Old 02-03-2015, 11:56 AM   #1
Assphalt
86 noober
Drives: Asphalt FRS, 90' CRX
Tinting mirrors to reduce nighttime glare
So I have been very interested in buying a set of Prova wide mirrors in a yellow tint for night time driving. These mirrors though, are not a full replacement but simply a mirror you stick on top of the factory one from what I understand.
Would I be able to simply tint my mirrors using yellow Laminx and get the same effect? I'm unsure if there is some sort of special polarization to those mirrors.
Has any one done this before?
-Thanks
Assphalt is offline   Reply With Quote
Old 02-03-2015, 12:32 PM   #2
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
"Wide angle" mirrors change the optics to get that "wider" view. Tint alone can not do that. Did they use a special tint? I have no idea.
Old 02-03-2015, 12:48 PM   #3
DAEMANO
Time Traveller
Tinted mirrors using vinyl would be very blurry. Do not recommend.
I mounted a set of yellow mirrors on my car by removing the old mirrors from their housing. I removed the mirrors with brackets attached from the car (they snap right out). To remove the OEM mirror from the bracket, I used a heat gun to soften the adhesive holding the mirror onto the bracket. Took out the OEM mirror, then reused the adhesive to install the new yellow ones (added LED turn signals underneath). Worked like a charm and has held well for months now. If you want more glue, then use 3m Windo-Weld (you can get it on Amazon).
The Following 3 Users Say Thank You to DAEMANO For This Useful Post:
Jake_86 (02-22-2015), Jrryjms07 (02-21-2015), NWFRS (02-03-2015)
Old 02-03-2015, 01:07 PM   #4
Porcupint
Drives: 13 GBS BRZ
Rexpeed mirrors are the actual glass replacement. It's what I have and they're amazing. I'd never go back.
These are the ones I have.
http://www.ft86speedfactory.com/rexp...ated-1354.html
Porcupint is offline   Reply With Quote
Old 02-03-2015, 03:22 PM   #5
Ammunition
Ammunition's Avatar
Drives: 2014 Scion FR-S
+1 for the Rexpeed full-replacement mirrors. Wide angle, and anti-glare. I couldn't believe how much more I was able to see after replacing my factory mirrors with these, and like @Porcupint said - I can't imagine ever going back to the factory mirrors after installing these.
Ammunition is offline   Reply With Quote
The Following User Says Thank You to Ammunition For This Useful Post:
Porcupint (02-03-2015)
Old 02-03-2015, 06:06 PM   #6
Assphalt
86 noober
Thanks for the replies. For those that have yellow tinted mirrors, how well do they reduce glare at night?
Old 02-03-2015, 06:34 PM   #7
Eski
Eski's Avatar
Drives: '15 Brz Series Blue
+1 i find headlights at night are so blinding i wear my sunglasses sometimes just to avoid the headache. #unsafeftw
Eski is offline   Reply With Quote
Old 02-03-2015, 06:43 PM   #8
Porcupint
Drives: 13 GBS BRZ
Don't have yellow, but the blue is incredible at reducing glare. I could care less if there's a jacked up truck with HID's behind me now. Previously it would give me a headache and have me cussing, but now it doesn't even make me squint.
Old 02-03-2015, 07:09 PM   #9
Assphalt
86 noober
From what I understand blue tints are suppose to improve daytime glare, yellow tint for night. I dunno.
Plus the yellow as an additional asthetic appeal to me and would compliment my yellow fogs!
Old 02-03-2015, 09:08 PM   #10
8R6
8R6's Avatar
Drives: FRS
are there yellow tinted mirrors that ARENT wide angle? i dont like convex mirrors and have no need for it really. i just want to reduce the glare
8R6 is offline   Reply With Quote
Old 02-03-2015, 10:06 PM   #11
ARTBRZ
Aloha!
ARTBRZ's Avatar
Have you noticed it affecting the mirror heat function?
ARTBRZ is offline   Reply With Quote
Old 02-03-2015, 10:08 PM   #12
ARTBRZ
Aloha!
ARTBRZ's Avatar
Have u noticed the heater function for the mirror being affected? I asked the other person but I noticed they live in LA. Weather fluctuation rarely happens.
Old 02-03-2015, 10:27 PM   #13
Porcupint
Drives: 13 GBS BRZ
LA as in Louisiana and we've been jumping between mid 20's and 80's the last week lol
The heat function seems to take a little longer, but I never timed it to compare to stock. Usually by the time I get the 2 miles down the road to the interstate, they're completely clear. So around 1.5 minutes to go from completely fogged/frozen to clear.
The Following User Says Thank You to Porcupint For This Useful Post:
ARTBRZ (02-03-2015)
Old 02-03-2015, 10:32 PM   #14
DAEMANO
Time Traveller
My yellow mirrors do help night time glare and are also brighter at night than blue ones I've seen. I think the yellow is made for this purpose.
Product To Reduce Dash Glare? Captain Snooze Cosmetic Modification (Interior/Exterior/Lighting) 12 08-20-2015 06:55 PM
Reduce interior sound KillionsFRS Cosmetic Modification (Interior/Exterior/Lighting) 15 10-28-2013 05:23 PM
WTT: My cf mirrors for your Raven mirrors- PLEASE LOCK FR-Shadow Exterior Parts (Aero, Lighting, Etc.) 3 09-25-2013 10:01 AM
1080p Nighttime Test Drive w/ ContourROAM1 forzajuve Electronics | Audio | NAV | Infotainment 0 04-30-2013 02:41 PM
Nighttime Test Drive w/ ContourROAM1 forzajuve Scion FR-S / Toyota 86 GT86 General Forum 0 04-29-2013 09:21 PM
