Old 04-13-2015, 06:10 PM   #1
Zhangy
Drives: 2015 FRS
Wet sanded a scratch then what product do I use?
I sanded a scratch using tutle wax repair kit's super fine 3000-4000 grit pads...
Now it's all dull and scratchy, what do I do next? re-clearcoat? polish?
Update: bought maguier Polish and worked good, then sealed off using plain wash and wax
https://onedrive.live.com/redir?resi...nt=photo%2cJPG
Zhangy is offline   Reply With Quote
Old 04-13-2015, 06:21 PM   #2
civdaddy
Drives: Slow
You bring the color back by buffing that area with compound. Be careful not to burn the edges. If you don't know what I'm talking about you should maybe have someone with experience help you out.
civdaddy is offline   Reply With Quote
Old 04-13-2015, 06:29 PM   #3
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
You can use a 3M scratch removal kit it comes with rubbing compound and a small buffer pad you can attach to a hand drill to buff the area. Just watch the edges of the bumper. No need to re-clear
[ame="http://www.amazon.com/dp/B003NS5NK8/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=2E6N T0EYM5EFA&coliid=I3M0U9PV3L8J01"]Amazon.com: 3M 39071 Scratch Removal System: Automotive[/ame]
brandonblt2 is offline   Reply With Quote
Old 04-13-2015, 06:30 PM   #4
jlugo711
Drives: 2014 GT86
You have to buff it out and wax it after. Use an orbital machine or if you're nervous do it by hand. Don't rub too hard and take your time! Should be good as new.
jlugo711 is offline   Reply With Quote
Old 04-13-2015, 06:37 PM   #5
DJCarbine
Thupercharged
DJCarbine's Avatar
For something that small, some swirl-x on a cloth will shine it up in a few seconds.
I just did something similar to a dime sized patch, wet-sanding + swirl-x and an old microfiber had it glossy and blended back in perfectly in about 15 seconds of rubbing.
What grit did you use? 2000 wet is very easy to get the paint back to where it should be.
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 04-13-2015, 08:37 PM   #6
Zhangy
Drives: 2015 FRS
3000, 3600, and 4000
Old 04-14-2015, 12:59 AM   #7
I like that idea......
You can always practice your body work moves on your lawn mower.
jblmr2 (04-14-2015), Ultramaroon (04-14-2015)
How bad does this scratch look? zonda Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 02-08-2015 03:19 AM
Finally got my first scratch AVodka14 Off-Topic Lounge [WARNING: NO POLITICS] 17 12-19-2014 11:43 AM
DIY-Scratch & Dent FirestormFRS DIY (Do-It-Yourself) Guides 8 06-13-2014 09:09 AM
First scratch pituala Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 05-07-2014 03:58 AM
What to do about this scratch? iamdaspoon Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 31 12-30-2013 08:13 PM
