Old 04-02-2016, 10:21 AM   #1
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Brake Feel Enhancement
I'd like to firm up the brake pedal on my '15 BRZ. The plan is to install a master cylinder brace (I'm leaning Greddy) and Vorshlag (sp) braided lines. My question is which to do first. The brace seems the most likely candidate, if only because it's the least involved process. What think ye?
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 04-02-2016, 10:40 AM   #2
D_Thissen
D_Thissen's Avatar
I have a Grimmspeed MCB, stop tech stainless lines and RBF 600 and my pedal is nice and firm. I noticed the biggest change after installing the MCB though.
The Following User Says Thank You to D_Thissen For This Useful Post:
DocWalt (04-03-2016)
Old 04-02-2016, 06:19 PM   #3
Pat
Pat's Avatar
Drives: 2023 BRZ
Neither will make a big difference. Both might make a very small difference when braking very hard. Pads might also affect feel, among other things.
Old 04-02-2016, 06:53 PM   #4
ansibe
Drives: White BRZ
I use carbotech 1521 for the street with ATE dot 4. I think the brakes feel great, much better than OE. I think this is mostly about good fluid, no air in the lines, and a relatively high friction pad. The high friction pad means less pedal pressure, and therefore less flex in the entire system: lines, fluid, caliper, seals.
I run stock lines and calipers, no brake shims.
ansibe is offline   Reply With Quote
The Following User Says Thank You to ansibe For This Useful Post:
Old 04-03-2016, 09:34 PM   #5
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Master cylinder brace made the most obvious change for me with the stock pads. Changing to pads that don't easily compress (like Carbotech 1521) will make the biggest difference and you'll gain brake performance too.
The Following User Says Thank You to DocWalt For This Useful Post:
wparsons (04-04-2016)
Old 04-04-2016, 01:46 AM   #6
Knshro13
Drives: 10 series FRS
Like what everyone above said, master cylinder brace will make the most obvious difference outside of a big brake kit upgrade.
Knshro13 is offline   Reply With Quote
Old 04-04-2016, 01:07 PM   #7
CSG Mike
CSG Mike's Avatar
What about deleting the brake booster?
Old 04-06-2016, 11:33 AM   #8
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
I was blown away with how much improved the pedal feel became with my Grimspeed MCB.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Brake firmness/pedal feel Hyper4mance2k Suspension | Chassis | Brakes -- Sponsored by 949 Racing 40 05-22-2019 12:22 PM
New Ferodo Brake Pads Feel Sticky kodyo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 04-30-2018 03:22 PM
Disappointed brake pedal feel, what am I doing wrong ZionsWrath Other Vehicles & General Automotive Discussions 12 11-15-2013 02:03 PM
why does the BRZ's brake feel firmer after a hard stop? chenshuo BRZ First-Gen (2012+) — General Topics 12 05-29-2013 05:32 PM
Odd brake pedal feel, fade? yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 09-11-2012 12:29 PM
