Old 03-23-2017, 10:16 PM   #1
GNious
Drives: 2017 BRZ (CWP)
Exhaust tips hanging a little low.
Not really necessary to go into the specifics, but the tips of my recently installed catback is hanging a little lower than I'd like. There's about a 1 1/2 inch to 1 3/4 inch gap above the tips. Is there such a thing as shorter exhaust hangers that I could buy to quickly solve this? Not really interested in performing any cutting.
Thanks!
GNious is offline   Reply With Quote
Old 03-23-2017, 10:23 PM   #2
DrButtDrugs
yerp
Drives: 2015 WRX
Can you turn the bushings a little bit so they don't hang straight down? You might be able to get nearly an inch if your pipe has a little give.
DrButtDrugs is offline   Reply With Quote
Old 03-23-2017, 10:35 PM   #3
GNious
I could try giving this a shot in the morning when I have some daylight. I would imagine that they'd just slide back into place after a while. I'll do my best, though.
The Following User Says Thank You to GNious For This Useful Post:
15limited (03-24-2017)
Old 03-23-2017, 10:56 PM   #4
swarb
You can buy stiffer hangers(polyurethane instead of rubber) or put both hangers in the same hole.
You can also heat the hanger and bend it into shape, just don't rip it off the weld.
1.5-1.75 inches is kind of a lot.
Do you have pics? What exhaust is it?
Old 03-24-2017, 12:21 AM   #5
15limited
15limited's Avatar
Thanks!
You're going to want at least some clearance so you don't run the risk of melting your bumper cover, turning the bushings won't do anything they will just rotate back. I bought Perrin? poly hangers and they are WAY stiffer than stock, can't comment on height difference as I didn't take measurements, but you could always utilise them on the most rearward 2 hangers for some angle adjustment if your new catback still uses all 4 muffler hangers
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 03-24-2017, 06:17 AM   #6
GNious
Measurement might not be exact, but I do know it's two finger widths for me. It's a Spec-D catback. Wanted something cheap for now (for better sound). Plan on going a full custom setup with quad tip in the future.
Old 03-24-2017, 09:16 AM   #7
Diode Dynamics
Diode Dynamics's Avatar
You should be able to adjust it a bit, or just replace the hangers with something shorter.
Nick C.
John C.
Diode Dynamics
Old 03-24-2017, 09:31 AM   #8
KnightRyderx2
Drives: 2014 FR-S
You can use worm clamps to shorten up the hangers. Just wrap the hanger with the clamp and tighten up. Just make sure you get the correct size; to small and it wont fit around the hanger, to big and it wont tighten down enough to do anything. This will get you about 1/2 to 3/4 inch less gap. You can also make adjustments as far as tighter or looser so you can even out the tips.
KnightRyderx2 is offline   Reply With Quote
The Following User Says Thank You to KnightRyderx2 For This Useful Post:
Timmy_Jones (03-24-2017)
bullshit roads, low hanging single exhaust and coilovers balci Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 02-01-2017 06:21 AM
Any tips or tricks on how to get your exhaust tips exactly where you want them? dumbforcrumbs Engine, Exhaust, Transmission 21 12-26-2015 08:32 PM
FS: 2015 Exhaust tips and DC exhaust tips BOTH SOLD* sal Canada Classifieds 8 03-25-2015 06:32 PM
WTB: JDM exhaust tips or perrin tips calvinck Canada Classifieds 0 06-01-2014 11:17 PM
iPod Keeps resetting, hanging; etc... Anyone else seeing this Max1957 Electronics | Audio | NAV | Infotainment 5 03-17-2014 08:41 PM
