Old 07-01-2015, 12:41 PM   #1
wbradley
Sarcastic SOB
wbradley's Avatar
Torque required for oil cooler sandwich plate and spacer??
My car is down with a damaged supercharger. In the interim I restored the pulleys to stock, plugged the PCB breather vent rerouted the air filter/intake/maf so I can move the car back into the garage. Installed the oil cooler radiator and pipes and just installed spacer/sandwich plate. Its a holiday here so I did my best with an adjustable wrench tightening it down and oiled the gaskets beforehand.
Just at idle it leaks at an alarming rate.
I will get the proper deep socket tomorrow but unsure what will be sufficient torque to seal the gaskets??
PS its from CX racing although the parts look to be high quality with what appears to be Viton gaskets.
Thanks.
Old 07-01-2015, 12:54 PM   #2
D_Thissen
D_Thissen's Avatar
What happened to the S/C?!?
The Following User Says Thank You to D_Thissen For This Useful Post:
drewbot (07-01-2015)
Old 07-01-2015, 02:22 PM   #3
wbradley
Sarcastic SOB
wbradley's Avatar
Look in Forced induction HKS owners thread details. I accidentally reversed the traction oil lines and ran it dry when installing the missing oil cooler and filter in a messed up deal on a used unit for (only $3400 ) Canadian $. Apparently the person attempting to rebuild says the unit has been tampered with previously. The bolt holding the pulley plate on was so overturned it broke off attempting to remove it.
I will likely have to buy a replacement blower a la carte. This will end up being aother $3500 unanticipated cost by the time I am done. Never will I buy anything like this used ever again.
Anyway, still waiting for helpful advice on the sandwich plate please...
Old 07-01-2015, 02:23 PM   #4
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
Perrin's calls for 25 ft/lbs.
BatStig is offline   Reply With Quote
Old 07-01-2015, 03:51 PM   #5
Cop
Cop's Avatar
Drives: 2013 FRS
Good lord that sounds horrible. Good luck with everything bud.
Cop is offline   Reply With Quote
The Following User Says Thank You to Cop For This Useful Post:
wbradley (07-01-2015)
Heads up - Oil sandwich plate protpibe Engine, Exhaust, Transmission 37 04-28-2017 04:15 PM
WTB: Quality Oil Cooler w/ thermo sandwich plate for NA application AyJay Want-To-Buy Requests 11 02-20-2015 10:16 AM
Oil sandwich plate with TRD intake? wootwoot Engine, Exhaust, Transmission 18 06-18-2014 10:17 PM
Greddy Sandwich Plate 12002802 Captain Snooze Australia Classifieds 2 07-09-2013 07:41 AM
Casting Defect Sandwich Plate Dezoris Issues | Warranty | Recalls / TSB 1 01-22-2013 03:04 PM
