Old 02-18-2013, 09:57 PM   #1
brillo
Drives: 2013 Firestorm FR-S
Engine oil standard operating temperature
I've looked through the manuals but I can't find the recommend max operating temps. Trying to understand when I should be concerned when tracking the car.
Thanks
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 02-18-2013, 11:03 PM   #2
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
When the engine oil temp climbs up to 100 degree celcius, you start to lose power.
Source
http://blog.perrinperformance.com/pe...-s-oil-cooler/
LeeMaster is offline   Reply With Quote
Old 02-19-2013, 04:00 PM   #3
getbent
Drives: 2013 FR-S Blue MT
I believe normal is between 90-100C. I would start worrying if it gets above 120C and seriously consider getting an oil cooler.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 02-19-2013, 07:08 PM   #4
ML
ML's Avatar
Drives: 13 White MT FR-S
mine usually sits around 200F depending on outside temps, and revs. but 200F +-10F
Old 02-19-2013, 07:13 PM   #5
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
On the street I assume?
On track I'd guess the stock car is 270-300 all day long based on similar cars.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
AZP Installs (04-21-2015), rice_classic (04-21-2015)
Old 02-19-2013, 07:27 PM   #6
ML
ML's Avatar
you are correct
Old 03-17-2015, 11:19 AM   #7
Astroboy
Astroboy's Avatar
Drives: None
Is this what you experienced while tracking your car?
Astroboy is offline   Reply With Quote
Old 03-17-2015, 06:11 PM   #8
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Give these a read:
Measurements and necessity of an oil cooler
Data with forced induction on a twin
JohnJuan is offline   Reply With Quote
Old 03-17-2015, 08:13 PM   #9
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
I live in socal and average daily driving from home to work or back home its anywhere from 190-210F. On track that Ive tracked 3 times average is 240-250F
ExxelDistributions is offline   Reply With Quote
The Following User Says Thank You to ExxelDistributions For This Useful Post:
Astroboy (03-30-2015)
Old 03-17-2015, 08:40 PM   #10
BRZnut
Drives: BRZ DGM Limited
Op, if I can borrow your thread for a second....can anyone direct me to a how-to for installing oil temp/pressure gauge??
The Following 2 Users Say Thank You to BRZnut For This Useful Post:
RevoG (03-18-2015), Teclis (06-27-2015)
Old 03-18-2015, 09:41 AM   #11
RevoG
RevoG's Avatar
Drives: Hot Lava 86 MT
Same question as above. On the block there is one space for a sensor. other sensor will go below the oil filter in a sandwich. So which sensor on which position?
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
RevoG is offline   Reply With Quote
Old 04-15-2015, 02:24 AM   #12
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
According to dash command my avg dd temp is 170f and 190f on the track. I have an oil cooler, upgraded radiator and all the goodies that come with
FRSfan111 is offline   Reply With Quote
The Following User Says Thank You to FRSfan111 For This Useful Post:
86Tony (08-16-2015)
Old 04-18-2015, 08:13 AM   #13
steve99
Drives: FT86
Thanks
depends what oil viscosity your using.
this summarizes it pretty well
[ame="https://www.youtube.com/watch?feature=player_embedded&v=cDfFJ5s6IDg"]FRS - BRZ Oil Pressure and Temperature Tech FA20 - YouTube[/ame]
Data from video
You want to keep above about 40psi at high rpm
so if your running 0w20 once temps get to 225F you starting to get into that low 40psi range.
STREET TEMPS
0W20 Redline
0w20 Redline 185F @ 800RPM 10PSI Oil Pressure
0w20 Redline 185F @ 2000RPM 35PSI Oil Pressure
0w20 Redline 185F @ 4000RPM 54PSI Oil Pressure
0w20 Redline 185F @ 7000RPM 65PSI Oil Pressure
10W30 Redline
10w30 Redline 185F @ 800RPM 19PSI Oil Pressure
10w30 Redline 185F @ 2000RPM 51PSI Oil Pressure
10w30 Redline 185F @ 4000RPM 65PSI Oil Pressure
10w30 Redline 185F @ 7000RPM 83PSI Oil Pressure
10W40 Redline
10w40 Redline 185F @ 800RPM 25PSI Oil Pressure
10w40 Redline 185F @ 2000RPM 64PSI Oil Pressure
10w40 Redline 185F @ 4000RPM 78PSI Oil Pressure
10w40 Redline 185F @ 7000RPM 91PSI Oil Pressure
TRACK TEMPS AFTER 9 LAPS @ 1 Minute 15 Seconds Per Lap
0W20 Redline
0w20 Redline 225F @ 800RPM 7PSI Oil Pressure
0w20 Redline 225F @ 2000RPM 30PSI Oil Pressure
0w20 Redline 225F @ 4000RPM 48PSI Oil Pressure
0w20 Redline 225F @ 7000RPM 43PSI Oil Pressure
10W30 Redline
10w30 Redline 245F @ 800RPM 7PSI Oil Pressure
10w30 Redline 245F @ 2000RPM 35PSI Oil Pressure
10w30 Redline 245F @ 4000RPM 52PSI Oil Pressure
10w30 Redline 245F @ 7000RPM 46PSI Oil Pressure
10W40 Redline (12 Laps)
10w40 Redline 265F @ 800RPM 8PSI Oil Pressure
10w40 Redline 265F @ 2000RPM 31PSI Oil Pressure
10w40 Redline 265F @ 4000RPM 55PSI Oil Pressure
10w40 Redline 265F @ 7000RPM 45PSI Oil Pressure
The Following 2 Users Say Thank You to steve99 For This Useful Post:
fstlane (04-18-2015), Wepeel (04-18-2015)
Old 04-18-2015, 10:34 PM   #14
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
I easily could hit 270F (100% stock) after a day of tracking in 80F weather. This was with 10min~avg sessions with 15min cooldowns between drives... rinse and repeat as many time until sun-down.
The car will start to pull timing after the oil hits 220F.
Before tracking her, go switch to a heavier oil. 0w20 is fine for daily grinds but, it loose's it's pressure when it gets past 240F.
Temperature not reading below 0 BrewCity-FR-S Scion FR-S / Toyota 86 GT86 General Forum 6 01-22-2013 10:05 AM
BRZ temperature display malfunction percyng CANADA 7 10-24-2012 09:31 PM
Seat heater temperature? milenko11 BRZ First-Gen (2012+) — General Topics 29 09-20-2012 01:19 PM
Disp Temperature not accurate marinjim Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 08-22-2012 08:16 AM
Engine temperature Skye Issues | Warranty | Recalls / TSB 5 08-09-2012 10:33 PM
