Old 05-16-2015, 10:31 AM   #1
xZAMx
Drives: '13 FR-S - Hot Lava
Problem with TRD quickshifter gettingloose
This is the second time this bolt (pictured below) has came loose on me after installing the quick shifter. Both times I re-applied loctite to the bolt and screwed it in. The first time I noticed a black washer of some sorts that shredded off. I'm not sure if that is a big deal.
How can I make sure this doesn't happen again?
xZAMx is offline   Reply With Quote
Old 05-16-2015, 06:55 PM   #2
Cop
Cop's Avatar
Drives: 2013 FRS
I've been having this issue as well. The last time I retightened the bolt I actually took some of the loctite off and it seems to have helped a bit.
Cop is offline   Reply With Quote
Old 05-16-2015, 10:12 PM   #3
DGM86
Drives: 15 BRZ, 07 Tacoma TRD, 01 Miata SE
Lock washer?
DGM86 is offline   Reply With Quote
Old 05-17-2015, 12:17 AM   #4
xZAMx
Originally Posted by DGM86 View Post
Lock washer?
Yeah...I don't know if there is a specific part # for it, but I think that will help my problem.
Old 05-17-2015, 12:56 AM   #5
RD1428
RD1428's Avatar
Drives: 2013 Scion FRS
Yep, lock washer that fits
RD1428 is offline   Reply With Quote
Old 05-17-2015, 01:16 AM   #6
ssyed
ssyed's Avatar
Drives: 2013 Frs
use blue threadlocker
ssyed is offline   Reply With Quote
Old 05-17-2015, 10:50 AM   #7
stevesnj
stevesnj's Avatar
Use a Nylock nut, it has Nylon inside the nut and works well. Use loctite 272 if you want high strength
My 2016 Build thread
Old 05-18-2015, 11:00 AM   #8
whip
Drives: 2014 FRS MT
This happened to me when I first installed my kit. I didn't have the bolt threaded properly in the adapter piece that comes with the kit. It was surprisingly difficult to seat properly but it finally took and has been holding strong for several weeks now. Coat that thing in loctite and make sure it's threaded properly.
whip is offline   Reply With Quote
Old 05-21-2015, 04:32 PM   #9
xZAMx
What adapter piece are you referring to? That may actually be my problem, I tightened the bolt again, but a couple days later it became loose again.
Unless I get a locking washer that is slim enough, I don't think it is going to work because it doesn't allow all of the bolt's thread to properly screw into place.
Also, I'm not what the nylon nut is going to do since there is no nut that accompanies the bolt.
I may just say screw it and revert back to stock. I'm having WAY to many problems with this thing that I should not be having.
Old 06-07-2015, 10:01 AM   #10
whip
Drives: 2014 FRS MT
I'm talking about the metal piece the bolt threads in to. Only a small amount of the bolt's threads actually engage so it is really important that you get it seated properly.
Old 06-09-2015, 01:12 PM   #11
SamGam
Drives: '13 BRZ SWP 6MT
Lock washer, and make sure you're torquing it to spec or maybe a few ft/lb more.
SamGam is offline   Reply With Quote
Old 06-09-2015, 01:26 PM   #12
xZAMx
I tried a lock washer, and it seemed to create more problems by creating more space.
I torqued it down and got it seated correctly. I believe I'm OK for now...
Thanks everyone!
Old 08-28-2015, 11:16 PM   #13
axelo
Drives: Whiteout frs
Blue locktite is giving in...will use red in one week...see how much it holds...if not, i'm sealing that shit forever with something...
I love the feel...my kind of driving i guess
axelo is offline   Reply With Quote
Old 08-28-2015, 11:18 PM   #14
xZAMx
I just replaced mine to stock, it wasn't worth the trouble anymore.
The Following User Says Thank You to xZAMx For This Useful Post:
axelo (08-28-2015)
Trd quickshifter=amazing! sanmarcosfrs Engine, Exhaust, Transmission 498 08-15-2017 01:31 PM
WTB TDR QUICKSHIFTER NJUL9925 Want-To-Buy Requests 4 11-26-2014 12:24 PM
FS: trd quickshifter nguyen_er Transmission and Driveline 9 06-26-2014 12:33 PM
TRD quickshifter - still notchy? unsurety Engine, Exhaust, Transmission 2 03-24-2014 12:00 AM
TRD Quickshifter lovebeingbleu98 Brakes, Suspension, Chassis 3 02-13-2014 12:14 AM
