Old 03-06-2015, 05:47 PM   #1
Flight_School
Drives: 2015 Series.Blue
OpenFlash Tablet Error
So the other day, I was planning to write my original file back into my brz, plugged everything in, made sure it was secure, followed the on screen instructions and every time I tried to write, it says error, file can't be written to the ecu, please try again.
The last time I wrote was about 2-3 weeks ago. I updated the OFT to the best of my knowledge, turned off music, all unnecessary electrical items, and still no success.
Has anyone had any issues like this before?
I already tried emailing the OFT team but I'm getting the feeling they are over busy.
Flight_School is offline   Reply With Quote
Old 03-06-2015, 05:57 PM   #2
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
Your headlights off?
jaorocks1 is offline   Reply With Quote
The Following User Says Thank You to jaorocks1 For This Useful Post:
Flight_School (03-06-2015)
Old 03-06-2015, 05:58 PM   #3
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
@steve99
Your genius is requested.
Bobblehead is offline   Reply With Quote
The Following User Says Thank You to Bobblehead For This Useful Post:
Old 03-06-2015, 06:04 PM   #4
Flight_School
Yes my headlights were off each time.
Old 03-06-2015, 06:04 PM   #5
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
did you make sure the cable was seated in the OFT and the obdII connector?
is the stock tune already flashed?
The Following User Says Thank You to continuecrushing For This Useful Post:
Old 03-06-2015, 06:06 PM   #6
Flight_School
Yes I double, then triple checked to make sure all the cables were pushed in properly in both the OFT and the OBDII connectors.
No, the stock tune is not already flashed. Not only can I not flash the stock tune, I can't flash any tune that was saved.
Old 03-06-2015, 06:22 PM   #7
swarb
Rewrite the tune on the tablet and try again.
The Following User Says Thank You to swarb For This Useful Post:
Old 03-06-2015, 06:59 PM   #8
Robert@Openflash
Robert@Openflash's Avatar
Drives: C6 Z06
You got PM'd
Robert@Openflash is offline   Reply With Quote
The Following User Says Thank You to Robert@Openflash For This Useful Post:
Old 03-06-2015, 07:49 PM   #9
Flight_School
I don't understand, what do you mean by re-write the original tune?
Old 03-06-2015, 08:05 PM   #10
steve99
Drives: FT86
Check if diagnostics work, if diagnostics ie real time logging works then connection to ecu is ok.
Try to write your original tune from the protected slot.
Make sure ignition is FULLY ON not just accessory but engine not running.
Old 03-06-2015, 08:10 PM   #11
Flight_School
Dianostics was working. I downloaded the original file, and re uploaded it in the save file number 5 and it is currently writing, so idk what happened but i hope it works now, i see the writing bar so i just have to keep my fingers crossed!
The Following User Says Thank You to Flight_School For This Useful Post:
steve99 (03-06-2015)
Old 03-06-2015, 08:16 PM   #12
raven1231
is your glove box open?
Old 03-06-2015, 08:19 PM   #13
Flight_School
No, the glove box was never open.
Old 03-06-2015, 08:33 PM   #14
Flight_School
Success! Thank you everyone for your help, I'm sure something yall told me to do helped!
The Following 3 Users Say Thank You to Flight_School For This Useful Post:
Annahra (03-06-2015), Chimera (03-06-2015), Shiv@Openflash (03-06-2015)
OpenFlash Tablet will not connect to OpenFlash Manager rever5e Software Tuning 10 03-12-2022 10:17 AM
Open Flash Tablet Error Messages DarkSunrise Software Tuning 22 08-30-2019 02:03 PM
FS: Brand New Openflash Header AND Openflash Tablet combo FT86POWER Engine, Exhaust, Bolt-Ons 6 02-11-2015 02:56 PM
Openflash Tablet + Openflash Header smellslikecurry Engine, Exhaust, Bolt-Ons 9 12-01-2014 06:20 PM
Open Flash Tablet Error flippy Engine, Exhaust, Transmission 2 08-14-2014 11:18 AM
