Old 06-05-2015, 06:15 PM   #1
empower-auto
Kouki-Monster
empower-auto's Avatar
Header to make gains / improve torque with SC?
Hey guys, short and sweet - I have an HKS V2 SC kit installed with a 43mm restrictor and am tuned on E10 94 Octane.
I am making 248whp right now and still have that dip down low.
My question is - has anyone had better luck with one header vs another for forced induction? Mostly looking for power under the curve, torque curve results and the closest to OEM fit.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 06-05-2015, 06:26 PM   #2
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Do you have a dyno of your setup? I've got a C30 rotrex, with a JDL UEL with no dip.
Give me a few and I'll dig up my dyno sheet.
Freeman is offline   Reply With Quote
Old 06-05-2015, 06:38 PM   #3
Freeman
Freeman's Avatar
KW C30, A/T, Base tune, JDL UEL, 3 Inch Header beack.
Old 06-08-2015, 11:50 AM   #4
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
http://www.ft86club.com/forums/showthread.php?t=89525
Old 06-08-2015, 12:42 PM   #5
wbradley
Sarcastic SOB
wbradley's Avatar
According to the dyno sheet from the guy that previously had my HKS S/ C w/ header, the torque rise was very linear, no discernible dip. I'll post my dyno after the 18th.
Old 12-18-2019, 08:48 AM   #6
SugarBrz
Guest
Posts: n/a
So has anybody experience which header is the best for an supercharged car?
I´m driving an 2016 BRZ with an HKS Supercharger V3 Kit. Unfortunatly my first engine got destroyed by an catted JDL UEL Header(Catalyzer melted togehter and blocked the exhaust) only 15km after installation.
Due the emission laws here in Germany I can´t drive a catless UEL Header. Right now I´m using a modified OEM Header with an 100 Cell HJS Catalyzer but I´m still looking for a durable catted UEL Header.
Old 12-18-2019, 09:57 AM   #7
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
You could be cheeky and run a 17+ decatted OEM header. They flow good and will look stock to a visual inspection.
The Following User Says Thank You to RToyo86 For This Useful Post:
sroby (12-18-2019)
Old 12-18-2019, 10:11 AM   #8
tomm.brz
Drives: brz 2017 hksv2
I had a hks uel header with my hks v2 supercharger
When I switcher over to a ACE 350 header I was able to run at least 0.4 leaner and gained almost 2 degrees of ignition timing without knocking, and the torque dip that was present with hks header was total filled up and you could feel the car pulling a lot stronger around 4k rpm
I vote for Ace header
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
CSG Mike (12-19-2019), mrg666 (12-18-2019)
Old 12-18-2019, 11:42 PM   #9
jflogerzi
jflogerzi's Avatar
Or JDL 4-2-1 EL header. Bit cheaper than the ace and works with stock or aftermarket overpipes
2013 Series 10 FRS #553
Which EL Header Correct Torque Dip Best? slava Engine, Exhaust, Transmission 56 02-20-2019 07:50 AM
Header torque specs Triumphrider Engine, Exhaust, Transmission 4 06-15-2014 10:09 AM
Header + Android Torque -Tune major quicknap Software Tuning 4 04-29-2014 05:07 PM
Nut torque for header to block? Overland'n'5thGEN Engine, Exhaust, Transmission 10 09-12-2013 11:19 PM
Torque gains, what does the job? JoeBoxer Engine, Exhaust, Transmission 21 10-01-2012 05:46 AM
