Old 10-01-2014, 03:08 PM   #15
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by Sleepless View Post
I didn't have any fade issues at ORP even without the ducts. No tapering issues either.
I get about 5 track days per set of front pads which I don't find particularly premature.
My car has stock power and the stickiest tires I've run are 235 AD08s. Given your supercharged power and use of R-comps, I'm guessing those are going make a big difference on brake performance needs/stress. Frankly, I'm surprised you can run on stock calipers!
interesting, in my case it starts fading after couple hot laps but maybe it's due to the more aggressive tires like you mentioned..since the stopping distance is exponentially effected with speed the faster you go the faster your brakes will suffer
Running on stock calipers and XP12s is not an issue even with the supercharger but only at RMP, PR and ORP is a whole different story but with the ST43s and new tires I can trailbrake a lot easier, I will eventually upgrade to a BBK of course
FYI, XP12s fade really really bad at 3A and 3B (Pacific Raceways)
glamcem is offline   Reply With Quote
Old 10-30-2014, 04:49 AM   #16
Panman
Panman's Avatar
Drives: 86 GTS
@rever5e What size rotors are you running? I've got a line on some used ST40 332/32s I'm doing 1-2 HPDE/Motorkhana/Drift days per month and a reasonable amount of canyon carving. Looking at NT01 for track rubber. Cost for the kit is equivalent to used STI Brembos.
Panman is offline   Reply With Quote
Stoptech S/S brake lines: same between stock caliper vs big brake kit? mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-10-2016 07:14 PM
Raybestos ST43 brake pad review!!!! icemang17 Tracking / Autocross / HPDE / Drifting 52 08-20-2014 01:44 PM
AP Racing CP8350 (Essex Sprint kit) vs Stoptech ST40 Comparison CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 05-17-2013 03:41 AM
FS: Stoptech Brake Lines FRS2000 Brakes, Suspension, Chassis 1 12-17-2012 04:07 PM
StopTech Brake Kit for the FR-S / BRZ Drift-Office Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 08-24-2012 02:36 AM
