Old 07-05-2015, 08:52 PM   #1
westmansweed
PULL OUT
Drives: 2015 Subaru BRZ Premium Space Grey
Manual Trans./Diff. Fluid Change.?.
i have a 2015 BRZ, i bought new last Aug. and it has about 9k on it.
Should i change the trans & diff. fluid with Motul 300 that i bought.?.
westmansweed is offline   Reply With Quote
The Following User Says Thank You to westmansweed For This Useful Post:
AZP Installs (07-15-2015)
Old 07-05-2015, 09:19 PM   #2
D_Thissen
D_Thissen's Avatar
Sure why not? You have it, may as well use it.
The Following 2 Users Say Thank You to D_Thissen For This Useful Post:
hmong337 (07-11-2015), humfrz (07-05-2015)
Old 07-06-2015, 10:50 AM   #3
JozhGoober
Drives: 2020 718 GT4, 2013 FR-S (Turbo)
Why would you buy the Motul 300 unless you were going to use it?
JozhGoober is offline   Reply With Quote
The Following User Says Thank You to JozhGoober For This Useful Post:
8R6 (07-07-2015)
Old 07-06-2015, 11:43 AM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I really think you should lay off whatever you were smoking before working on your car.
Old 07-06-2015, 11:53 AM   #5
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Obviously he is going to use it lol. I'm guessing he just wanted to know if 9k miles is the time to change it.
Old 07-07-2015, 07:01 AM   #6
504
504's Avatar
Drives: 2014 86 GTS
504 is offline   Reply With Quote
The Following User Says Thank You to 504 For This Useful Post:
WhiteFRS69 (07-11-2015)
Old 07-07-2015, 11:36 PM   #7
Euro7R
Drives: 2013 Subaru BRZ
I change my fluids more often that I should. I don't even bother following the maintenance schedule.
Euro7R is offline   Reply With Quote
The Following User Says Thank You to Euro7R For This Useful Post:
Old 07-08-2015, 12:45 AM   #8
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Originally Posted by 504 View Post
^^^^^^THIS^^^^^^
aegisdrgn is offline   Reply With Quote
Old 07-08-2015, 03:06 AM   #9
Donbrz
Drives: 2015 Brz Blue Series
Prob depends on how you drive and shifting. Have 2015 BRZ manual and changed at 7k. Significant impact on shifting smoothness. Had some metal shavings on magnetic drain plug for differential fluid, but not like others I have seen, that waited until 25-30k to swap fluids. Fluids smelled as bad as warned so be well ventilated.
Donbrz is offline   Reply With Quote
Old 07-10-2015, 02:07 AM   #10
Naco
Naco's Avatar
Drives: 2015 Steel FR-S MT
Just did the diff today and holy hell does the factory stuff stink.
Dumped mine out at 5K and it was still reddish and had only a little bit of gunk on the drain plug. Doing the trans on my next day off so we'll see what we find there.
17x9 RPF1 wrapped in 245/40 RE-71R = Mo Low Required
Naco is offline   Reply With Quote
Old 07-11-2015, 08:59 PM   #11
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
When are you supposed to change trans and diff fluids?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 07-11-2015, 09:35 PM   #12
swarb
Old 07-15-2015, 07:24 AM   #13
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
On a street driven car 30k interval for trans/diffy fluid is a good number to work off of if you are using a full synthetic like Motul Gear 300. On our Project BRZ and Spec86 Cup race car we generally will change the fluids at the beginning of track season on the Spec86 Cup car and for the Project BRZ Street/Track car we change it at the beginning and end of the track season.
The Motul Gear 300 has served us well over the years with smooth engagement and not having any issues in our transmissions. We've used it in 100s of BRZ/FRS, some of them hitting nearly 100K miles at this point.
We also offer (4) Liters (enough for Trans and Diffy) for $85 shipped if anyone is in need of it. http://store.azpparts.com/fluids/motul-gear-300-75w90/
-mike
AZP Installs is offline   Reply With Quote
Old 07-15-2015, 08:02 AM   #14
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
I changed mine earlier on to rid of the break in stuff and any metal shaving. Could be stupid but I feel better. Used motul 300 as well, then redline after a clutch install. I prefer the redline. If I had to do it again id use own stuff and call it a day, specially if you're going for short intervals.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Changed Diff/MT Trans Fluid to Motul 300 and super low MPG jfg5067 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 01-18-2016 09:24 AM
Trans/diff fluid recommendations: Motul Gear 300, Extra-S, or.. B-R-Z Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 07-03-2014 08:06 PM
Replacing Trans & Diff Fluid, Hot vs Cold BRZNutt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 12-22-2013 09:04 PM
Change trans fluid thru dipstick bigsley18 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 07-18-2013 10:16 AM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 03:11 PM
