Old 02-22-2017, 10:26 PM   #1
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
DIY - OEM Armrest Install (Hybrid/more secure method)
I've had my eye on this armrest since I bought the car and kept putting off buying it since it's 200 bucks. I found these OEM look-alike versions for around $150 and was hesitant about the quality/fitment, plus I'd rather spend an extra $50 for the OEM variant. I then found a seller on eBay, based in the UK, selling OEM units for $160 shipped. I bought it, and within 8 days it arrived.
While doing research I found a guy that bought one of the OEM look-alikes on Amazon and in his review he mentioned that he installed the armrest by taking out the center console and securing the bolts using wing nuts on the underside of the center console instead of relying on the rubber anchors that come with the arm rest. The install instructions have you drill holes in the center console and insert these rubber anchors that widen and secure themselves when you put the bolt through. The armrest is not securely attached to the car.
Toyota's method of installing this requires that you drill 11 holes. First using a 5mm bit, and then an 8mm bit -- in the end you have 11 8mm holes. 3 of these holes are filled with 3 plastic anchors on the underside of the armrest. In the other 8 holes, you insert a rubber anchor that when a bolt is driven through it, they expand to secure the arm rest in place. So the armrest is never securely anchored down, it could be lifted up if pulled hard enough.
The hybrid install: To make the install more secure, I used only 4 of the rubber anchors and the other 4 bolts are secured using a lock nut on the underside of the center console. This method does require that you remove the center console but IMO its easier to drill holes and do the install with the center console out of the car. With this method, the armrest is installed permanently and will never come loose. To install this way, you need to drill 4 5mm holes and 7 8mm holes. 4 of holes (5mm) have to be just wide enough to get the bolt through. The other holes have to be 8mm to accommodate the rubber anchor and plastic anchor on the armrest frame. The 4 5mm holes are the ones on the front-most and rear-most sides of the armrest (2 on front side, 2 on rear side) -- see pics below.
Link to armrest: http://www.ebay.co.uk/itm/350825608542
The seller is burrowscarparts. The invoice is from an actual Toyota dealership -- Burrows Toyota Sheffield.
The goods
Some before pics
Center console removed and ready for install
Paper template taped to center console. This was a little annoying to get just right. I moved/re-taped a few times until I was happy with the placement. I started with drilling holes right through the paper for the 3 plastic anchors on the underside of the armrest (see 3 holes drilled in below pic).
You need to remove the cushion of the arm rest so that you can access the bolts and secure them. Test fit
I then proceeded to drill the remaining 8 holes. I drilled the 5mm holes right through the armrest to make sure I had no issues with fitment. Be very careful and make sure you are not drilling on an angle. Once done, I removed the armrest and screwed the bolts in place to make sure they would fit through. I then re-drilled 4 of the holes with the 8mm bit. The front-most 2 holes and rear-most 2 holes need to remain at 5mm.
The 5mm holes will be secured with lock nuts so no rubber anchor is used. The larger 8mm holes have been fitted with the rubber anchors.
You can only easily secure it with 4 lock nuts because there is padding that is in the way on each side on the underside of the center console. You could remove this padding and reinstall it if you really wanted to use 8 lock nuts to secure it, but in my opinion it is plenty secure with using only 4 lock nuts. Also, the rubber anchors were more secure than I expected when I gave it a tug prior to adding the 4 nutted (lol) bolts.
I then started bolting the armrest to the center console, starting with the bolts that use the rubber anchors. Be careful to not over tighten these. I then installed the bolts that are secured with a lock nut. The front-side bolts are circled in green.
The rear-side bolts are circled in green.
Armrest pad reinstalled and it's ready to go back in the car.
Done
This is the hardware I used from Home Depot. 4 nuts and 4 washers = $2.54
And 5 gallons of a dogfish head 60 minute IPA clone I brewed 2 weeks ago.
B-R-Z is offline   Reply With Quote
The Following 13 Users Say Thank You to B-R-Z For This Useful Post:
bhmax (07-26-2017), BigHugeFatGuy (04-03-2019), btune (03-06-2017), Byza (04-15-2017), Cole (08-12-2017), derekbrz24 (02-23-2017), funwheeldrive (02-23-2017), Guru Woodman (02-22-2017), jcw99 (02-23-2017), MJones_RB (10-31-2018), Nails (04-27-2017), TofuJoe (08-09-2017), wolffbite (04-27-2017)
Old 02-23-2017, 08:11 AM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Looks good, that should have been a standard option.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
B-R-Z (02-23-2017)
Old 02-23-2017, 11:00 AM   #3
B-R-Z
B-R-Z's Avatar
I don't understand why this isn't standard. The interior looks rushed/unfinished without it. Plus logically, why would they not include it? Are Americans known to not like armrests?
The Following User Says Thank You to B-R-Z For This Useful Post:
TOLM (01-07-2018)
Old 02-23-2017, 11:19 AM   #4
Subie_Nubie
Subie_Nubie's Avatar
Drives: 2013 Subaru BRZ Limted
All your pics are dead atm. Can you reupload so I can see this DIY goodness? @B-R-Z
2013 SWP BRZ Limited // 6 MT // Grimmspeed Intake // Tomei Supreme UEL Header // OFT Stage 2, 93 Oct, UEL Tune // Enkei RPF1's // Borla Catback and Diffuser // Bilstein Shocks // Eibach Anti-Roll Kit // TRD Strut Bar
Subie_Nubie is offline   Reply With Quote
Old 02-23-2017, 11:30 AM   #5
B-R-Z
B-R-Z's Avatar
They work for me..they are all on Dropbox. Can anyone else not see them?
Old 02-23-2017, 04:42 PM   #6
derekbrz24
derekbrz24's Avatar
Drives: 2017 Subaru BRZ WRB PP
Thanks for the tutorial but where did you buy your seat heater trim? I like the carbon and red brz look.
derekbrz24 is offline   Reply With Quote
Old 02-23-2017, 05:15 PM   #7
funwheeldrive
Looks great! Thanks for the write up. I plan on installing one of these when my car is paid off.
The Following User Says Thank You to funwheeldrive For This Useful Post:
B-R-Z (02-23-2017)
Old 02-23-2017, 06:05 PM   #8
B-R-Z
B-R-Z's Avatar
I bought that years ago, maybe 2014. I think Diode Dynamics but not 100% sure.
Old 04-15-2017, 03:57 AM   #9
Byza
Drives: 2017 86 GTS
Pics are down for me too.
Byza is offline   Reply With Quote
Old 04-15-2017, 09:40 AM   #10
B-R-Z
B-R-Z's Avatar
Thanks. I guess dropbox killed my public links. Images have been fixed.
Byza (04-15-2017)
Old 04-15-2017, 09:51 AM   #11
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Nice write up, but I'm more interested in your Dogfish 60-minute clone recipe. All-extract, or did you mash? Willing to share? I've never had great luck brewing IPAs.. my yeast always gives out once the alcohol content gets high.
Thanks!
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 04-15-2017, 10:04 AM   #12
B-R-Z
B-R-Z's Avatar
Originally Posted by MuseChaser View Post
Nice write up, but I'm more interested in your Dogfish 60-minute clone recipe. All-extract, or did you mash? Willing to share? I've never had great luck brewing IPAs.. my yeast always gives out one the alcohol content gets high.
Thanks!
It didn't come out as good as I was hoping. It has a nice hoppy flavor and ~6.5 ABV, but the nose isn't there so it doesn't drink like DFH 60 minute does. This was an extract recipe -- I have not advanced on to grain yet. I used this recipe, which has instructions for both: http://www.homebrewtalk.com/showthread.php?t=25709
A few weeks back I brewed Northern Brewers Off The Topper, which is a Heady Topper clone. I gave it a taste when I moved it to the secondary and it tasted awesome, just hoping the dry hopping works out this time to give it the nice aroma. http://www.northernbrewer.com/off-th...a-homebrew-kit
I've used Safale US-05 yeast for all of my brews so far and have had good luck with it.
MuseChaser (04-15-2017)
Old 04-15-2017, 10:10 AM   #13
dinfern22
dinfern22's Avatar
Drives: 2016 Scion FR-S(Halo)
Without removing the center console, could I use the template to drill just the 3 holes for the anchors, then insert the arm rest into the three holes then drill the rest of the holes, while the anchors are inside for better accuracy?
dinfern22 is offline   Reply With Quote
Old 04-15-2017, 10:42 AM   #14
B-R-Z
B-R-Z's Avatar
Yes, the official instructions do not require that you remove the center console. I think it's safer to drill right through the armrest holes so you do not have any surprises when you go for the final mounting.
Sent from my Pixel using Tapatalk
DIY: Quick-Latch Install (Hybrid Way) zeal86 DIY (Do-It-Yourself) Guides 11 09-28-2017 10:19 PM
Install rear armrest SPEEDGOD Scion FR-S / Toyota 86 GT86 General Forum 5 07-15-2014 11:32 AM
Rear Armrest install Vides990 Cosmetic Modification (Interior/Exterior/Lighting) 8 03-09-2014 12:40 AM
jdm armrest install, help jdubious Cosmetic Modification (Interior/Exterior/Lighting) 4 12-11-2013 01:34 AM
1-Bucket Method (Gary Dean) - The best rinseless wash method Obsidiank Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 12 09-23-2013 01:00 PM
