Old 09-06-2016, 02:32 PM   #1
Gray Fox
Gray Fox's Avatar
Reverse Lockout not Engaging
Hey guys! So, I just got myself a used BRZ and am super happy with it. However, I'm not sure what the previous owner did, but I noticed when trying to shift into first gear, there was nothing preventing me from shifting into reverse. I don't even have to pull up on the "ring" of the shifter; it just slides all the way over. Now, this is not only incredibly frustrating, but also very dangerous, and I was hoping that you bright folks could help me figure out how to fix this issue, preferably without buying an aftermarket shifter. Thanks in advance!
Gray Fox is offline   Reply With Quote
Old 09-06-2016, 02:42 PM   #2
everythingsablur
everythingsablur's Avatar
Drives: 2016 Scion FR-S RS 2.0
Previous owner probably fiddled with the reverse lockout pin so that it is always in the "open" position. Depending on how it was done, it should be reversible, or at the very least put it back into a lockable position.
Can you contact the previous owner, or did you get this from a dealer? You might need to do a little light disassembly to see what's been done.
2016 Scion FR-S Release Series 2.0 #170/1000
everythingsablur is offline   Reply With Quote
The Following User Says Thank You to everythingsablur For This Useful Post:
humfrz (09-06-2016)
Old 09-06-2016, 02:46 PM   #3
markitect
Drives: Scion FRS
Sounds like they took an aftermarket lockout off, and didn't put it back together right. There is a pin that attaches the collar to a cable, they might have just plain not installed it. You can use aftermarket installation instructions for reference. http://www.ft86club.com/forums/showthread.php?t=69811
markitect is offline   Reply With Quote
The Following User Says Thank You to markitect For This Useful Post:
humfrz (09-06-2016)
Old 09-06-2016, 04:06 PM   #4
Welcome to the forum @Gray Fox ..........
Yep, a couple of good suggestions up above......
Old 09-06-2016, 04:24 PM   #5
jasonojordan
Drives: 2013 satin white brz limited
Also a scary 3rd option. This happened to my old wrx with a sti swap after I sold it to a friend. Couple months after it stopped needing to use the lockout collar to go into rev the transmission failed. Not sure what all failed in it but yea.
jasonojordan is offline   Reply With Quote
Old 09-06-2016, 04:37 PM   #6
FX86
Frank Jaeger!
Old 09-06-2016, 11:36 PM   #7
Gray Fox
Gray Fox's Avatar
Thanks so much for the input guys! I bought it from a private seller, so I'll ask him if he knows anything about this. Seems like I'm going to have to disassemble this guy tomorrow to get to the issue. I'm hoping and praying that it isn't a sign of a transmission failure... fingers crossed! I'll update when I find out what's up. You guys are great
The Following User Says Thank You to Gray Fox For This Useful Post:
everythingsablur (09-07-2016)
Old 09-06-2016, 11:49 PM   #8
It's a really simple mechanism. Intuitive once you get the boot off.
Old 09-07-2016, 12:53 AM   #9
Hey @Ultramaroon ....... easy for you to say .........
@Gray Fox , I suggest you read up a bit before tearing into it, this will get you started ......
[ame="https://www.youtube.com/watch?v=XSeKM6WxlE0"]Installing Raceseng Reverse Lockout and Ashiko/Slammer Gear Knob - YouTube[/ame]
everythingsablur (09-07-2016), Ultramaroon (09-07-2016)
Old 09-07-2016, 03:42 PM   #10
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
It's not!
billwot is offline   Reply With Quote
Old 09-07-2016, 04:21 PM   #11
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
That video will not help, the piece he needs to look at is under the shift boot (that drift pin does not need to be removed). @Ultramaroon is correct, it really is simple when you see it. It's just a metal plate with 2 bolts keeping it in place, if you loosen the bolts the plate can slide back and forth for adjustment. If it's all the way to the left (or removed) you will have no reverse lockout.
Scenic Driver is offline   Reply With Quote
The Following 2 Users Say Thank You to Scenic Driver For This Useful Post:
Old 09-07-2016, 04:41 PM   #12
I didn't watch the vid.
If I may tack on to your more helpful post, OP, align that plate so the lockout centers the gearshift in both first and second gear gates. Make sure it's not cockeyed.
Scenic Driver (09-07-2016)
Old 09-07-2016, 05:56 PM   #13
Oh, good to know.
Thanks for the correction and additional information.....
@Gray Fox sorry I misled you .....my bad .......
Old 09-07-2016, 10:27 PM   #14
Gray Fox
Gray Fox's Avatar
Thanks for the help, guys! I got to the root of the problem. It was indeed the shift lock plate. Previous owner had it aligned too far to the left. Easy fix!
Oh, good to know.
No worries @humfrz, thanks for helping
The Following 2 Users Say Thank You to Gray Fox For This Useful Post:
everythingsablur (09-07-2016), humfrz (09-07-2016)
WTB: OEM Reverse Lockout Ethereal05 Want-To-Buy Requests 2 07-18-2016 04:01 PM
wtb oem reverse lockout Vincenttam Want-To-Buy Requests 0 02-09-2015 05:41 AM
Reverse lockout? MrMarinakos Cosmetic Modification (Interior/Exterior/Lighting) 0 04-28-2014 08:47 PM
FS: raceseng reverse lockout red White0utFrs Interior Parts (Incl. Lighting) 3 04-12-2014 01:15 PM
