Old 11-01-2014, 06:35 PM   #1
Eazy-V
Any rubbing issues with 17x9.5 +40 wheels and 255/40/17 tires?
Eazy-V is offline   Reply With Quote
Old 11-01-2014, 07:08 PM   #2
CSG David
CSG David's Avatar
On stock suspension, yes.
Old 11-01-2014, 10:13 PM   #3
momo3605
Drives: 2014 Fr-S Monogram
CSG David...could you explain why stock suspension would rub and aftermarket would not? I'm looking at similar fitment to above but 18x9 et 45. If they don't fit with stock suspension, would it be very close and possibly rub with Ohlins?
momo3605 is offline   Reply With Quote
Old 11-01-2014, 10:29 PM   #4
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Stock suspension(struts/springs) are a lot wider than coil overs which allow for wider wheels and bigger offsets. I suggest going with 245/40.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 11-01-2014, 10:35 PM   #5
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
My 245 40 on 17 x 9 +42 barely fits on stock suspension with proper camber. I couldn't even get 1.2 degrees without it rubbing. 9.5 and 255? no way without coilovers.
Old 11-01-2014, 10:51 PM   #6
tnle
Drives: Toyota 86 13'
Because the back rim of the wheel is touching the spring, with an after market coilover you can add negative camber (which pushes the top of the coilover closer towards the engine), clearing the wheel
I can't fit my TE37SL 18 x 9.5 +45 without coilovers. LCA were ONLY required on the rear, if you aren't going to slam your car for more camber
tnle is offline   Reply With Quote
The Following User Says Thank You to tnle For This Useful Post:
CSG Mike (11-02-2014)
Old 11-01-2014, 11:55 PM   #7
Eazy-V
I have Tein monoflex coilovers and with max negative camber, I had slight inner fender liner rubbing on the front wheel when taking corners hard. So, lets say I set -1 camber in the front and rear should 255/40/17 have any rubbing front or rear?
Old 11-02-2014, 01:46 PM   #8
momo3605
Does the brand of coilovers matter? I want to fit 18x9 et 45 with 235 or 245 tires with -1.5 degree camber on ohlins coilovers. Will that easily fit?
Old 11-02-2014, 01:49 PM   #9
Reaper
Reaper's Avatar
Drives: violent
Yes.
Old 11-02-2014, 02:08 PM   #10
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
My Enkie RPF1, 17x9x45, 235/40 Nitto, hit the stock front coil. I had to add a 10mm spacer.
Back cleared OK.
Lunatic is offline   Reply With Quote
Old 11-02-2014, 03:04 PM   #11
D_Thissen
D_Thissen's Avatar
A 17x9+35 might work better. Even then, I think you might need some negative camber up front
Old 11-02-2014, 09:18 PM   #12
CSG David
CSG David's Avatar
Try raising the car a little bit. That action remedies that particular issue.
Old 11-02-2014, 09:18 PM   #13
CSG David
CSG David's Avatar
You need a coilover with around a 60mm diameter spring. Factory springs are 90mm diameter at minimum.
Old 11-02-2014, 09:29 PM   #14
CSG Mike
CSG Mike's Avatar
Sort of. It depends on the diameter of spring your specific coilover uses, but the higher end stuff can be converted to use any diameter spring.
Sharing 17x9 Track Wheels & 255 Tires with a 5x114 Car AyJay Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 05-27-2014 01:30 AM
WTB: 18x9.5/ 18x9/ 17x9/ 17x9.5 Square With or without tires loogs Wheels and Tires 11 12-08-2013 03:40 PM
Rubbing issues boricua FR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 11-23-2013 07:28 PM
17x9 235/45 vs 235/40 tires QUESTION karma003 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 07-21-2013 04:13 PM
FS: Gramlights 57d 17x9 +38 5x114.3 w/ tires 1500 miles on tires, $1800 shipped apexsti46 Wheels and Tires 6 09-05-2012 02:54 AM
