Old 01-16-2016, 05:04 PM   #1
kravi
Drives: Subaru BRZ
brz - idle is hunting
So my idle was acting squirrelly today. I noticed it stopped at a red light. Would sit at 750 for a few seconds, start to drop, the car would vibrate like it was about to stall (at around 500), then it would bounce up to 900 and slow down to 750. Rinse and repeat. This was happening on the way to my destination (where I spent an hour and a half). Also happened on the way home after the car had warmed back up again.
The engine was warmed up by that point, gas is always 93 octaine (from Shell). Outside temperature was around 50 degrees. Car is at 35.5k miles.
Cheers,
--kravi
kravi is offline   Reply With Quote
Old 01-16-2016, 05:29 PM   #2
Lelantas
Lelantas's Avatar
Drives: '15 BRZ ISM
What model year? AT or MT? Is your AC on and/or is the knob set to defrost? Multiple owners have reported these issues when the AC compressor kicks in, although I personally haven't had the problem occur.
If the problem is occurring frequently on an earlier model-year BRZ, you can take it in to the dealer to get an ECU update that resolves the issue.
Lelantas is offline   Reply With Quote
Old 01-16-2016, 06:06 PM   #3
bottle
Used to happen to me on a MY14 BRZ. Believe there is a TSB fix for it if it's MY13 or MY14 up to a certain VIN.
Click Here
bottle is offline   Reply With Quote
Old 01-16-2016, 07:01 PM   #4
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
Old 01-16-2016, 07:08 PM   #5
86kahl
86kahl's Avatar
Drives: whiteout, dark tint
Same situation occurs for me and I have the updated ECU on MY13 and it still happens fairly often, but it's never stalled on me, feels close to it at times tho. I was told it has to do with the DI system cycling between direct and port at idle to burn off carbon build up. I know that carbon build up is a problem for DI only systems so it's not an unreasonable solution.
86kahl is offline   Reply With Quote
Old 01-16-2016, 07:17 PM   #6
kravi
Drives: Subaru BRZ
Thanks, this is indeed an MY13 MT limited. I need to take it into the dealer for the frozen window TSB fix, so I might as well do both at the same time.
Obliged!
--kravi
Old 01-16-2016, 07:28 PM   #7
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Cheers,
--kravi
MY x<2014, go get reflash on ecu. Check air filter, maf(?) sensor.
Also, was your a/c on?
Old 01-16-2016, 09:50 PM   #8
kravi
Drives: Subaru BRZ
Heat was on, not AC. I just replaced my air filter about 2 months ago. Not sure about checking the MAF sensor, I'm not getting any alerts, and not sure what to look for to see if it is borked
--kravi
Old 01-16-2016, 11:14 PM   #9
Packofcrows
--kravi
Lol wipe/pressure air blow into it. I use vaccum speed on car engine components
Old 01-17-2016, 09:37 PM   #10
kravi
Drives: Subaru BRZ
Obliged! I'll check tomorrow. Snowed today, just enough to keep me from wanting to hang around outside.
--kravi
Lightweight flywheel, now struggles to start and revs hunting ChrisD Engine, Exhaust, Transmission 14 07-30-2015 06:53 PM
Idle hunting on park WishIhad86 Issues | Warranty | Recalls / TSB 7 04-12-2015 01:19 PM
Texas Job Hunting/Networking Thread nlamon33 Southwest 41 10-29-2014 05:02 AM
Hunting Rear Diffuser ROCKETS86 Cosmetic Modification (Interior/Exterior/Lighting) 13 11-13-2013 10:16 PM
Hunting discussion/pictures thread monjorrow Off-Topic Lounge [WARNING: NO POLITICS] 4 12-12-2012 07:37 PM
