would this still hold true for me?
Current DD: M235i
Old 05-10-2017, 08:19 AM   #8
Captain Snooze
Drives: Red Herring
I do not know but I am thinking that given the differing roll rates front and rear (I am suggesting the more grip at the rear will cause more roll at the rear) you may want a different delta f/r camber.
Let me emphasise this is just conjecture on my part.
The proper way to set camber is with a pyrometer.
8RZ (05-10-2017)
Old 05-10-2017, 08:22 AM   #9
cjd
cjd's Avatar
Drives: 2017 BRZ
Just get something "in the green". It's clear performance isn't your intent.
The Following 2 Users Say Thank You to cjd For This Useful Post:
Captain Snooze (05-10-2017), Lynxis (05-10-2017)
Old 05-10-2017, 08:26 AM   #10
8RZ
The Gunshine State
8RZ's Avatar
I never claimed it was, majority city/hwy driving.
Current DD: M235i
Old 05-10-2017, 10:58 AM   #11
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Seconding this.
Note that rear camber isn't adjustable on the stock hardware, you need either adjustable rear lower control arms or eccentric bushings so you are going to get what you get in the rear without one of those.
The suggestions for a bit less camber in the rear than the front is because the front is macpherson strut and the rear is multilink. As a result, the rear gets more camber under compression than the front does. To adjust for this, most people aim for around 0.5 degrees more in the front than the rear to even it out.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
8RZ (05-10-2017)
Old 05-10-2017, 11:05 AM   #12
8RZ
The Gunshine State
8RZ's Avatar
Sounds good, thanks fellas.
Current DD: M235i
Old 05-10-2017, 05:45 PM   #13
cjd
cjd's Avatar
Drives: 2017 BRZ
Yeah, that was me keeping it short not criticizing. I'm a proponent of more front camber than is green, but it's not required.
Old 05-10-2017, 09:53 PM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
That sounds to me like much more grip needs to be added in front relative to rear. Be it in way of extra camber, lesser swaybar or whatever. Of course my real choice would be to not get staggered wheel/tire setup in first place, to not have to workaround it. Even selling staggered set of used wheels is much harder as there are way less potential buyers who would want such.
Alignment recommendations for my setup? sqd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-19-2016 01:33 PM
Need Insight on Shop Recommendations - Alignment Ammunition Northwest 19 04-29-2016 02:04 AM
Alignment shop recommendations? (SEA) Koa Northwest 7 02-16-2015 07:18 PM
Alignment Shop Recommendations (San Diego) RMP Tracking / Autocross / HPDE / Drifting 3 07-25-2014 04:14 AM
Recommendations for alignment in Socal anewprelusion Southern California 18 01-13-2014 02:36 PM
