Old 03-22-2015, 08:57 PM   #1
jarednoel
Drives: Asphalt
Exhaust size
Curious on what size exhaust everyone is running. Currently running a 2.25" exhaust but I'm wondering if it would be okay when I go FI with the SBD kit or if it's necessary for a 3". I'm aware of the bigger gains/better breathing exhaust but I'm just curious about the end of the spectrum that uses stock/oem exhaust piping, etc etc.
Thanks again!
jarednoel is offline   Reply With Quote
Old 03-22-2015, 10:44 PM   #2
robr
Drives: 2013 FRS, with boost by ATS Racing
That small will choke a turbo down for sure, but 3" isn't "needed" unless you want crazy power. I really wouldn't suggest a 2.25" though.
I have a 3" downpipe and over pipe and whatever else you want to call the pipes before where the cat would be. Then I go to a 2.75" exhaust all the way to the back from where the cat would be. I make 360 rwhp at 11psi.
2.5" turbo back will support 300rwhp just fine as well. Routinely see 250 rwhp on full 2.5" setups.
robr is offline   Reply With Quote
The Following User Says Thank You to robr For This Useful Post:
jarednoel (03-23-2015)
Old 03-23-2015, 07:35 AM   #3
mrk1
Drives: Sterling BRZ Ltd
SBD doesn't have a 3" down pipe so running a 3 inch exhaust wouldn't make that much sense. Larger diameter exhaust is most beneficial at the turbo end of the system.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 03-23-2015, 01:01 PM   #4
robr
What mrk1 said is correct about turbos liking the bigger pipes up front. To that point as well, we did an AVO kit with their down pipe (2.5") to a 3" catback. Did 390rwhp at 1 bar. So even a "small" 2.5" downpipe will support a decent amount of power.
A Vortech with all factory exhaust parts, including cats, and TRD muffler did 260 or so, I don't remember exacts right now. Would it have made more power with larger exhaust pieces? Sure. But they aren't needed.
So really, it depends on what power you're hoping to run (I know nothing about the SBD kits).
Old 03-23-2015, 02:02 PM   #5
xxscaxx
Drives: 2013 SWP BRZ
Keep it as big as possible near the turbo side, and stay on the smaller end from the catback if anything. I'll be running 3" downpipe/overpipe/midpipe to my 2.5 catback, not worried about the bottleneck as much as noise lol.
xxscaxx is offline   Reply With Quote
Old 03-23-2015, 03:03 PM   #6
kbogarto
Drives: 2013 BRZ limited WRB
What is the stock exhuast diameter?
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 03-23-2015, 03:26 PM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
2.25 I believe.
I would correct some people's posts on here, but i dont want to start an argument.
Remember fullblown made 743whp on the stock exhaust.
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post:
kbogarto (03-23-2015), xxscaxx (03-23-2015)
Old 03-23-2015, 06:43 PM   #8
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Originally Posted by cdrazic93 View Post
2.25 I believe.
That's crazy! Do you have a link to that?? I just assumed they were running a 3" dp straight pipe
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 03-23-2015, 07:52 PM   #9
robr
If you mean me, "argue" away. I don't get internet butthurt. My point was that a 3" isn't needed. I would never suggest trying to push 300hp through the stock exhaust, but I have no doubt it'd physically work.
And yeah, I assumed that FB car was running at least a 3" turbo back, if not open after the downpipe. Crazy.
Old 03-23-2015, 08:10 PM   #10
mrk1
There are also variables, a 2.5 exhaust with a straight path design will flow a lot and support some nice numbers. Also if you run a external waste gate dumping to atmosphere that's a large volume of gas that does not need to be handled by the exhaust. Yes I know SBD doesn't support a EWG but that's a draw back of the kit.
The Build Thread
Jackson Racing SC - exhaust piping size ndsleep612 Forced Induction 9 08-11-2014 07:39 PM
Stock exhaust size? yetiFR-S Engine, Exhaust, Transmission 0 06-05-2014 08:48 PM
Exhaust Size Cards2323 Engine, Exhaust, Transmission 13 01-29-2014 09:49 PM
Know size and thread of the bolt to the exhaust hanger? JiB Engine, Exhaust, Transmission 4 06-20-2013 09:37 AM
Does anybody know size of mid exhaust pipe? chipz91 Scion FR-S / Toyota 86 GT86 General Forum 2 09-21-2012 09:04 AM
