Old 09-22-2016, 08:48 AM   #1
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
BRZ 2017 Aluminum intake! MT6
So Subaru killed the plastic intake for a real aluminum intake for the 201MT6 only. I've been eye balling FBM intake for a year now to add to my motorbuild but Subi has really brought us MT guys an aluminum factory. I can see the factory plastic intake is pressed together and time will kill it sooner than later. MAP location is directly in front of the TB.
Subi knows MT6 guys are boosting?
Any thoughts? Go...
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 09-22-2016, 09:40 AM   #2
Amputechture
Drives: 2014 BRZ
Cool! Wonder the reason for the battery relocation.
Amputechture is offline   Reply With Quote
The Following User Says Thank You to Amputechture For This Useful Post:
Traktor (12-26-2016)
Old 09-22-2016, 09:44 AM   #3
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
The pic shows a RHD car. It gets swapped with the brake booster too.
Jesse36m3 is offline   Reply With Quote
The Following 3 Users Say Thank You to Jesse36m3 For This Useful Post:
AJPG (11-05-2016), Amputechture (09-23-2016), Freeman (09-23-2016)
Old 09-23-2016, 01:02 PM   #4
Amputechture
Drives: 2014 BRZ
Stupid me. Interested to see if there is anything to be squeezed out of these. I know Velox didn't have much luck with their prototype manifolds. MAP sensor has to be rescaled I'm assuming?
Old 09-23-2016, 01:05 PM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Depending on the cost I want one for my '13 but I would have to paint it black. I think the red looks awful lol
Old 09-23-2016, 01:06 PM   #6
steve99
Drives: FT86
MAP is pressure sensor
MAF is air flow, its in same location
will be ok
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Boofneenee (10-26-2016), Guff (09-24-2016)
Old 09-23-2016, 01:26 PM   #7
Amputechture
Drives: 2014 BRZ
will be ok
Gotcha, wasn't sure how that worked. My line of thinking was that relocating the map sensor in a larger area would cause it to read low temporarily until the larger ID pressurized.
Old 09-23-2016, 01:41 PM   #8
steve99
Drives: FT86
MAP sensor calibration in tune is just two numbers an offset and a pressure/volt .
like
bar/volt .833
offset (bar) .012
where the MAF you actually scale the sensor volts against air flow at a large number of points
JohnJuan (09-23-2016)
Old 09-23-2016, 02:14 PM   #9
JD001
JD001's Avatar
Drives: Subaru BRZ
I have a 2014 RH drive with the battery in the same location.
Old 09-23-2016, 11:31 PM   #10
Amputechture
Drives: 2014 BRZ
I know these are so new to market but has anyone been able to tinker with these yet? Zach or Drift office Bob maybe? : )
Old 09-24-2016, 10:33 AM   #11
GsxrMe
GsxrMe's Avatar
I got the local subi dealer have 1 on order for me. 3 to 4 weeks. Just over $300.
2014 Subaru BRZ
The Following User Says Thank You to GsxrMe For This Useful Post:
FRS_Ken (12-05-2016)
Old 09-24-2016, 11:48 AM   #12
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I wonder if the intake elbow swaps over too...
-Josh
Old 09-24-2016, 09:16 PM   #13
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
Wouldn't this retain more heat than the plastic intake manifold? Are there reported failures of the plastic intake manifolds?
skylinekin is offline   Reply With Quote
Old 09-24-2016, 09:29 PM   #14
wbradley
Sarcastic SOB
wbradley's Avatar
Plastic is more of an insulator so the intake charge might be less vulnerable to heat transfered from high under hood temps with plastic vs aluminum. With headers it gets hot under there. Proof is the outdoor temp gauge reads far above actual outdoor temp simply as a result of the sensor location in the front bumper area.
Whether this is significant...well, Subaru does employ a lot of engineers so I doubt it in most applications. It is a nice STI looking intake though and certainly one of the added appeals of buying the newest model.
The only negative I can think of with the plastic one is that some people might accidentally break off the clips on the intake cover when accessing the intake manifold inlet from the PCV while installing a catch can. I did, but made a little clip from stainless sheet metal and glued it in place of the broken clip.
sales@delicioustuning.com
New Carbing Aluminum Air Intake Suction Kit Pekingduck Engine, Exhaust, Bolt-Ons 11 11-28-2016 07:16 PM
FS: Lower control arm ssyed Canada Classifieds 24 10-30-2016 06:13 PM
PRICE DROP New Fujitsubo Authorize-R Catback Exhaust & Carbing Aluminum Air Intake Pekingduck Engine, Exhaust, Bolt-Ons 7 07-15-2016 06:30 PM
?? about the 2017 changes. UAmach1 Scion FR-S / Toyota 86 GT86 General Forum 26 03-28-2016 08:55 PM
GenomeTuning Aluminum Intake Plugs genometuning Engine, Exhaust, Bolt-Ons 58 06-23-2014 07:43 PM
