Old 06-05-2012, 05:36 PM   #1
96z2
Drives: N/A
How to remove third brake light (to tint back window)
How is the third brake light attached and how to I remove it? Through the trunk?
96z2 is offline   Reply With Quote
Old 06-05-2012, 05:48 PM   #2
Mari0
Car Enthusiast
Mari0's Avatar
Drives: tC 05 & 07, Rav4
edit: nvm
Mari0 is offline   Reply With Quote
Old 06-05-2012, 06:00 PM   #3
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
my tint guy just worked around it, theres quite a bit of room between the light and the glass - just need a longer reach squeegee and a bit of reach skillz.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 06-05-2012, 06:20 PM   #4
luxmn
First FR-S
Drives: Whiteout MT FRS
piggy back question, is it legal to remove that light and install a light at the lower rear reflector?
luxmn is offline   Reply With Quote
Old 06-05-2012, 06:21 PM   #5
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
^ Depends on your state. In most cases, the third brake light needs to be higher then the other two lights.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 06-05-2012, 06:21 PM   #6
old greg
Rocket Surgeon
Drives: PSM GGA OMG
That's the first place I would look.
old greg is offline   Reply With Quote
Old 06-05-2012, 06:29 PM   #7
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
The bolts arent accessible from the trunk. The tint shop had to remove the rear seats and side panels to get the rear deck out of the way.
Parting out HERE
Old 06-05-2012, 06:29 PM   #8
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Originally Posted by Mari0 View Post
You don't need to remove it to tint the back window (99.9% sure) since it's on the inside
edit: found a picture
Wait wha!? The tint is applied on the inside.
Off Topic- On the FR-S is the defroster in between the glass or applied on the inside were you can feel it? Reason why I asked was when I got my Integra tinted and wanted to remove it later on, the adhesive pulled off some of the rear defroster material and didn't fully work in those areas.
Old 06-05-2012, 08:07 PM   #9
Hanakuso
In most states it's illegal to have it that low. It might bring more attention to you if you move the light to that lower position compared to just having 2 rear brake lights. They might not even notice you're missing a 3rd brake light if that makes sense.
I never got a ticket for running only 2 brake lights on my S2000 for a good 2-3 years.
Hanakuso is offline   Reply With Quote
Old 06-06-2012, 12:54 AM   #10
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
I think it has to be at a certain distance from the ground. That is no way high enough at the lower area.
DrDuquette is offline   Reply With Quote
Old 06-07-2012, 04:14 AM   #11
keithbribac
Drives: Gray
the third brake light actually comes off, but just the top part and not the base. my tint guy just slowly pulled and wiggled it back.
keithbribac is offline   Reply With Quote
Third brake light...(top mount) Slide Cosmetic Modification (Interior/Exterior/Lighting) 103 02-22-2017 02:47 PM
"back-seat-remove" option. Z_Rocks Scion FR-S / Toyota 86 GT86 General Forum 53 06-25-2013 04:24 AM
Window Tint IceCreamMan Cosmetic Modification (Interior/Exterior/Lighting) 46 09-22-2012 02:43 PM
Window tint in MI eikond Great Lakes 4 06-01-2012 01:59 AM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 03:53 PM
