Old 05-06-2016, 12:00 PM   #1
LWAA
Drives: Subaru BRZ
Borla Muffler question
Can anyone tell me if this Borla Muffler has the right connections (i.e. input/output on one side and output on the other) for my BRZ?
https://www.partsengine.ca/borla-dua...7-p-57561.aspx
thanks,
2015 BRZ Sport-Tech A/T
(apologies for any wrong terminology – upgrade neophyte here!)
LWAA is offline   Reply With Quote
Old 05-06-2016, 02:05 PM   #2
Well, as long as you have to weld a flange on the inlet side, I reckon it would come close enough.
Then, where are you going with it .......??
If you're "building" a custom muffler system, it seems to me that $400 is an expensive starting point ......
Old 05-06-2016, 03:52 PM   #3
LWAA
Drives: Subaru BRZ
I have no idea - I'm going by the advice of a car guy I work with who would be doing the mod. I have absolutely no clue about modding.
I was going the Invidia N1 route, but he steered me toward this.
Old 05-06-2016, 04:00 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Short answer: no.
Long answer: you're better off getting a pre-fabbed bolt-on exhaust if you have no idea what you are doing.
-alex
Old 05-06-2016, 04:34 PM   #5
Teseo
Drives: frs
They are the same size. But for the money you can get better exhaust perfectly bolt on without custom work. Do you want an axleback or catback?
Old 05-06-2016, 07:38 PM   #6
LWAA
Drives: Subaru BRZ
Axleback I think. Bolt on would be perfect. Any suggestions for the sound I'm after?
Old 05-06-2016, 09:21 PM   #7
LWAA
Drives: Subaru BRZ
Sounds very nice!
Old 05-07-2016, 09:57 AM   #8
LWAA
Drives: Subaru BRZ
That's sounds great and the price isn't bad too. Thanks for the help!
Old 05-13-2016, 08:27 AM   #9
LWAA
Drives: Subaru BRZ
I got the borla but it didn't come with a gasket. Before I remove the existing exhaust, can anyone tell me if the stock gasket is a metal one I can easily reuse or if I need to go buy a new one?
Old 05-13-2016, 09:18 AM   #10
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Grab a new one at a dealer.
JazzleSAURUS is offline   Reply With Quote
Old 05-13-2016, 11:48 AM   #11
Gunman
Drives: 2019 Mazda Miata RF
Borla makes two axle back bolt on mufflers, I'd just get one of those, rather than try to fab the same thing.
http://www.borla.com/products/frs_br...rt__11839.html
This is the Scion option, which is euro legal:
http://www.borla.com/products/brzgt8...__1014034.html
Old 05-13-2016, 12:08 PM   #12
swarb
The problem with custom exhaust is tip alignment can be very difficult to get perfect if you are picky. Mandrel bends either require lots of cutting/welding/labor and/or an expensive mandrel bender. $400 is cheap for custom mandrel bent exhaust. Your guy is probably offering crush bent. You are better off getting a pre-fabbed exhaust that is stainless, has gaskets, flanges, hangers, and fits good. Custom at $400 probably skimps on all those things except the muffler itself.
Old 05-13-2016, 12:44 PM   #13
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by new2subaru View Post
Here's another you may like then.
Greddy Axleback.
There no real need to do anything custom with so many options for bolt ons IMHO.
I believe the SP elite is has been discontinued as I tried finding where to buy it and couldn't awhile back, the clone of it is the topspeed pro 1 axleback
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
new2subaru (05-13-2016)
Old 05-13-2016, 08:15 PM   #14
LWAA
Drives: Subaru BRZ
A friend and I put the Borla axleback on tonight. It didn't take long and sounds amazing!
I got it at an amazing price from ft86motorsports, way cheaper than anyone else.
Borla uel + dual muffler delete Gt86_nick Engine, Exhaust, Transmission 16 06-19-2014 03:40 PM
What muffler to purchase for no-name setup (borla?) jbixel Engine, Exhaust, Transmission 4 10-23-2013 01:43 AM
Borla header with muffler delete WhiteFR-S Engine, Exhaust, Transmission 21 10-17-2013 01:13 PM
Installed Borla (plus my muffler delete) WhiteFR-S Engine, Exhaust, Transmission 4 10-04-2013 10:32 PM
Muffler shop that sells/installs Borla? Skurj CANADA 0 01-24-2013 05:29 PM
