Old 02-03-2016, 01:46 PM   #1
ikeryder13
Drives: 2013 GBS BRZ
car jerks to right on deceleration
When I am on the freeway and I decelerate the car pulls to the right, just like a quick jerk... then it straightens out... I have had the car alignment done, tires balanced... what could be causing this?
ikeryder13 is offline   Reply With Quote
Old 02-03-2016, 01:48 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
brakes sticking?
Old 02-03-2016, 01:52 PM   #3
ikeryder13
Not that I notice... it sorta just pulls that way
Old 02-03-2016, 01:55 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
any mods?
Old 02-03-2016, 02:06 PM   #5
Have you checked the tires pressures ... ??
Mr.ac (02-04-2016)
Old 02-03-2016, 02:08 PM   #6
ikeryder13
Nothing but exhaust components... yes I checked the pressure
Old 02-03-2016, 02:22 PM   #7
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I would go back to that shop and re-check
Old 02-03-2016, 03:13 PM   #8
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Is the road a nice flat surface? Could just be road crown?
Cockatoo is offline   Reply With Quote
Old 02-03-2016, 03:18 PM   #9
ikeryder13
I got 1 new tire but it's on the rear not the front... the road is any freeway lol
Old 02-03-2016, 04:20 PM   #10
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Decelerating, you mean when you get on the brakes the car pulls to the right? Of so it sounds like the front right brake is doing more work causing the car to pull that way. Maybe visually inspect both brakes for wear, check brake fluid, bleed the brakes.
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 02-03-2016, 04:32 PM   #11
ikeryder13
No just letting my foot off the gas... like as soon as I do it it pulls to the right
Old 02-03-2016, 05:19 PM   #12
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
are you sure you're just not subconsciously doing it? I mean I've seen weirder things being done without the person knowing
fumanchu1 is offline   Reply With Quote
Old 02-03-2016, 05:44 PM   #13
Are the tires on your car directional .. ??
Old 02-03-2016, 05:49 PM   #14
jbailey8748
Could be a brake dragging. Or loose ball joint, tie rod end, wheel bearing. Get it in the air and start spinning things and wiggling things.
Car jerks when shift from neutral to 1st Vincent Nguyen Engine, Exhaust, Transmission 26 01-22-2016 07:05 AM
Engine/Drivetrain Squeak Upon Deceleration in Gear - 2013 M/T FR-S Purdue FR-S Issues | Warranty | Recalls / TSB 7 07-15-2015 08:47 AM
Jerks phobos512 Mid-Atlantic 18 05-17-2014 10:09 AM
BMW drivers really are jerks...lol Lonewolf Other Vehicles & General Automotive Discussions 34 08-25-2013 11:12 AM
Odd noise on deceleration Dipstik-sportech Engine, Exhaust, Transmission 7 08-18-2013 10:42 AM
