| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2014 BRZ Limited
Why I bought the extended warranty
![]() 65,000 miles. Stock NA drivetrain. Maintenance schedule followed to the letter, performed by dealerships to maintain the record trail. Used oil analysis done after every oil change, with no indicators of a problem at all. Saturday afternoon, as I was pulling away from a light and shifting from first to second, I heard a startling pop/growl noise followed by a clattering sound. I was actually looking at the tach when it happened and saw the oil light come on right after the sound. I pulled into the nearest parking lot and called for a tow. The local dealership opened it up this morning. Apparently the oil pump shattered, starving the bearings of oil and causing one or more of them to spin, all of which happened within the span of a few seconds. SOA has asked the dealership to inspect the bearings and heads to see the exact extent of the damage, but the dealership has already said I'm getting a new short block at a minimum and probably a long block. They're taking good care of me so far. At the time I bought my car, I recall people on this board telling everyone who bought the extended warranty how stupid they were for wasting the money. I bought it anyway. I paid $1500. An engine swap would be what, about a $5K job? It looks like I'm getting it under warranty. I'm glad I didn't listen to the people saying how stupid I was. |
| The Following 14 Users Say Thank You to extrashaky For This Useful Post: | Atropine (02-07-2017), BboyRuda (02-07-2017), funwheeldrive (02-06-2017), Impureclient (02-07-2017), jcw99 (02-06-2017), justatroll (02-06-2017), Kimsey47 (02-07-2017), Mim (02-07-2017), new2subaru (02-06-2017), soulreapersteve (02-07-2017), strat61caster (02-06-2017), Tcoat (02-06-2017), Yardjass (02-07-2017), ~el~jefe~ (02-07-2017) |
#2 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (02-06-2017), strat61caster (02-06-2017) |
#3 | |
Drives: '13 FRS - STX
#4 |
The Gunshine State
Drives: '14 BRZ Limited
Wow, is oil pump failure common on FAs? This is the first time I've heard of this.
![]() Current DD: M235i |
#5 |
Drives: LR BRZ Limited
i bought the extended warranty too brother.
#6 |
The Gunshine State
The main issue with extended warranties is that you must have proof that you have done all scheduled maintenance or else it will be voided.
If you spend the money to take the car to the dealership for every oil change, services, etc then it will be fine. Otherwise, you have to do all the maintenance yourself and keep receipts as proof.
#7 |
Off Topic
The oil pumps on these cars are about as reliable as a 50 year old grenade. It may blow up if you sneeze at it, or you may be able to drop kick it into a wall with no problems. The others I've heard of breaking all broke randomly as well.
#8 | |
Yep, the mechanic said he hadn't seen it before, but he also said they didn't get many BRZs in. I put another post on the Issues board for the technical discussion.
When people kept saying it was stupid, I remained fairly quiet and figured, "We'll see." |
| The Following 6 Users Say Thank You to extrashaky For This Useful Post: | daiheadjai (02-07-2017), Hoahao (02-08-2017), Kimsey47 (02-07-2017), soulreapersteve (02-07-2017), strat61caster (02-06-2017), Tcoat (02-06-2017) |
#9 | |
#10 |
Drives: Full race 4cyl boxer
I have 45,000 miles and the extended warranty.
I also pay the extra $$ to have the DEALER do my oil changes JUST so it is on record (in their system) as being done by a competent mechanic. I am 100% competent (more-so than most of their techs) but I want ZERO questions if it ever comes up.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
#11 |
Depends on how you look at it. You're thinking cost over time. I'm thinking cost per mile. Remember, when I bought mine, I was driving almost as much as you were. I put 30K miles on it in the first 12 months before my job changed. Even racking up the miles that fast, the risk still seemed to justify it.
#12 |
You could have used this as an opportunity to do a LS1 swap.
Now you are stuck with the stock engine for another 60k miles. |
| The Following 8 Users Say Thank You to funwheeldrive For This Useful Post: | Dadhawk (02-06-2017), Ghost of Akina (02-07-2017), gramicci101 (02-06-2017), PandaSPUR (02-07-2017), Summerwolf (02-07-2017), TMXSTAR (02-07-2017), ToySub1946 (02-06-2017), Yardjass (02-07-2017) |
#13 | |
#14 |
Extended warranties are basically an over/under bet, and the house almost always wins. @extrashaky, I'm glad the gamble worked "to your benefit" this time.
All I can add is my personal experience. I have never purchased an extended warranty, but have tracked it against issues. Maybe I'm the other side of the exception, but I have never had a repair that would have been covered under an extended warranty period on the 8 or so cars I've purchased where that would have been available. So, if we take the $1,500 cost that is $12,000 I would have "thrown away". The one time I did have an engine completely disintegrate in a car it was under the standard warranty, and well within it. 1998 Chevy Astro threw a rod and made a hole in the crankcase the size of a baseball. New engine went almost 200,000 miles and was still running when I got rid of it.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| Extended warranty? | dgcam55 | Issues | Warranty | Recalls / TSB | 33 | 12-12-2015 03:56 PM |
| Warranty Work With Mods + Extended Warranty | Wyattkb | Issues | Warranty | Recalls / TSB | 3 | 01-20-2015 04:23 PM |
| Extended Warranty? | huangddg84 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 33 | 11-03-2014 01:50 PM |
| extended warranty? | lionbacker54 | BRZ First-Gen (2012+) — General Topics | 28 | 05-27-2013 10:44 AM |
| Extended Warranty? | FoxtrotRomeo-Sierra | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 05-31-2012 01:02 PM |
