Old 05-20-2016, 10:35 AM   #1
BDKane01
BDKane01's Avatar
Drives: 2016 Subaru BRZ Limited CWP MT
Pedal dance not working. *issue resolved*
'16 BRZ limited. Car was warmed up, on a flat empty parking lot, and I followed the procedure. You can see one of my attempts below.
I'd like to be able to do this for a novice autoX event coming up.
[ame]http://youtu.be/zKofpVGY58E[/ame]
Hindsight is 20/20
BDKane01 is offline   Reply With Quote
Old 05-20-2016, 10:41 AM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Interesting, something is preventing the diagnostic mode from kicking on. You don't have any radiator or coolant mods do you?
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
BDKane01 (05-20-2016)
Old 05-20-2016, 10:44 AM   #3
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
hmm..I dont know but if you buy OFT and you can do this by one touch lol
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Old 05-20-2016, 10:57 AM   #4
BDKane01
BDKane01's Avatar
Originally Posted by FRSBRZGT86FAN View Post
Interesting, something is preventing the diagnostic mod from kicking on. You don't have any radiator or coolant mods do you?
It's a brand new unmolested limited.
I'd rather not. I haven't even made my first payment yet.
Hindsight is 20/20
The Following User Says Thank You to BDKane01 For This Useful Post:
Ultramaroon (05-20-2016)
Old 05-20-2016, 11:09 AM   #5
FirstWinter
Drives: Car
Try it with the handbrake already engaged then go from there? That's what I usually do. If it doesn't work I usually just spazz out with both of them and through trial and error it usually works.
FirstWinter is offline   Reply With Quote
The Following User Says Thank You to FirstWinter For This Useful Post:
Old 05-20-2016, 11:15 AM   #6
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
1. Start engine with hand and foot brake engaged
2. 2x foot brake & hold
3. 2x hand brake & hold
4. 2x foot brake
Works for me. Hand brake up on engine start.
murdoc is offline   Reply With Quote
The Following User Says Thank You to murdoc For This Useful Post:
Old 05-20-2016, 11:22 AM   #7
zc06_kisstherain
Drives: SWP BRZ
Ok
mixtape (05-20-2016)
Old 05-20-2016, 11:25 AM   #8
BDKane01
BDKane01's Avatar
4. 2x foot brake
Ok. So start with them engaged. Then what? Release both of them and start the process?
This is getting confusing.
Hindsight is 20/20
Old 05-20-2016, 11:27 AM   #9
BDKane01
BDKane01's Avatar
Ok
I just plan to save up and get some wheels. I may get the tablet down the line. I would just like to see if I can do this without any additional software or etc
Hindsight is 20/20
Old 05-20-2016, 11:33 AM   #10
zc06_kisstherain
Drives: SWP BRZ
No problem at all everyone has their own preference
Old 05-20-2016, 11:47 AM   #11
FirstWinter
Drives: Car
start with them engaged and just start the process. don't drop the handbrake at the start wait until the step where you have to
Old 05-20-2016, 12:20 PM   #12
BDKane01
BDKane01's Avatar
This is not work either...hmm
Hindsight is 20/20
Old 05-20-2016, 12:46 PM   #13
FirstWinter
Drives: Car
I don't remember the original post (and a quick search didn't find it...), but someone had posted up a sequence to turn off additional electronics in the car. The sequence is as follows:
- Turn on the car. The car must be FULLY warmed up. You must do the entire sequence within 30 seconds of starting the car.
- Pull the e-brake 3 times. Hold/lock the e-brake on the 3rd pull.
- Press the brake pedal 3 times. Hold it down the third time.
- Pull the hand brake 3 more times. Hold/lock the hand brake on the 3rd pull
- Press the brake pedal 2 more times.
- On the last press of the brake pedal, two yellow lights should have come on.
I purposely used staggered brake compounds to test whether the brake dance does anything; here are my conclusions.
- The pedal dance eliminates electronic brake force distribution.
- The pedal dance also eliminates the "panic brake" function.
- I tried trail braking mid-turn with the "normal" electronic aids off, but without the pedal dance. This resulted in a spin; the car literally locked up the rear brakes. My speculation is that the car recognized the fronts locking up, and put additional force on the rear brakes. The problem here, is that I had purposely put a much lower friction pad in the back, so it kept sending more and more brake pressure to the back, until it just locked. Once it locked, it stayed locked, even though I was not stepping on the brakes.
- I tried this again a few more times. Same result.
- I then tried again, but with a rear brake bias. This time, pressing on the brakes mid-turn or trail braking always resulted in the car straightening out and/or plowing.
- With the pedal dance, I can trail brake or brake in the middle of a turn for rotation just fine, regardless of pad setup.
Moral of the story: if you're driving on a track or at an autocross, do the pedal dance! (Remember, ALL aids will be off)
All testing was done on a closed course, at the "Balcony", courtesy of Willow Springs Raceway.
*edit*
From another post:
Just follow CSG Mike's post. If you're still having problems I'll film myself doing it later today and upload it.
Old 05-20-2016, 12:50 PM   #14
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Or fix it with this.
http://www.beastronix.com/
2superblus is offline   Reply With Quote
The Following 2 Users Say Thank You to 2superblus For This Useful Post:
Beastronix (05-22-2016), CSG Mike (05-20-2016)
Pedal dance Simqc Issues | Warranty | Recalls / TSB 6 05-22-2016 09:56 PM
OFT - Pedal Dance Mode. RustySocket Software Tuning 2 08-24-2015 06:55 PM
Is there a way to turn all the aids off w/o doing the pedal dance? D K Tracking / Autocross / HPDE / Drifting 4 07-07-2014 09:16 AM
Pedal Dance Device robot Tracking / Autocross / HPDE / Drifting 3 01-10-2014 09:26 AM
Gas pedal dance brake thing.??? gdrider77 Software Tuning 9 12-22-2013 08:43 AM
