Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 10-13-2015, 06:54 AM   #1
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Exhausts
I am looking at the tons of options the EU/UK and USA have available... and looking at what might be affordable for us in SA.
I am looking for a full system - equal length headers back.
I am probably going to supercharge it in future, so I am not concerned with a 2hp gain from one brand over another. I do want a nice smooth sound though.
Anyone have facts/prices/good contacts?
Importing stuff from overseas is crazy expensive!!!
I love the HKS header-back, but at around R30-40k before shipping it's simply unaffordable.
86 South Africa is offline   Reply With Quote
Old 10-13-2015, 07:23 AM   #2
Freedom
Freedom's Avatar
Drives: PEARL WHITE GT86 TRD
Rob Green Motorsports (RGM), they do superchargers and custom exhaust for roughly R90 000.
Do a bit of searching on the Africa thread for exhaust options, this question has been asked a few times before. Most of us have gotten the BRZ exhaust.
For quality headers you will unfortunately have to import.
Freedom is offline   Reply With Quote
The Following User Says Thank You to Freedom For This Useful Post:
86 South Africa (10-14-2015)
Old 10-13-2015, 08:18 AM   #3
FT_86_SM_GP
FT_86_SM_GP's Avatar
Drives: Lawn moweR
Agree with Freedom on the cat-back (BRZ De Graaf)
On a side note - I recently heard a RGM supercharged BRZ with the DeGraaf catback (Probably had de-catted stock header), sounded pretty decent.
(First time I heard a SC BRZ in person, heard allot of RGM 86's, but most of them had the stock 86 exhaust).
Any specific reason why you want a EL header ?
Where are you based? KZN?CPT?JHB?
FT_86_SM_GP is offline   Reply With Quote
The Following User Says Thank You to FT_86_SM_GP For This Useful Post:
Old 10-13-2015, 08:23 AM   #4
Sporran
Drives: Metallic Grey 86
I second what Freedom has said. Rather wait until you're ready to fit your supercharger then speak to RGM and get both - they'll be matched and dyno tuned so you'll be sure they'll work well together.
You could opt for just an exhaust but you'd need a tune to optimise it and if you're already considering the FI route why not just do them together?
Sporran is offline   Reply With Quote
Old 10-14-2015, 01:28 AM   #5
Dammod
Dammod's Avatar
Drives: .
Headers and a tune make a world of difference, ask @FT_86_SM_GP and check out a few of his track videos and dyno results:
http://www.ft86club.com/forums/showp...&postcount=158
http://www.ft86club.com/forums/showp...&postcount=155
I only made 15kw less then a RGM Supercharged GT86 a while back at a Cape Town dyno day when I was still on a earlier revision tune making less power then I am now.
I had a BRZ Exhaust (obviously :-)) Phoenix Performance tune, on pump fuel.
"Some will follow your footsteps, easier than they will your advice."
Dammod is offline   Reply With Quote
The Following User Says Thank You to Dammod For This Useful Post:
Old 10-14-2015, 04:51 AM   #6
steve99
Drives: FT86
have a read of the Basic Bolt on Mods Giude link below
if you want cheap option see if you can get someone to remove the cat in header and weld in a piece of pipe, dont just knock out the cat internals.
no sure how strict they are on cats in SA, but also you could do same to secondary cat just striaght pipe it. The rest of exhaust is not that restrictive, maybe swap out the overpipe of get one made as it necks down in places.
if you remove primary cat you will likely get cel code p0420, you can try o2 spacer in second o2 sensor but a tune is much better option especially on your crappy fuel.
if your going to the expense of a supercharger you probably want to be running about 7 to 9 psi, some of the kits running 4 to 6 are not much better than a NAcar runnig an exhaust and tune.
The Following 3 Users Say Thank You to steve99 For This Useful Post:
86 South Africa (10-14-2015), sav (12-09-2015), ShaunWRX (10-14-2015)
Old 10-14-2015, 04:31 PM   #7
86 South Africa
EL for sound and smoother exhaust flow.
Based in JHB.
Been to RGM and not a fan to be honest. His exhaust didn't look like much more than some welded steel (sounds harsh I know). Not convinced it's properly tested and designed.
As for the FI. Vortech is nice but I'm going edelbrock when I'm ready.
Old 10-15-2015, 08:06 PM   #8
steve99
Drives: FT86
if you have not seen this, results for gutted stock cat, would be better if cat was cut out and pipe welded in like example later in thread see below, dyno in that thread for just the insides knocked out of cats, not pipes welded in
http://www.ft86club.com/forums/showthread.php?t=96235
86 South Africa (12-08-2015)
Old 10-26-2015, 03:56 AM   #9
Rossi
Drives: Toyota 86
As it is happening at Powerflow Midrand having a muffler delete done will keep the updates coming and a Gopro Vid of the sound[Name:  ImageUploadedByTapatalk1445846171.261010.jpg
Size:  287.1 KBATTACH]123591[/ATTACH]
Rossi is offline   Reply With Quote
The Following 3 Users Say Thank You to Rossi For This Useful Post:
86 South Africa (10-28-2015), Dammod (10-26-2015), ShaunWRX (12-09-2015)
Old 12-08-2015, 12:50 PM   #10
86 South Africa
@Rossi vids and sound?
I like driving!
Old 12-09-2015, 01:09 AM   #11
ShaunWRX
ShaunWRX's Avatar
Drives: 2014 Toyota 86
How does it sound and go now? Did you go with the y-piece split into 2 or the single exit?
Satin White Pearl 2014 Toyota 86 High
ShaunWRX is offline   Reply With Quote
Old 12-09-2015, 03:01 AM   #12
Rossi
Drives: Toyota 86
I went with the Y pipe from just behind the resonator into a dual exit with the stock tailpipes
The Following User Says Thank You to Rossi For This Useful Post:
Old 12-09-2015, 03:02 AM   #13
Rossi
Drives: Toyota 86
Vids will be posted on Sunday
86 South Africa (12-09-2015)
Old 12-09-2015, 05:15 AM   #14
ShaunWRX
ShaunWRX's Avatar
nice! thats the same setup I went with from Powerflow. Still happy a few months down the road
exhausts
Really need help with this... About Exhausts Hentai Engine, Exhaust, Transmission 5 06-15-2015 07:40 PM
Decent exhausts? NYCSicilian Engine, Exhaust, Transmission 8 03-17-2015 03:23 PM
4 exhausts, pick 1 tdotBRZ Engine, Exhaust, Transmission 7 08-08-2013 12:19 AM
Exhausts stevo_12v AUSTRALIA 142 03-04-2013 03:00 AM
Exhausts!!!!!! FT86_Zero AUSTRALIA 4 07-02-2012 11:53 PM
