Old 04-17-2015, 01:31 AM   #1
kbye
kbye's Avatar
Drives: 2014 FR-S
MTEC clutch spring review
Follow-up to my post here... turns out what I was looking for was already being sold by MTEC - a replacement clutch spring. Didn't see much reviews for it but it wasn't expensive, so what the hell.
MTEC on the left, stock on the right.
They are the same free length but the compression rates are different - I can compress the MTEC spring with my hands but it's a lot more difficult on the stock spring. Install was easy, I followed MTEC's guide here.
Impressions:
Basically what you would expect - it's a compromise between stock and complete spring removal. Provides a bit more weight than stock but not as much as complete removal. It also eliminates the free-play as shown in my poorly animated gifs:
No spring:
MTEC spring:
Verdict:
If I were to do it again, I'd just leave it springless. Like others have said, pedal free-play is a non-issue and while I had the spring out I quickly got used to it. That being said, the clutch feel is still pretty good, better than stock. So I'll leave it in for now, I'm pretty adaptable.
This would also benefit those who don't like the stock light clutch feel but are often in stop-and-go traffic, and/or have chicken legs. Don't skip leg day, bros.
Update 05/12/2015:
After driving with the MTEC spring for a couple of weeks, I'm happy with the pedal feel and don't think my clutch requires any further adjustment. Very worthwhile mod.
My current settings:
- MTEC clutch spring
- clutch height adjustment to 5mm above brake pedal (I think.. will double check)
- stock slave cylinder
kbye is offline   Reply With Quote
The Following 21 Users Say Thank You to kbye For This Useful Post:
akahenry (04-17-2015), AllStar0419 (04-21-2015), cbryant514 (10-04-2017), ck-GT86 (04-17-2015), continuecrushing (04-17-2015), Cop (04-17-2015), DocWalt (03-29-2016), ElijahF (03-13-2020), GhostOp86 (04-17-2015), GT86_PRAGUE (05-12-2015), Hyper4mance2k (04-20-2015), JB86'd (04-17-2015), jcw99 (11-20-2015), Keenercarguy (06-06-2016), Lorico (10-02-2015), Milotic (07-25-2017), Pat (04-17-2015), smg1138 (01-29-2017), tato.valverde (05-05-2015), totally (05-15-2015), zc06_kisstherain (04-17-2015)
Old 04-17-2015, 01:46 AM   #2
Cop
Cop's Avatar
Drives: 2013 FRS
Nice review, appreciate the GIFs
Cop is offline   Reply With Quote
Old 04-17-2015, 12:22 PM   #3
sirsol66
Drives: 2013 FRS- Hot Lava
Thanks for the gif's!
I've had my spring removed for about a year and was wondering about this as well. If it pops up cheap on a group buy, I'll buy it.
How was the install? Trying to get the stock spring back in was essentially impossible.
sirsol66 is offline   Reply With Quote
Old 04-17-2015, 02:56 PM   #4
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Awesome, finally someone bought it.
I saw this floating around and wasn't sure how well it performed. I removed the spring entirely at first, however there were times when the pedal wouldn't come back all the way.
.ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 04-17-2015, 02:57 PM   #5
ck-GT86
ck-GT86's Avatar
Use zip-ties, I made a post about putting the stock spring back in. MTEC instructions even advise to use zip-ties.
.ck
|| My Build Thread ||
Old 04-17-2015, 04:15 PM   #6
kbye
kbye's Avatar
Drives: 2014 FR-S
It was dead easy, zip tied the springs, pushed the clutch pedal down, pushed the rod assembly in and guided it onto the clutch assembly. Then released the clutch pedal and the whole thing popped into place. It helps that the MTEC spring has a lower compression rate than the stock spring.
MTEC also gracefully provides you with two zip-ties to use.
Old 04-17-2015, 05:47 PM   #7
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
good review..i dont know i need it..
Old 04-20-2015, 12:27 PM   #8
sirsol66
Thanks! I'll order one with my next batch of parts.
Old 04-20-2015, 01:25 PM   #9
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Moral of the story? Dont skip leg day bruh
The Following 3 Users Say Thank You to cdrazic93 For This Useful Post:
Adam_L (01-26-2018), Hyper4mance2k (04-21-2015), sato (05-11-2015)
Old 04-21-2015, 04:14 AM   #10
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
@kbye, Thanks for the review. I love the feel of the spring removed, but I hate the slop at the top of the pedal stroke. Too bad the spring isn't just strong enough to remove the slop, yet not change the great spring-less pedal feel.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 05-02-2015, 01:45 AM   #11
MTEC Industries
Drives: 86
Thank you for the review kbye. One thing I do want to explain is that removing the spring can damage you clutch master over time. I've tested and noticed increased wear on the inner seals.
MTEC Industries is offline   Reply With Quote
The Following 5 Users Say Thank You to MTEC Industries For This Useful Post:
Adam_L (01-26-2018), ck-GT86 (05-02-2015), gravitylover (01-23-2018), Hyper4mance2k (05-12-2015), MJones_RB (06-28-2018)
Old 05-11-2015, 10:32 PM   #12
ARTBRZ
Aloha!
ARTBRZ's Avatar
Bought this because of this review. Installed it today and what a great product! Before this I was making myself nauseous with my shifting.
ARTBRZ is offline   Reply With Quote
Old 05-12-2015, 01:02 AM   #13
tunami
tunami's Avatar
Drives: 2013 FR-S 6spd Whiteout
I did this mod recently as well in pair with the MTEC shift springs. Use needle nose pliers to get the c-clip on/off and make your life a lot easier. It does feel alot better than stock. In my opinion the best way to describe the clutch feel would be "smoother" and more controlled returning back to the resting position. It's not an issue for me in traffic.
tunami is offline   Reply With Quote
Old 08-30-2015, 06:18 PM   #14
axelo
Drives: Whiteout frs
just installed
first i removed spring only...it had a lot of clutch pedal play up top...with the mtec spring now, it didn't eliminate the clutch pedal loose play of the no spring and pedal is smoother. don't feel much clutch engagement...well a little... will use it as it is and adjust pedal...
This is great jaja
axelo is offline   Reply With Quote
MTEC Shifter Spring Questions & Comments JohnAyySays Engine, Exhaust, Transmission 19 06-11-2018 08:09 AM
Need help - stripped mtec spring stueck9356 Engine, Exhaust, Transmission 45 04-30-2017 09:14 PM
Yet another Mtec shift Springs review Raven604 Engine, Exhaust, Transmission 19 10-05-2016 08:04 PM
MTEC shifter spring install issue jamesm Engine, Exhaust, Transmission 36 12-06-2015 09:36 AM
DIY Trans Bushing, Rear Shift Bush, MTEC spring Q Ralph Spoilsport Engine, Exhaust, Transmission 7 10-31-2013 09:15 PM
