Old 09-30-2015, 03:06 PM   #15
RickyBobby
Drives: 2013 Firestorm FR-S AT
I hate washing and waxing cars, and I'm too old to use a clay bar. It's been 6 months since I waxed my FRS.
I use Meguiar's Gold Class Carnauba Plus Paste Car Wax but I'm game for trying something new so I gave Griot's Garage 11075 One-Step Sealant a shot.
I got it at Advance Auto with a 25% off coupon for $13.49 + tax for a 12 ounce bottle.
Washed the car with a micro fiber mitt and car wash soap, dried it with microfiber towels, and applied the Griot's manually with a cheapy pad from Walmart. http://www.walmart.com/ip/Microfiber...-Blue/16817502 I expected it to disintegrate after a few stokes but it worked surprisingly well.
The sealant/polish is thin and goes on easy and comes off easy with micro fiber towels. It removed water stains from my trunk that vinegar and Meguiar's wax could not. I rubbed some of the Griot's between my index (trigger) finger and thumb and could not feel any abrasives, unless they are molecular size.
I like it. Now let's see how long it lasts.
RickyBobby is offline   Reply With Quote
Old 10-08-2015, 07:04 PM   #16
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
I've been using Griots stuff for a long time. Their polishes are really easy on the paint, even their most aggressive stuff.
I used the same polish/sealant on my BRZ after claying it, and it turned out really nice. With cars this new, they really shouldn't have much scratches anyway. I've used their sealant in the past and it seems to last a while. According to Griots, there isn't too much of a point of waxing over the sealant, but it wouldn't hurt. They have a really great Q&A on their website on the page for the sealant that has a lot of good info.
PERRIN_Chris is offline   Reply With Quote
Old 10-11-2015, 02:18 AM   #17
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Ever try Windex, soft dish detergent or rubbing alcohol?
Not sure which but I tried all three separately within 10min of each other and they removed some watermarks on my top and hood. I'm guessing it was the alcohol. I used dish detergent for removing wax.
Old 10-11-2015, 02:34 AM   #18
pantdino
Drives: Firestorm 2013 FR-S
Originally Posted by WhiteFRS69 View Post
in short terms
sealant is what protects the car
Wax is what gives it that glossy wet look
I believe a glaze gives it gloss by filling in microscratches.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 10-11-2015, 07:05 AM   #19
Junkman2008
Junkman2008's Avatar
Drives: 2001 Corvette Coupe
The correct statement would be that glaze gives it the ILLUSION of gloss by attempting to fill in the scratches and REDUCING light scatter. In reality, you will never have true shine or gloss until you actually REMOVE all of the paint damage.
This is why I never use a glaze.
"Marines - Making the other guy die for his country for over 200 years."
Junkman2008 is offline   Reply With Quote
Old 10-11-2015, 01:35 PM   #20
RickyBobby
Water spots are minerals left behind from hard water or rain. Calcium carbonate (aka lime) is the most common mineral left behind. You need an acid to dissolve the minerals. I don't think dish detergent, which contains alcohol, or rubbing alcohol (aka isopropanol) will work well on water spots on your car. Windex has a large amount of ammonium hydoxide in it, and may take some of the spots off. http://www.whatsinsidescjohnson.com/...-glass-cleaner
What's recommended the most to remove water spots is a solution, 1:1, of white vinegar (acetic acid) and distilled water. Some window cleaners now have vinegar instead of ammonia in them and may also work. http://www.wikihow.com/Remove-Hard-Water-Spots
I used what I had on hand, apple cider vinegar and tap water to try and remove the water spots on my car. As the article states this will not work and it did not.
Method 2 in the article uses hydrochloric acid (HCl) cleaners. I personally would not use these on my car.
Griot's Garage 11075 One-Step Sealant did remove the water spots. I don't know what's in it. I can not find an MSDS on it.
Edit: While searching for an MSDS on Griot's website I found this answer, by Griot, to a posted question: "Applying another coat of One-Step Sealant will not lengthen the longevity of protection. The sealant will still only last for about 9-12 months. Also, if you've already applied a coat of One-Step and apply another coat a few days later, you'll be removing the sealant that was previously applied due to the abrasives that are in the formula."
So, I'm assuming then it's the abrasives in it that are removing the water spots.
Old 10-11-2015, 03:08 PM   #21
Junkman2008
... So, I'm assuming then it's the abrasives in it that are removing the water spots.
Now you're figuring it out, which is why you don't use a AIO to do a man's job (i.e., what a polish or compound does).
One note though, that product lasting 9 months is a crock of BS.
Armor Sealant Stay Fresh Car Care Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 08-27-2014 05:01 PM
Questions on how to apply paint Sealant FR-BLESS Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 08-26-2014 03:43 AM
Oil pan sealant? mrk1 Forced Induction 14 03-26-2014 09:11 PM
3M paint sealant VS opti-coat denverizzles Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 07-26-2012 12:42 AM
Paint sealant for new cars kurtkarl Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 06-18-2012 10:12 AM
