| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: None
Is stabbing the throttle bad?
Yesterday, I did a test on my car to see if I had the di failure. Which I don't. I first let the car warm up to 85c, and then I stab the throttle in while in neutral at a complete stop. I just stabbed the throttle to red line three times. Is this bad? I noticed the engine somewhat bogged for a second when I did this. Note, my car is turbocharged.
Sent from my LG-D850 using Tapatalk |
#2 |
Drives: 2012 E92 M3, 2013 BRZ
depends on the type of blade you used to stab it
| The Following 20 Users Say Thank You to dpgfunk For This Useful Post: | 8R6 (06-17-2015), Andrew025 (06-18-2015), Astroboy (06-16-2015), brandonblt2 (06-18-2015), Calum (06-18-2015), civicdrivr (06-17-2015), DocWalt (06-16-2015), DustinS (06-18-2015), endless_pain (06-17-2015), GhostRai (06-18-2015), GotBRZ1691 (06-17-2015), Koa (06-16-2015), Pat.Thornton (06-19-2015), pushrod (06-18-2015), raven1231 (06-16-2015), Sportsguy83 (06-18-2015), STV3 (06-16-2015), TSwiftgavemecrabs (06-18-2015), Tye300 (06-18-2015), wparsons (06-16-2015) |
#3 |
Only users lose drugs.
Drives: All the time
I think the proper terminology would be "shanking the throttle".
| The Following 3 Users Say Thank You to venturaII For This Useful Post: |
#4 |
I would assume its not great for it but it seems to still be running so I'd just carry on
| The Following User Says Thank You to raven1231 For This Useful Post: | Astroboy (06-16-2015) |
#5 |
Señor Member
The sharper the blade the better...
| The Following User Says Thank You to STV3 For This Useful Post: | wparsons (06-16-2015) |
#7 |
Señor Member
#8 |
#11 |
Drives: '22 BRZ
No, it's not bad for it unless you do it all the time or just sit there bouncing it off the rev limiter.
| The Following User Says Thank You to DocWalt For This Useful Post: | Astroboy (06-16-2015) |
#12 |
Bilge monkey
Drives: '13 BRZ, 82 starlet
| The Following 3 Users Say Thank You to Sammakko For This Useful Post: |
#13 |
Drives: JRSC'd Asphalt FR-S
oh yeah stab the hell out of it, the more you stab it the better.
#14 |
Drives: frs
Thats the feel of turbo lag
| The Following User Says Thank You to Teseo For This Useful Post: | Astroboy (06-16-2015) |
| Part throttle faster than full throttle | brn12345 | Engine, Exhaust, Transmission | 38 | 10-21-2021 12:20 PM |
| AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? | tracerit | Engine, Exhaust, Transmission | 11 | 02-15-2014 12:44 PM |
| throttle dip? | JDM FRS | Issues | Warranty | Recalls / TSB | 18 | 07-07-2013 03:50 AM |
| 5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? | kharn83 | Issues | Warranty | Recalls / TSB | 9 | 08-06-2012 07:44 PM |
